Sennheiser HD 800 S - Open Back Dynamic Headphone - Official Thread
:+1: :+1: :+1:
Whatever the reason, whatever the sound chain, the Focal Clear has excellent instrument sonic reproduction, imaging, speed and punch capabilities.
But when playing back voices, whether male or female, this has a similar problem as, to my hearing, many planar drivers also have them, they simply sound unnatural, sometimes metallic, sometimes too harsh, or shrill, but almost never normal.
That’s why the HD800s is always my choice 90% of the time, unless the music genre allows for the qualities of the Clear, and vocals or spatiality play a secondary role.
Amen brother. Your wisdom is scripture in my book.
Planar magnetic headphone sound is absolutely precise and amazing. But yes, it seems easier to digest organic reproduction of high performing dynamic drivers.
Yes, it was the harsh edge to the vocals that killed the Clear for me. I’m not certain, but playing around with EQ suggested that the elevation from 1-2k was (at least partly) to blame. The Ether 2 is flatter in this region, and the 800S flatter still, and their vocal presentation is much more natural to my ears.
Many thanks for taking the time to respond so comprehensively.
I’m afraid I’m (for now) reasonably convinced that I can’t consciously identify differences in source gear. I’m not saying I don’t at some level experience the differences others are able to identify and articulate; only that I can’t pinpoint them in side-by-side (including blind A/B) comparisons, regardless of which of my headphones I use.
I have no doubt others - yourself included - can hear these differences, and I thought @Torq and @GoldenSound’s scores on the Klippel distortion test were particularly instructive - I can’t reliably hear distortion below -43dB (they both reached -69dB).
So - getting back on topic - I’m definitely curious to hear what more the likes of the Utopia and D8000 have to offer over the HD800S, but I think it’s unlikely I’ll upgrade from my RME-ADI 2 and Jot 2 (at least until I have compelling first-hand evidence that the benefits of doing so wouldn’t be wasted on me).
Well that’s fine too. If you’re happy with what you’re hearing and are satisfied with the gear you have then that’s the MOST important imo. It’s a hobby after all, you find what works and what doesn’t work. You learn from it, and have fun along the way. No need to take it too seriously. And unfortunately, there’s no one-size-fits-all. The best suggestion I can give is to go at your own pace and hear as much as you can.
The biggest problem with those tests is that oftentimes differences aren’t heard in the short-term but in the long-term. You can’t expect to fully grasp differences doing short bursts of comparison. When you get used to a piece of gear for a long period of time, the likelihood of you noticing differences when something new is plugged in is much much higher. I personally think of it this way. Why evaluate gear in the short-term when you listen to music for the long-term? Of course, those tests can be very useful but in the right context. As you hear more stuff, naturally you’ll hear those differences more quickly (assuming time and effort have been put).
Just to add, differences in source gear is also dependent on the product itself. A lot of budget stuff will likely sound very similar, for example. In the case of the RME, I wouldn’t be surprised if you didn’t hear a difference. Imo the RME, sound-wise, does not fully warrant its asking price (neither as a standalone DAC or as an AIO). I personally wouldn’t recommend it to anyone if sound is the main focus. If you use the other features consistently, then yeah I think it can be a great product.
In general terms, d8kp is the most similar to the 800s imo. Both are relatively forward in detail and energetic in the top-end. D8kp is more of a u-shaped can, while the 800s is more neutral and agile. That being said, d8kp offers much better bass extension, grip, and texture. Stage is also sharper with good width and depth, but not as big as the 800s. Bass is the d8kp’s strength with outstanding organicness, realism, and texture. Utopia is quite different. Exaggerated dynamics and holographicness are what make the utopia standout and unique imo. It’s an analytical can, yet quite smooth at the same time. Treble is also a standout and is very refined, extended, and controlled. Personally, I don’t think the utopia is the most natural but it will surely let you hear what’s within the recording. D8kp is relatively forgiving of source gear, while the utopia is NOT.
