This is a place to discuss all things Sony MDR-MV1.
Here are the measurements:
B&K 5128
GRAS
EQ Profile:
Sony MDR-MV1 Review:
B&K 5128
GRAS
EQ Profile:
thatās suprisingly decent at ~$300 in Japan atm, Iād be fine with it with just a high shelf.
Yeah the 6khz and up brightness does get to me with this one. Not hard to EQ though.
As tiresome as āHow does it compare toā¦ā questions are, I was expecting it to be compared to the RĆDE NTH100 since they seem substantially similar in most ways except price and open versus closed.
Obviously comparing the charts is subject to some significant systematic error.
PS. ¼" to ā " adapter. Sonyheiser?
Listened to Sony MDR-MV1 $400 today, no EQ. As expected and as with most Sony headphones, the experience was very enjoyable. Started by amplifying them from a Singxer SA-1. Moved to plugging into Quicksilver and RSA The Raptor reaping notable scaled improvement.
Next, I A/B compared to HifiMan Sundara, both with no EQ. The $300 Sundara spanked the $400 Sony.
Finally, I A/B compared to Sennheiser HD600, both with no EQ. The $300 HD600 also spanked the $400 Sony.
While the highs are prominent in the Sony MDR-MV1, they are comparatively unrefined next to the treble reproduced from either of the two legendary established headphones in the mix. Unfortunately, this contributed to a narrowing of the perceived sound stage and a reduced sense of envelopment compared to its counterparts. I donāt know if or how my opinion might change once I get around to equalization.
Sony MDR-MV1 sounds great and is a keeper for me. However, at the moment I am finding it hard to justify Sonyās $400 price tag when there are $300 headphones able to bring a greater amount of sweet sounding joy to my ears.
I just impulsively bought the MDR-MV1 yesterday and got it today. I also bought this cheap 4.4mm cable (https://www.amazon.com/dp/B0C3C242T9) and it seems to work just great with my DAP.
I was a little concerned with the treble peak, but Iāve tried to put on some of my brightest test tracks and I havenāt been bothered by it at all. Itās clearly more defined in the treble range, but not sibilant or harsh for my ears. I tried tracks from Norah Jones, Fleetwood Mac, Rhianna, and some EDM stuff and it didnāt bother me.
The bass is quite big for an open-back and I was surprised to hear good subbass quantity on this headphone.
My favorite part is just how amazingly light and comfortable these are! Itās 220 grams and suede pads! oh man. I wish all my headphones were this light and comfy! It is even more comfortable than my beloved HD600, and much lighter than my Susvara!
Anyway, not a huge fan of the build quality, but if you wanna make it light, you gotta compromise here and there. The āProfessionalā stickers are also not aligned very well, but I may end up taking those off I decide to keep these (which it seems I willā¦)
Obligatory graphs I measured tonight: Audio Discourse - Headphones Graph Database
Hereās some select comparisons:
I have had the MDR-MV1 for about a week now and I am still surprised I am enjoying them so much. They are just tuned nicely balanced and are comfortable as all I can be. I guess, because, Iāve been wearing them so long during the work-week that I do find the pads can get a little warm due to the material after a bit of use. I did try the Brainwavz Leather pads on these and they kind of ruined the mid-range a bit, and increased bass levels. Itās more V-Shaped, although it does help with comfort even more!
The Sony MDR-MV1 is the newest and one of the very few open-back headphones in this well-known brandās collection of audio gears. The MDR-MV1 retails for approximately $399 and I happened to impulsively buy this recently and now will tell you why I like it so much!
The MDR-MV1 is super lightweight. It reminds me quite a bit of some of the low-end Audio-Technica open-back headphones in terms of lightweight and construction. It has an aluminum perforated outer cup design, and plastic yokes. The headband is very reminiscent of other Sony monitor headphones with their staple red and blue R/L indicators on each side.
The total weight of this headphone is 222 grams, making it ultra-light and awesome to wear. The micro-suede pads add to the overall comfort of wearing these headphones and making them easily wearable for many, many hours. And thatās a good thing, because this thing keeps staying on my head for some reason.
The cable plugs into the left cup and is a standard 3.5mm cable. The included cable has a TRSS 4-pole connector into the cup, but a standard TRS 3-pole 3.5mm stereo jack also works fine. The included cable terminates into a 6.35 mm (1/4 inch) jack, but it also comes with a 3.5mm pigtail adapter to make it work with a multitude of sources. For me, I actually ended up buying a 3.5mm TRSS to 4.4mm balanced cable that I primarily use with my sources.
The MDR-MV1 has a very balanced tonality that borders upon the V-Shaped sound signature that you could find in other Sony consumer headphones. It does not quite steer all the way there, but itās an aggressive U-Shape (which I prefer).
