The CCA CST is a new single dynamic IEM from the sister company of KZ. It features a 10mm driver with a double magnetic circuit. It has a fixed cable and is constructed from wood and metal, and is the first single dynamic model from CCA. The diaphragm material is not specified.
The CST comes packaged in a very small, flat, white rectangular box. There is a colour image of the IEMs on the front and brief specifications on the back. The IEMs are packed in a plastic tray with the documentation and two pairs of Starline tips (S, L). The medium size tips are pre-fitted on the earphones.
The earpieces have a body made of a light-coloured wood. There is a gold-coloured metal trim on each end and a large vented grille on the rear but there is no branding or channel identification. The angled nozzle emerges from a domed cap with a prominent lip to secure the tip and there is a small circular pinhole vent near the base. The IEMs are reminiscent of the VJJB K4S which are also made from wood and metal. They are light in weight and very comfortable. The cable is rubbery and is terminated in a 90° angled plastic 3.5mm plug. There is some cable noise.
Testing was performed using an Xduoo X20 DAP and a burn in period of 100 hours was carried out. The pre-fitted tips were used and although I did not obtain a perfect seal, after experimenting with various other tips the medium Starlines proved to be the best compromise.
First Impressions
The CST displayed a warm, well-balanced U-shaped profile which was very easy to listen to. The lower frequencies were elevated with strong sub-bass, a prominent mid-bass and some bleed into the mids. The mids themselves were a little recessed and warm in the lower region but possessed good timbre. The upper mids were brighter and more forward and this trend continued into the treble which was above the mids in level, but not above the bass and with only a slight trace of harshness. Detail retrieval was good but the transients were a little soft. The soundstage was one of the best features, being wide, deep and spacious with a good impression of height. This was probably due to the vented rear of the earpieces. Overall this relaxed and natural presentation was very impressive at the price.
The CST’s bass was forward and powerful, warm in tonality and a little soft in attack with the emphasis in the mid bass and a good sense of weight. The sub-bass did roll off somewhat with the lowest frequencies lacking definition. The texture was good and there was a good reproduction of recorded ambience.
Jennifer Galatis’s soundtrack “Io” features an arsenal of keyboards. “Interstellar Voyage” begins with an anthemic theme in synth strings supported by deep sub-bass tones. These displayed good texture on the CST but due to the limited extension, they lacked some impact. Where the mid-bass took centre stage, the effect was very satisfying.
Mark Dwane’s series of albums on mystical themes performed on MIDI guitar are always very well recorded and produced. “Siren’s Song” from “Archives 2” is based on a fast-moving sub-bass riff with wordless female vocals and electronic effects. The bass notes possessed good texture and reasonable impact but did merge together a little with some lack of definition due to the blunted transients. This is a severe test and to be honest, the CST did do fairly well considering the price.
Mids
The midrange was somewhat recessed, but still retained some presence. The lower mids were less prominent than the upper mids which were brighter.
Benny Andersson’s solo album “Piano” features his own compositions. The beautiful “Jag Hor” received a measured performance from the CST. In the quiet passages it sounded great with good clarity and definition but in the more powerful sections the dynamic range was a little squashed and the atmosphere of the recording venue rather flat. Occasionally there was a strident tonality in the climaxes with a thin note quality.
Pachelbel’s famous “Canon in D major” performed by the JF Paillard Orchestra also came over very clearly with the divided string sections well defined and the harpsichord continuo clearly audible. Once more, however, in the more lively passages the timbre of the strings became less natural with a slightly sharp edge and there was some clouding of detail.
Treble
The CST’s treble was largely well defined, especially in less complex tracks and at low volume. In more energetic pieces the separation did suffer a little and the tonality became brighter and less defined. However, detail retrieval was very good in general.
“Pyramid” from “Behind the Gardens” by Andreas Vollenweider showcases his trademark electric harp and complex percussion arrangements. The high notes of the harp were clear and the complex percussion accompaniment bright and well textured. Towards the conclusion there are multiple cymbals playing and there was some splashiness and merging of detail in the loudest sections.
The BBC Philharmonic’s version of Hubert Clifford’s “Kentish Suite” is a fine Chandos recording. Part 5, “Greenwich” brings to bear the full orchestra in a dynamic performance with prominent strings, brass and percussion. There was plenty of verve and attack on the CST and the layout of the orchestra was nicely portrayed. The brass and percussion did tend to dominate, being just a little too bright and forward, affecting the balance and the violins displayed a slightly thin timbre in the loudest passages. The slow movement “Pastoral” on the other hand, was more to the CST’s liking with the woodwind solo floating over the harp and string accompaniment in a most attractive way whilst displaying a more natural tonality.
