This small binaural microphone sits inside the ear’s concha and can be used to measure headphone response on real human heads. The microphone only partially obscures the ear canal.
The mic is sold in regular and high sensitivity variants. I’m using the regular sensitivity one and it seems to work fine.
I tried running the mic through a cheap USB mic adapter and that didn’t work very well. The mic needs some plugin power (low voltage phantom current) and I think that adapter wasn’t giving it enough juice. I’m now running it into a Zoom H1N and that’s working much better, not least because the H1N has a preamp with adjustable gain.
This makes the HD58X look warmer, slightly bassier and darker than the HE4XX, all of which agrees with my hearing.
The HE4XX has noticeably more 8.5 KHz than the HD58X, which agrees with other measurements I’ve seen
There’s no weird 4 Khz dip like on my MiniDSP E.A.R.S.
You don’t see the boosted 1-5 KHz region that you see on HATS, I think because that’s mostly ear canal gain which doesn’t come into play here.
There’s a big dip at 6700 KHz, which is the center point of concha gain. The mic sits in my concha, so it makes sense that I’m not benefiting from concha gain, but this is even worse because it’s dipped. Adding some EQ boost at 6700 KHz does (tentatively) seem to make stuff sound clearer/less grainy for me, so perhaps part of this feature is actually my own ear shape. I’ll have to do some more experimentation with my other ear and maybe my wife if she’ll play ball to see how much of this feature is me and how much of it is the mic.
Both headphones look even more severely rolled off in the bass than what my E.A.R.S. and other people’s measurements show. I took these measurements wearing rather thick glasses and, unlike the E.A.R.S., I’ve got hair, so the roll off seems plausible.
It looks like this thing might be useful for CSD waterfalls too. It shows that the HE4XX has some undamped resonances that the HD58X doesn’t, which agrees with measurements I’ve seen at https://diyaudioheaven.wordpress.com/.
So, to get a better calibration, I measured the output from my room-corrected studio monitors (JBL LSR305 plus Rockville APM10b subwoofer) by measuring with the mic outside my ear and also in my ear, yielding the following:
It’s not quite optimal (lots of squiggles even after doing psychoacoustic smoothing), but it does show that there is a bit of ear gain in the 1-5 KHz region. Interestingly, it also shows that there’s some loss around 6-7 KHz, perhaps because of some interaction between my concha and the mic(?)
Turning the in-ear LSR305 measurement into a target curve, I’m able to EQ the HE4XX against this, yielding …
IIRC, @Mad_Economist suggested placing the microphone into an occluded ear canal, so I took the capsule from the Sound Professionals mic and placed it into a spare Symbio W medium tip that I had around. It’s not all the way into my ear canal, but pretty close.
Intuitively this mostly makes sense, a very even response from 100 Hz to 10,000 Hz, with a bit of gain from the outer ear in the 1-5 KHz range, and pretty bad roll off at the extremes. The ear gain (even accounting for the lack of ear canal gain) does seem surprisingly low though.
While I don’t have a HD58X on-hand to measure, I do have a HD600, and that seems congruent with my results. A measurement with a recent blocked meatus microphone prototype I have made (using a truly fiddly 3mm condenser) vs. the ear simulator in my HATS (uncompensated, of course).
Well, low-frequency rolloff aside, but such low frequencies aren’t meaningfully impacted by probe positioning - even the outer concha placement would be suitable for such measurements - that’s just the capsule and phantom power adapter I’m using.
Glad to see more folks looking at blocked canal! From my data, it seems to cohere pretty well with ear sim measurements on a wide range of headphones, and compensation using Hammershøi & Møller’s blocked canal population averaged HRTFs has been relatively accurate in my experience.
I’m looking to purchase the newer version out your binaural mic which has higher sensitivity and lower self noise but is pricier. Looks to have silicon tips that already do the ear canal occlusion
See the above linked paper by Hammershøi & Møller - with a non-occluding probe variation tends to be higher, both because the probe tends to vary in its position, and because it is typically partially occluding rather than being fully acoustically insignificant, giving it another vector to cause variations.
The new Sound Professionals mic may be suitable, although it likely does not fit close enough to the ear canal. You want to be under 6mm (1/4" or so) from the canal entrance for the furthest protruding part of the mic capsule.
Hi @pwjazz gonna revive this 4 years later… But I just read about Mitchco’s headphone measurements, and while searching for the mic, saw your posts. So I bought the same mic. I do room calibration for speakers. So I thought about doing exactly what you tried. Sitting in front of a speaker (Which I EQd to sound natural in the listening window on the spot), then measuring both speaker and headphones with these mics on my ear. And compare the frequency responses.