The bass range is lifted quite high for being an open-back. In fact, I donāt know of many open-backs that has the amount of sub-bass and mid-bass quantity that this MDR-MV1 has, and thatās the most impressive thing about this headphone. While its not as resolving and textured as the Hifiman Susvara, it does more than an adequate job for putting good presence to bass guitars and drum kicks. I really enjoy having a more fuller bass response than my other headphones can provide here.
The mid-range has a slightly recessed tuning, much like what youād expect from listening to a Hifiman, Audeze, or something like the Sennheiser HD800S, and differs quite a bit from the Sennheiser HD600 and HD650 headphones which I find as a standard for this price point. The HD600 series is very mid-focused with great timbre and pushes this mid-range and vocals fairly foward. The MV1 takes a different approach, and has it set just a bit further back, and some may find this timbre to be a little off, but I really enjoy the more distant stage.
Deep male vocals such as The Nationalās Matt Berninger come in with full grit and deep undertones thanks for the elevated bass range, and this is one of the few open-back headphones I enjoy rock music with ā something that only more recently, the ZMF Atrium has provided, and the semi-open back emu/Fostex headphones give.
The added treble does sometimes make female vocals sound a little thin, but male vocals are quite rich to counter it. That treble peak in the graph is scary-looking, and it gave me quite a pause for weeks as I decided whether to give this tempting headphone a shot. In the end, I donāt find it a problem at all. No sibilance in even the worst tracks I tried ā stuff like Rhianna and Norah Jones. In fact, I donāt find this headphone fatiguing at all, and I listen to it for hours on end without pause, and main with female vocals and strings ā things where too much treble can sizzle and give headaches easily.
The soundstage of the Sony MDR-MV1 is a little bit more big and open than a traditional studio headphone, and larger than the HD600, which is more intimate in presentation. While itās not as large as say the Sennheiser HD800S or most of the Hifiman headphones, it falls somewhere in the middle.
The Sony MDR-MV1 is a headphone that keeps staying on my head, and is quickly becoming the one I reach out for despite owning the legendary Sennheiser HD600 and Hifiman Susvara, which both sit next to it on the headphone stands. I continue to grab the MV1 because itās the most comfortable headphone Iāve worn, and it has a very balanced and suitable tuning that works so well with rock music primarily, but is also well-suited for any genre really.
This one has well-exceeded my expectations, and Iām very happy my impulses got the better of me.
I really like these, especially compared to the HD650, which Iāve never enjoyed due to their lack of bass and narrow soundstage. These are also a bit more comfortable, lighter and with less clamping force.
I still prefer my planar headphones overall but I wanted a single dynamic pair where I could actually feel the sub-bass. The last headphones that managed that were the Fidelio X2 and despite all their flaws, I genuinely liked those.
These are currently listed on Amazon.com as a Limited Time Deal of $330
Amazon.com: Sony MDR-MV1 Open Back Reference Monitor Headphones : Electronics
So⦠yeah I ordered a pair. Gonna do the Headphones.com EQ Challenge!
Iāve been skeptical of EQ for some time. I have had one real success story so far with EQ. Found a set of EQ settings for the Sony MDR-Z!R that are pretty extensive. They are parametric EQ values that I plug into PGGB, and they work amazingly well. I would put the Z1R up against any headphone with these EQ settings. (They are posted elsewhere on this site).
Iām still working thru EQ settings for other offerings in my collection.
Decided to try these out. Here are my thoughts. My primary reference point will be my EQād HD650.
Non-Sound
Doesnāt seem to have as much room in the ear cups as the HD650, so I can feel my left ear making contact
Clamp force is higher than my aged HD650s
Incredibly light. Clearly designed to be worn for hours at a time
Cable is slightly microphonic. Moreso than my aftermarket openheart cable I use on my HD650. Not bad for a stock cable, though.
Cable has a neat screw-in design on the part that goes into the headphone. I havenāt seen that before.
Requires very little power to reach adequate volumes. I can use my Midgard at low gain with a preamp cut for EQ and still have most of the volume knob left.
Headband isnāt great. Probably one of the worst Iāve felt on a headphone in a while.
Sound (no EQ)
V-shaped. VERY V-shaped. Lots of bass, dipped midrange, and extra energy around 6-8k.
The overall sound signature is close to something like a Fiio FT1. This is not a good thing, IMO.
Voices have a lot of extra bite and sibilance
I didnāt know an open back dynamic could have bass like this. Itās basically similar to a lot of the closed backs Iāve heard.
While thereās obviously a lot of bass, I wouldnāt call it particularly well-articulated. It has a bit of that muddy effect that you get in bassy closed-backs. This is definitely not the āplanar bassā that people love from HiFiman, Audeze, etc.
Perceived instrumental separation is better on the HD650.
Thereās an overall lack of clarity across the entire frequency range that can make things sound diffuse and hard to differentiate.
Doesnāt have the magical midrange that the HD650 has, so voices never sound quite as natural.