Soundstage
The CST displayed a large, spacious stage with good imaging, layering and separation. The sense of space was well rendered enabling the ambience of a recording venue to be heard clearly. In dynamic and complex passages the staging became flatter and there was some merging of detail.
Vangelis’s “Elsewhere” from his album “Direct” begins with an electronic percussion elementcircling from left to right which is joined by another from right to left which weave in and out in a figure of eight. This was very well reproduced by the CST. A solo voice high in the centre plays the main theme and the climax was very well handled with the full range of keyboards at Vangelis’s disposal excitingly presented. The CST was very impressive in this piece.
Malcolm Arnold’s wonderful “Cornish Dance No. 3”, in a classic Lyrita recording with the LPO and the composer on the rostrum, produced an expansive staging on the CST with the bass drum foundation, brass fanfares and a bright incisive tambourine cameo all combining to produce a thrilling performance. The ambience of the concert hall was particularly well reproduced. There was just a hint of splashiness in the cymbal crashes in the climax.
I have chosen some dynamic drive IEMs with a fixed cable at a similar price to the CST for comparison.
KZ ED9
At a current price of around £14 the ED9 still holds its own in this sector with its two tuning options. With the gold nozzle it sounds similar to the CST with a powerful bass and a strong V signature but loses out in detail and refinement. The brass nozzle gives a more neutral and transparent sound with better detail and staging which is exceptional at the price. The vented rear endows the stage with a spacious quality.
Cambridge SE1
The SE1 started out with a list price of around £70 but appeared on Amazon recently at a bargain price of £20. It is a bullet-shaped IEM with an 8mm dynamic driver featuring a beryllium plated diaphragm. The earpieces are crafted from aluminium and there is a fixed cable. It has a powerful and punchy bass, smooth well-resolved mids and a clean treble. It improves on the CST with superior transients and better separation. The overall profile is U shaped but mids are more prominent than the CST. Treble is smoother and more refined but with no loss of detail.
Lindy Cromo IEM-75
Another Amazon bargain, this too had an original price of £70 but was reduced to £12.99. It is a dual-drive IEM with a 15mm bass unit and 7mm tweeter, a metal body and again, a fixed cable. Bass from the large driver goes very deep and is effortless. Mids are somewhat less forward than the CST and the treble rolls off earlier so the overall sound is fairly dark producing an L-shape profile, but it is very smooth and engaging. It does lose a little in detail to the CST but does not suffer from compression or splashiness.
On the front of the box the description includes the words “natural sound” and I would not disagree with this. In general the CST presented music in an entertaining, unforced and attractive fashion with the only negatives being a somewhat thin tonality in the treble and a lack of definition in complex or dynamic pieces at loud volumes. It is well made, looks good and has a well balanced sound quality. If you don’t mind a fixed cable and you have a limited budget, it may well be suitable.
The CVJ CSE is a new 1DD + 1BA hybrid IEM from the company. Like the previous CSA, it is an affordable model. It employs a silicon crystal composite biological diaphragm dynamic driver 10mm in diameter covering the bass and a customised 30095 BA, placed within the nozzle, for the treble region.
In a departure from their previous packaging, the CSE comes in a small black rectangular box with a sleeve featuring a colour image of the IEMs on the front and the specifications printed on the back. The box has a gold CVJ logo and, inside, the earpieces are presented in a card cutout along with the spare eartips (the medium size being pre-fitted to the IEMs). Below this are stored the suede effect pouch, the detachable cable and the documentation.
The faceplates are fashioned from a clear green resin with a wave-like embossed surface and there is a clear amber body through which the components can be seen. There is a small circular vent on the inner surface for the dynamic driver and a gold nozzle with a silver grille. The 2-pin socket for the detachable cable is set flush.
The cable is a black tightly braided 4-core type with a straight metal 3.5mm plug and angled connectors and is similar to those supplied by TRN. There is no chin slider. The earhooks are quite stiff and could usefully be more supple for a better fit.
The CSE was tested principally using an Xduoo X20 DAP. A smartphone and a CD player were also used. The earphones were subjected to a burn in time of 100 hours to settle down the components. The stock cable and tips were used and a good seal and isolation were obtained.
First Impressions
CVJ’s earphones, starting with the CSA, have established a “house sound” which is refreshingly different from the sea of V-shaped offerings from the majority of Chi-fi companies, being more neutral/bright and displaying a more mature tuning. The CSN and CS8 followed this philosophy but the CSE is a little more V-shaped and a touch warmer in tonality. The bass was well textured and deep with good impact, the mids were mildly recessed but had good timbre and the treble was generally smooth with good levels of detail. There was adequate volume even from lower-powered devices and no need for additional amplification.
