Sennheiser HD 6 Series Comparison Thread
Resolve has just put out a video comparing all of the currently available headphones from the 6 series (as well as one from the 4 series), so I thought it prudent to have a place to discuss the topics addressed in the video as well as anything else surrounding the comparisons between all of these headphones.
Below you can find all of the measurements included in the video, as well as a few others I’ve taken the liberty of adding.
Individual Frequency Response Measurements
Sennheiser HD 600
B&K 5128 — DF-Calibrated
B&K 5128 — Raw
GRAS 43AG with KB50xx pinnae — Raw
B&K 5128 — DF-Calibrated, pad wear effects shown
Sennheiser HD 650
B&K 5128 — Raw
Sennheiser HD 6XX
B&K 5128 — Raw
Sennheiser HD 620S
B&K 5128 — Raw
Sennheiser HD 660S2
B&K 5128 — Raw
Sennheiser HD 490 Pro
B&K 5128 — Raw
Impedances of the HD 6 series (and HD 490 Pro) compared
Total Harmonic Distortion measurements
HD 600
HD 650
HD 620S
HD 660S2
HD 490 Pro
Excess Group Delay
HD 600
HD 650
HD 620S
HD 660S2
HD 490 Pro
I see that you are testing both a 650 and a 6xx, and that they appear to have some differences. Are these within expectations for unit variations, age of units, ear pads and wear, or does it appear that despite the hype, that these are truly different units?
In the video this thread is referencing, Resolve mentions that we should probably still think of them as the same headphone, as with the same earpads they measure near-identically both in terms of Frequency Response as well as impedance.
Gras mic drop.
No need for any more Sennheiser HD 600 series videos for the next couple of years from anyone else as this video is spectacular. Even though I would place Drop HD6XX in D tier, Resolve is spot on coming from the subjective perspective. Props! Bravo Resolve!
This image is now a thing that exists on the internet… The horror
Very well done. I like it when @Resolve gets enthused. :grinning:
Been thinking about dipping into the Sennheiser pool. I’m leaning toward the 490 Pro, I’ve got some other “Pro” styled headphones ( Yamaha, AKG ) and this looks like it would be a good fit with my wonky ears.
Mark Gosdin
Great video - I do like that the HD490 Pro was included as I do really like that headphone after having used it for a few weeks now.
Your video was solid, @Resolve. Great job. :clap:
This is the first time I see an impedance plot for the 660S2. Quite an elevated one.
Anyway, since I am in the brain burn-in camp, and after owning the 600 for 4 years and the 660S2 for almost a year, I can comfortable state that even though the 600 sounds more natural in the first couple of songs, the 660S2 gives me a better experience in the long run, i.e., after my ears adjust to its FR. But we’re living in the instant dopamine era, so the 600 will always be easier to recommend. :man_shrugging:
To my ears – while in longer listening sessions: 660S2 > 650 > 600 > 660S
Cheers. :beers:
Thanks for this survey of the 6 (and one 4) series headphones, Resolve!
I’ve flirted with the idea of a 6 series headphone for a long time. But guess the lack of sub-bass and maybe also soundstage has kept me away. The 490 Pro looks like a fairly nice additional though to Sennheiser’s Pro lineup. And perhaps one I might consider.
I’m tryin to get away from EQ though. And the 490 Pro looks a tad bright in the low treble, not unlike my current Beyer DT-770. If you do another vid on the 490 Pro, it might be interesting to see a comparison with Focal’s new Hadenys, and maybe a couple other recent open backs that also extend well into the bass.
I know you’re not really the tech guy at Headphones.com, btw. But there are a few issues along more technical lines that I’d push back on, or want to know more about in the 6 Series Comparison video. I don’t agree that a midrange/BBC dip = soundstage, for example. And don’t necessarily agree that more “heads” are better, unless they’re close to the anthropomorphic/metric characteristics of a rig like the 5128. (The 5128 manikin still needs some work tho imo.)
I’d also like to know more about how a DF HRTF curve was computed for the GRAS 43AG, because accurate free field and diffuse field HRTF measurements normally require a manikin with at least a head and neck that interacts with the sound field. And I don’t see how you’d get those, or translate them correctly to over-ear measurements made on a system with a flat plate and no head, like the 43AG.
IAC, I’ll be interested to see how your efforts to correlate measurements between rigs proceed. And look forward to maybe hearin a few more thoughts on the 490 Pro, if you do another vid on this.