Using the HD800S as “coffee beans between different fragrances
That’s right. Stretchy analogy and small blog content. I’ll make this short though. :grin:
In the past weeks I have been spending big time with the FiiO FD7, a bassy and somewhat darker set. I’ve been very happy in my basshead season. But suddenly I started feeling the bass was no longer punching as it used to, even after doing a tip rolling and picking the punchiest eartip on my collection (AZLA – cough cough). WTF. What now?
Decided to take the HD800S from its case after some time. I knew I was going to miss the bass, but, whatever… :man_shrugging: Bass is my hedonistic flavour of the month but midrange is my devotion for life. :prayer_beads: :pray:
Spent 2 hours with the HD800S. Listened to a bunch of songs. Majority metal. :metal: I’m not a metalhead myself but the FD7 gave me that. Detail and layering are on pair between both – my perception.
There is nothing more refreshing than using a reference tuned headphone to “cleanse” your senses. Anyway, the FD7 is now as punchy as ever, and the soundstage and pinna excitement (a.k.a. short term tinnitus on my terms) are unbeatable on the HD800S though. :joy:
Cheers. :beers:
Pulled the trigger on HD800s on typical $1.4k sale (from Amazon given ease of return). Also have a Folkvangr inbound. So I shall have a lot of playing to do with Mjolnir 2, Folkvangr, Jotunheim, Yggy LIM, Gumby and Bifrost 2 to juggle around and compare and find what I love.
First of all - Hi!
This is my first post on the forum, but I have been reading all posts in this thread :slight_smile:
Back in September I purchased a Sennheiser HD 820 and the HDV 820 amp. I really love this combo, but for some reason I just have this idea, that I NEED a pair of HD 800S :hear_no_evil:
Anyway, going through the posts, I am convinced and I just placed an order for the 800S.
They should be arriving within 7-10 days, so by then I will hopefully know what the fuss is all about :smiley:
Love the way you put this!
Bold move. I love mine.
Why 2?
Hi Graham
Not sure I understand your question?
I’m semi-breaking balls (being a language twit). You refer to ordering a “pair” of HD 800’s phones. The “s” in phones suggest more than one (one or more cups), rendering the “pair” redundant.
Slow night on a Sunday. No offense meant.
Best wishes
Hi @Brose and welcome!!
I’m a big fan of the HD800S. It probably gets the most play time of all my headphones. (it’s just sooo good on tubes!!) I’ve never had issue with it sounding bright to me. Granted I’m older and my hearing is nonexistent over 13k …so there’s that.
So I’m curious to hear a comparison and comments when you get them because….
… this exactly how I feet about the 820!!
I’ve been fighting off getting them for awhile. I’m so curious about how they compare. If they offer something a bit different and are as great as the Hd800s I NEED them!:laughing:
You realize they’re 2 different models ? The HD800 and the HD800S…it’s not plural. :grin:
Hi @Audiophool and thank you for the warm welcome :slight_smile:
I’m really excited and look forward to trying them on for the first time! - I’m sure they are great and that they will be a perfect match with my HD / HDV 820 :crossed_fingers:t2:
I would love to give you an update once I have had the chance to compare them to the HD 820, but with the advanced and skilled reviews and comparisons in the official 820 thread, especially the one written by @Torq in post #19 (August 18) I am not sure there is much I can add with my limited head-fi knowledge :slight_smile:
@Brose don’t let the other reviews stop you from giving us your thoughts. Something you say about or see with the HD 800 S may make all the difference to someone reading what you write.
Mark Gosdin
Thanks @mgosdin - I’ll keep that in mind :slight_smile:
i concur with @mgosdin.
Be aware that @Torq likely has more headphone experience than…the rest of us put together…
We also all hear a little bit differently, and new people hear things with fresh ears.
+1 for trying the HD800S on tubes. I didn’t really like them until I heard them on tubes.
I never found them to be bright either but like @Audiophool I am over 50.