Sound (with EQ)
EQ is absolutely required to smooth over the response, primarily reducing the aforementioned bass and treble boosts to more reasonable levels
Oratoryās EQ does a pretty job out of the box with this. He basically goes after the same areas I did when I did tone sweeps. Bit shouty, but I say that about basically all his profiles.
The headphone takes EQ very well. Some headphones, like the HD6XX series, donāt, but the MV1 will take any change you throw at it like a champ.
There are three primary issues that need correcting, IMO
Bass: Thereās too much for my tastes. I use Oratoryās bass correction filters with the shelf at 105hz set to 1.5. This gives a tasteful amount of low-end without overwhelming the midrange
Midrange: The mids on the MV1 are a bit recessed when compared to something like an HD6XX (but what isnāt, amirite?), so I add a bit around 1500 and 2000hz.
Treble: I hear the peaks around 6000-7000. I lower these areas by a few dB
Even after EQ, it still doesnāt have the natural midrange or overall balanced character that you get with the 6XX. Guitars and vocals never sound quite right. It beats the 6XX in low end, but thatās not much of an accomplishment. Maybe I need to spend more time refining my filters, but Iāve tried multiple approaches and nothing gets it quite where I would want it.
On a more positive note, they work really well for heavy metal, especially classic stuff from the 80s. Slayer sounded particularly good, for example.
Final Thoughts
Overall, the MV1 is not great in stock form, but can become somewhat compelling after some EQ work. This would be fine if we were talking about a $200 headphone, but unfortunately the MV1 retails at double that, which makes it far less worthwhile. If someone wanted something like the MV1, Iād point them to the Fiio FT1 at less than half the price. Yes, itās a close back that weighs a bit more, but the value is unmatched. Itās also more comfortable and has pad swaps available for tuning beyond just using EQ if youāre so inclined.
Referencing the Headphone Showās rankings, Iād say the MV1 in stock form is D-tier, with EQ is B-tier, but either way you can get better headphones for a lot less money.
Hello. So Iām new here. And somewhat new to audio and all the terms involved.
I was looking at a couple of different headphones, and kinda landed on these. Worst case scenario is that I send them
back I guess.
After that I ordered I kind of realized that the headphones have a extremely long cable and my audio interface is on the table next to me.
so I started to look into it, and apparently its a 3.5mm TRSS cable that screws into the headphone that then goes to a 6.35MM(TRS)
So that didnt make much sense to me. What cable should I look for? Will any 3.5mm TRS work? my audio interface uses a 6.35mm jack and is not balanced(obviously)
It would be the easiest if whatever cable I get is available in europe atleast, or perhaps china.
saw a couple cables that were customly made for the model, but it would end up being expensive having it sent over here.
Last question on my mind was that I saw the 2026 Headphone SHOW Tier list.
and the hosts kinda praised it (atleast with some EQ) It sounded like he was refering to a certain filter
Its possible that it was made my himself. but im wondering what programs you use to EQ usually, and what the EQ they were speaking of
might have been.
Thanks.
I bought a Hart Audio Cable for mine. You lose the locking mechanism, but otherwise this works and you can choose your termination or go with their modular system that lets you swap: CST-HC-2-MDR: Custom 3.5mm TRRS cable for Sony MDR-M1, MV1 headphones ā Hart Audio Cables
A cheaper alternative than buying a replacement cable is to use a cable organizer like this:
Alright, thanks for the responses. Im not sure about having something like that on my desk.
Will probably get a RPL-HC-2-MDR or the one you mentioned. CST-HC-2-MDR.
the price is somewhat similar. not sure if theres a different quality or feel to them, or if theyre about the same.
Recently got these and Iām not getting why theyāre so praised. I think I know why theyāre marked as a frequently returned item on Amazon.
The vocals on a lot of tracks is so far back, they almost sound recessed. On these tracks, the V shape just drowns out a ton of the detail.
Am I donāt something wrong here? I read they donāt need a dac/amp to sound good and running them off a high end motherboard where other headphones sound better than these for half the price.
Itās unlikely youād get any improvement running them from a dedicated dac/amp, at least not the kind that would shift your preference towards them. People - at least in our circles - love these headphones not for their default sound quality but for their comfort and as EQ platforms. These are some of the easiest headphones to EQ available. I think by default I also rated them a C, or something like that.
Iām an idiot. I plugged the cable into the headphone and only gave the connector a few spins and didnāt tighten it all the way. Iām guessing the connector wasnāt seated properly and not getting good enough contact. The bass got a lot punchier and it sounds good now after tightening it up firmly.
Iām wondering if this is why people return them, as they sound great now. There was a review on Amazon where some guy said changing to a silver cable magically made them much better, but Iām guessing he did something similar to me and replacement cable gave him a better seated connection.
Hahah it happens. And yeah changing the cable on these wonāt change the sound, provided itās locked in correctly.