Re the DFHRTF, this would’ve been from Oratory taking the KEMAR to “a facility” as I called in a recent live stream haha. My understanding is that this was calculated from FF (power weighted average). But this is where @Mad_Economist would have to fill in the rest of the details. I will say, it has yet to be independently validated, but it’s what we’re moving forward with currently since it lines up with the measured result as well.
Regarding the different heads thing, this is something we’re currently researching. But there’s already a lot pointing to HpTF variation across real heads being a far more significant factor than even we had previously considered. So I’d say just keep an eye on what we’re doing there. Once we have something more concrete to share on that front I’m sure we’ll make a video.
Re the soundstage effect, I don’t think it’s just a dip around 1.5khz. I think it’s a combination of that dip with certain extra presence in the treble. But in just about all headphones that are seemingly well received for this effect, these features are present.
Edit: not Struck method
Thank you very much for the detailed reply, Resolve. And happy July 1st or 4th, whichever is most applicable in your cases. I wanted to give your 6 series comparison video another look before responding to the above and maybe givin a more in-depth take on some of this, because there’s alot of ground covered in this video, in a relatively short space of time.
I also like to quibble about some of the technical stuff. But overall, I think you and DMS are doin a pretty decent job on most of your measurements and reviews. And I find myself agreeing with more of your takes than not. I hope both of you will continue to post your raw/uncalibrated/uncompensated measurements though, since I prefer to use my own methods of compensation and reference curves, rather than the ones Headphones.com is currently offering.
For me, the most logical baseline or reference point for a headphone’s FR is still the in-ear FR of a pair of good neutral speakers in a typical semi-reflective room. And I hope that you, DMS, or some other kind soul at Headphones.com will make a run at this at some point, so we can see how this type of in-ear response compares to the raw headphone measurements. I know some on your staff think DF is the best way to go. But for me, it’s just a stepping stone to get a little closer to the above, until some better in-ear measurements of speakers are available.
I have some gripes about the way y’all are doin DF compensation as well, but will save most of those for another time or place. I like the results I’ve been gettin recently with HBK’s original 1/3-octave 5128 DF measurement though. And would like to try posting a few examples of this in another topic here, maybe in the Technical Forum.
The comparisons of new and worn earpads was very interesting. I wasn’t expecting that much variation in the before and after on these headphones. But my experience with other headphones has been similar. As the pads wear, and become more compressed (and your ears get closer to the drivers), the FR seems to get warmer sounding. This may not be true for all headphones though.
I’ve been wondering about the potential influence of pad flap on some of the closed back measurements as well. So I’m glad you threw in the slide of the HD620S with increased clamp for comparison. And hope this is something you’ll continue to look at, and try to understand better. I know you need fairly high dBs when doing measurements to filter out the background noise. But I wonder if that could be adversely (and maybe unfairly?) effecting the bass measurements on some closed-backs, since it may not necessarily represent the responses at more typical listening levels. And I seem to be noticing a bit less mid-bass emphasis in some of Jude’s (and maybe also the Sound Guys’?) closed-back measurements by comparison.
Tyll put his old Head Acoustics rig in a small insulated box when doing his headphone measurements. And I wonder if that might be something to consider as well. Seal or leakage issues around the 5128’s cheeks might be something else to look at.
On the subject of HpTF variation, I think you’ll have to explain what this refers to a little more, and why you think it’s important… I expect headphones to measure differently on every head, ear, and ear canal. This is more of a problem, imho, with IEMs than with over-ear headphones though (even though some of the technical research seems to contradict this), because an individual’s HRTF interacts much less with an IEM, making it harder to filter out the HRTF effects, and produce a reliable, predictable result. This is why I only use over-ears for my critical headphone listening.
I still expect some variation with over-ears. Assuming we all fall within a more or less normal range of human physical characteristics though, compensation should take care of alot of that. That is really the point of compensation, in fact! To filter out the individual effects of a person’s or rig’s transfer characteristics, so that measurements on two or more individuals or systems can be more easily compared. This is one of the main reasons we do compensation, or “calibration”, as you refer to it in the video.
Re soundstage, since this is largely a subjective effect, I think it’s difficult to actually pin down precisely what’s responsible. I think Tyll and probably also some of the more informed developers and subjective listeners in the hobby would probably say that it’s a bit more involved than just a midrange dip and some extra treble though. This might also be a good topic for another thread though.