The bass was elevated with the emphasis between the sub and mid bass. The tonality was warm and engaging with good impact and reasonable speed. There was a small amount of bleed into the mids and the bass did dominate on certain material.
Jeff Wayne’s superb production in David Essex’s “Rock On” showcases double tracked bass guitars which effortlessly plumb the nether regions of the frequency spectrum. Partnered by staccato string elements, the bass remained clean and incisive and created a powerful and weighty foundation.
The characterful bass line in “Hazard” by Richard Marx displayed excellent depth and texture and was clearly defined against the accompanying bass drum. This rhythm section drove the piece along in great style, providing a solid basis for the instruments and vocals.
Mids
The CSE’s mids were somewhat recessed but due to the clarity and detail on offer, still showed good presence. Timbre generally was quite natural. The upper mids were slightly cooler in tone and perhaps a little less convincing.
Debussy’s “Claire de Lune” received a wonderful reading from Ikuyo Nakamichi in a superb 20 bit K2 recording. The CSE gave a very good reproduction of the solo piano with an accurate and realistic portrayal of the decay, undertones and harmonics which create a natural timbre. In the climaxes the tonality was clean and crisp with fast transients and good separation in the rapid arpeggios and with only a moderate increase in sharpness in the high notes.
“I know a Rose Tree” by Secret Garden is based on a melody by the mediaeval German composer Michael Praetorius. Fionnula Sherry’s violin solos and the Irish choir Anuna, supported by orchestral accompaniment, delivered a beautiful and sensitive rendition of this work and the CSE produced a well defined picture of it, with nicely layered vocals and harmonies and the diction preserved well.
Treble
The treble was largely clean and free from peaks. There was an emphasis in the lower treble and a further elevated region in the upper treble which added detail and sparkle, only occasionally resulting in sharpness or less natural tonality.
Bach’s famous Toccata and Fugue in D minor performed by Helmut Walcha in a vintage 1960s recording, sounded great. Very different from the Gothic and Romantic French and British instruments, the clarity and brightness of the Silbermann organ was excitingly and dramatically portrayed with immediacy and impact. The details in the faster passages retained their separation and the tonality was generally clean, with only the more energetic sections sometimes a little over-bright or edgy.
“I Robot” by the Alan Parsons Project is the title track from the album of the same name. Following an introduction with a sequenced synth riff and electric guitars, the distinctive metallic sound of the Cimbalon enters and it was reproduced cleanly and brightly, with good rhythmic integrity and clarity. The layering of the different elements was very precise. This was perfect material for the CSE and was very enjoyable.
Soundstage
The CVJ presented a spacious image with good width and height but a little less depth. There was a good sense of natural ambience. Imaging was good and separation and layering competent. This was a very good performance at the price.
The “Benedictus” from “The Armed Man” by Karl Jenkins sounded very believable. The solo violin set against the string accompaniment, the divided female vocals and their positioning were all depicted authentically within an airy acoustic space. The climax “Hosanna in Excelsis” with bass drum and full choir was handled very well.
The bright tones of Catrin Finch’s harp in “Clear Sky” from the album “Tides” were precisely placed high in the centre of the image with the orchestral accompaniment occupying the rest of the stage. When the more dynamic passages were playing and the full orchestra was present, the stage did become crowded leading to a reduction in separation and the tonality became brighter and sharper.
I have compared the CSE with dual hybrids in the same price range.
KBEAR KS2
The KS2 is a classic V-shaped IEM with an appealing dynamic and exciting character. It has a powerful bass approaching basshead levels and an expansive soundstage. However, the mids are recessed, there is some bass bleed and the treble lacks refinement compared to the CSE, occasionally being a bit harsh in the lower treble region. The CSE is better balanced and does not have such a deep V signature.
CVJ CSA
CVJ’s debut product offers something different and is neutral/bright with a solid well-textured bass, slightly forward mids, and a clean treble with good extension and detail. The sound is immediate and more balanced than expected and is a mature tuning not normally found at this price level. The CSE has a more V-shaped profile with a more elevated bass and is not as bright in the treble, and the mids are just a little more recessed but still posess good presence and a very natural timbre.
TRN M10
The M10 employs an 8mm micro driver for the bass and the familiar 30095 treble BA unit. The overall sound is mildly V or W-shaped but still retains good balance. The bullet-shaped earpieces, which are nicely crafted from metal, are worn cable down and are very comfortable. The lower region goes very deep and is warm like the CSE but just a little looser and the mids are a little bit more recessed. The treble is not as extended or as smooth as the CSE, and the soundstage is not as large.