I think that a slight dip in the upper midrange can potentially improve the timbral and tonal balance of some recordings though, because the speakers used for mastering recordings will often have a dip or depression in their in-room response due to cross-over and directivity issues in the same frequency range. A good example of this is the Adam T8V…
https://www.spinorama.org/speakers/Adam%20T8V/ASR/index_asr.html
The in-room response of the T8V has a fairly pronounced dip at around 2 kHz in the upper midrange. And it also rises up fairly significantly in the low treble before descending back down again in the higher frequencies. To properly decode a recording mastered on a speaker like this, you’d need a headphone with a similar dip and rise in the same ranges. This might improve the perception of soundstage as well. But it may only be because the headphones are doing a better job of matching the tonal and timbral balance of the transducers used to produce the recording.
The Adam is a somewhat extreme case, but there are many other well-regarded speakers with a similar dip or depression in their in-room/off-axis response, at the cross-over of the midrange and tweeter drivers. So this is not an uncommon thing. Recent speaker designs (with DSP and improved cross-overs) are beginning to address this issue though. And getting much closer to acheiving a linear in-room slope from F0 in the bass to the treble.
Sorry to hear you’re under the weather in the livestream btw. Another thought also occurred to me though on the subject of pad wear, after watching the 6 series video…
If you have a good, reliable in-ear mic, like maybe the one used to measure the difference in response between the HD 600 and 650 on your own ears, perhaps that could be used to document any changes in your headphone’s response over time, due to pad wear and other factors, so appropriate adjustments could be made in your EQ settings to compensate for those effects. For this to work most effectively, you’d probably need measurements with an in-ear mic and also a good HATS (like the 5128) made while the pads and headphones are still brand new, so you have a good baseline to begin with for comparison and any future tweaks.
The pad wear effects on the 6 series seem to be confined primarily to the higher frequencies though. So perhaps that could be tweaked with just a simple high frequency shelf control.
There’s no guarantee that changes in FR due to pad wear or aging would measure the same at the eardrum reference point (of a HATS) as they due at the entrance to the ear canal, btw. But an in-ear mic might give at least a general idea of what’s goin on there for the purpose of doin some basic EQ adjustments.
Hope you’re feelin better soon.
This is perhaps a minor point, but looking a little more closely at some of the pad wear comparisons, I notice that the unworn plot of the HD 650’s left driver (shown in the first graph below) is not as good a match in the treble to the average of the two drivers shown in the basic DF compensated HD 650 plot. Is this because there’s a little asymmetry in that range on the HD 650?
Do you attribute that to the lower ear gain, or some other aspect of the frequency response? It’s interesting to see that the S2 has such a large bass spike in the impedance curve, but I would have expected this to have more of an impact on the frequency response (or does that manifest in some other way psychoacoustically?)
This was the first time I’ve seen a good comparison between the 650/6XX and S2, and am surprised that the overall bass presence of the S2 is not actually elevated compared to the 650/6XX (small sub-bass shelf, but everything else is more subdued). I’ve certainly been telling myself that the S2 is bassier, but I don’t know if that’s just placebo based on marketing or if I’m just cuing off the small lift in sub-bass.
Well, the S2 does have darker mids and I don’t hate that. My trick is to never cross a certain volume ceiling – which does not necessarily need to be low. Under this circumstance, I find its tonal balance really good while having a very comfy listening. If I cross this ceiling, the S2 starts sounding shouty to me.
And this goes in the opposite direction when comparing to the 600/650s. These other two always “beg” me to increase the volume, for instance.
Another dear diary post. Sorry.
Not Sound Stuff:
  • The build and comfort are fine. These are one of the few headphones I can avoid maxing out the headband, but barely. Clamp loosens up over time(Except with the HD 620S) which is nice. They distribute their weight nicely on larger heads too.
  • They feel sturdy and durable, if a bit cheap. It’s a shame Sennheiser does not sell replacement drivers, at least as far as I can tell. 3rd party online stores sell them for the price of an HD 6XX(In Canada). You’re better off just getting a replacement headphone.
  • My biggest gripe is the shape and compliance of the ear pads. I wish they were angled more straight down, and also that they were a bit softer so they could compress against the head with a wider surface area. The HD 620S pads are great, except it feels like placing your ears in a greenhouse after a short period. Also, the HD 620S clamps against larger heads like two hydraulic press machines on each side.
  • The 490 Pro is a wildcard. The headphone is simply a bit small in every way. The mechanical design is simply fantastic though.
Subjective Sound Stuff: Remember, wiggly air in my ear drum is not the same as wiggly air in yours. And then headphones hate me either more or less on my head compared to you on your head. Which means they respond different.
Also, these impressions are all on new ear pads.
HD 660S2:
  • The HD 660S2 was a bit of a letdown for me. It took the “Lush” midrange and “Smooth” treble of the HD 600/650, and created a subjectively “Muffled” and “Hollow” midrange and treble presentation. But then the recessed ear gain and lower treble exacerbate the peak that is created around 5kHz for me.
  • The only thing I sometimes enjoyed was the bass. It was somewhat “Snappy” with some tracks, but with others it was limp and subjectively “Flat” or “Textureless”
HD 600:
  • Really, really good. However, there are times when it can be just a hair shouty, and the forward shifted ear gain subjectively can add a “Grain” or “Papery” texture to various guitar and vocal tones. Lastly, sibilance is not a problem with 9/10 tracks, but it still appears once in a while.
  • I am nitpicking pretty hard though. The 600 and 650, for all intents and purposes, are very similar. Especially when the pads are worn in.
HD 650:
  • Basically the perfect headphone for my preferences, though I have not heard the Sennheiser HE-1.
  • For me, the HD 650 requires zero EQ. Personally, I prefer it significantly more compared to the “Dry” and slightly “Gritty” HD 550 as well.
  • Strangely, I do not subjectively hear the ear gain shift with the HD 650 much at all, whereas as I do with the HD 600. I think there are a few ingredients that create a personal psychoacoustic effect which basically masks that FR feature for me. But, I could be wrong. As I am unaware how much unit variation could be at play here or not. Though the ear gain around 3-3.5kHz does not sound more recessed here than the HD 600 for me.
  • Those ingredients are aspects with the “In-situ” FR that make the HD 650 sound warmer and darker than the HD 600, which makes that ear gain “Grit/grain” feature less noticeable. Or, it makes that feature “Fit in” or sound “more in-line” with the rest of the response. Whereas it “Stands out” more with the HD 600, maybe.
HD 620S:
  • Fine for a closed-back. The FiiO FT1 existing makes it overpriced in my opinion.
  • I do get a lot of sub bass. But the mid bass hump still overpowers it a bit more than I would like. The lower midrange has a subjectively “Boxy” characteristic to it, upper midrange overtones are undermined by the lower midrange fundamentals, which themselves are dealing with the “Boomy” mid bass bloom.
  • And then the treble is similar to the FT1 for me where it is not high in amplitude, but still very uneven. “Splashy” mid treble overtones, “Shimmery” upper treble, dark 8kHz(most headphones are dark there on my head) and then elevated lower treble harmonics making percussive hits compressed. Except now they are also subjectively “Wooly” from the excess mid/upper bass.
  • The FT1 had the redeeming qualities of the frankly incredible bass, and then a “Fine” lower midrange. Whereas for me, the HD 620S is basically a complete mess.
HD 490 Pro:
  • Not much listening time with the sound signature.
  • Subjectively, it is better than the HD 560S with the Mixing Pads. But it still has all of the same flaws for me personally, except to a lesser degree.
  • Those issues being the same as the HD 660S2 in the bass, being “Limp” and somewhat “Textureless”
  • The same thin lower midrange as the HD 560S which takes a steep climb into the ear gain, which comes off as shouty. The same “Sandpaper” effect with lower treble harmonics. And then the same dark upper treble and “Air” frequencies.
  • However, 10kHz is noticeably less “Shimmery” than the HD 560S, which is nice.
  • I got lucky with Listener’s 5128 HD 560S squiglink. It sounds very, very similar to how I hear the HD 560S, which makes it very easy to EQ. I cannot say the same for the 490 Pro.
HD 580 Precision:
  • Not much listening time.
  • An “HD 560Sified” HD 600, but way better than the HD 560S.
  • Slightly thinner, shouty midrange. Slightly more “Papery” and “Shimmery” treble compared to the HD 600.
HD 58X Jubilee:
  • An “HD 560Sified” HD 660S2. But still better than the HD 560S in my opinion. And the “HD 560Sification” is more subtle.
  • Slightly “Thinner” and “Grainier” and brighter sounding HD 660S2.
I have not tried the HD 660S(1).
Thanks for these impressions, Unrelentingly.
I have been probing around for distortion info on the HD 490 Pro and 6XX for comparison to some other headphones. And having a little trouble interpreting and comparing some of the plots here. Does the HD 650 have the best distortion performance of all these headphones? And which one would be the next best?