The CSE diverges somewhat from the CVJ “house sound” by being more V-shaped than neutral as seen in their previous IEMs. It does retain some of the qualities of the earlier models but adds to this a more prominent bass and treble, in a compromise between their usual tuning and the popular sound profile normally found in this price sector. It is a solid performer and does most things well but lacks the individuality of the CSA which offers something different with its more mature neutral presentation. Even so, the CSE is still a very good choice and should be on your shortlist.
Not exactly ultra-cheap but still well below $100, has Anyone tried the Moondrop Aria 2 yet? From some places I’ve heard it’s sounds as good as Starfield.
The TRN TA1 were sent to me with a discount by LuckLZ Audio Store. As always, I will be as sincere and unbiased as possible but I like to be clear on the origin of the items I review. To see the link to both the LuckLZ sore and the TA1, please visit the review on my blog here: Review - TRN TA1
Intro…
The TA1 are the latest TRN release, as far as I am aware, and feature a Knowles 33518 BA driver and an 8mm dual core dynamic driver. They are currently available for around 30€ which is well inside the sub 50€ bracket I set on the blog.
There is a lot of competition in this price bracket lately but the TA1 seem to offer good specs, at least on paper, with the Knowles driver that should assist in avoiding some of that high end roll off that is present on a lot of the similar priced offerings, most of which are single DD.
The IEMs are delivered in a simple box with an image of the product on the cover of the cardboard sleeve, the model number and not much else on the outside. Personally I have received what seems to be classed as the Japanese version, which seems to only differ in the design on the IEM shell, sporting a anime face rather than the TRN logo.
Inside the box we get the IEMs, a more than acceptable cable, various sets of silicone tips and a set of very soft memory foam tips. I tried the various tips included, along with a few more, and came to the conclusion that I really like the included foam tips.
The IEMs use a metal shell, in a shiny silver finish , which they state is a Magnesium-Alloy housing. The shape of these IEMs reminds me of the original Tin T2. The IEMs can be worn cable up or down, however, the included cable is shaped to wear cable up. I mention this because, for some reason, the anime face on the IEMs is orientated for cable down, meaning that it is upside down when used with the included cable. This is something that I really don’t care about but thought it was strange.
The IEMs do portray themselves as well built, looking quite good also. I was a fan of the T2 and this is sort of a shiny version of it.
As far as comfort, they are very comfortable IEMs, although the cables do seem to stick out further from the ear than usual.
The interesting part is obviously the sound and I am a fan of DD for bass with BA for the highs, depending obviously on how much of that metallic “BA tone” is present.
Starting off, as is usual, with the subbass, there is a decent amount of presence down into the lower rumbling areas. The bass is also very well controlled and doesn’t give me a sensation of being bloated or overly boosted. Songs like “Way Down Deep” by Jennifer Warnes or “Royals” by Lorde have a nice and smooth subbass, with everything being present but without being in your face.
In the general bass frequencies, there is again a nice smoothness and control to the bass lines and hits, even if there is a bit of a boost to them. The IEMs have a clear V shape tuning to them but the driver does a good job of keeping the bass in check, not becoming overly present, at least in my opinion. The timbre of the bass is also decent, with instruments sounding realistic in their lower ranges. Songs such as “No Sanctuary Here” by Marian Herzon feat. Chris Jones sounds very well laid out and the bass, which can become easily overpowering, doesn’t get in the way of other instruments of the track.
Moving into the mid range, for a V shaped tuning, these actually deal with the transition pretty well, however, the large dip around 1k does take some of the presence away in the center mids. This results in a midrange that is also very smooth, with no harshness introduced in the higher mids. Depending on the choice of music, the mids can be a little too absent for my liking and while acoustic guitars can sound decent, there are songs on which they are missing a little too much around that 1k mark. As an example, the guitar in “Billie Jean” by The Civil Wars is missing some presence in the center of the mids to be considered natural, it has more of an emphasis on the lower end of the guitar. This is by no means a terrible sound signature in the mids, it is very smooth and relaxing, I just would not consider it to be natural.
Although the mids can lack a little presence, it is nice to see that the boosted low end doesn’t interfere too much and doesn’t overshadow the mids. There are times, with other IEMs, where the mids sound ok until we get to a bass heavy track that just overpowers everything, I don’t find it to be the case with the TRN TA1. I keep repeating the word “smooth” but it really is the best word to describe these IEMs all the way from the lowest frequencies up until we start to reach into the treble area.
Speaking of treble, here is where the TA1 aren’t quite what I expected. Due to them being a hybrid set, I expected the BA driver to be a little clearer and more extended in the higher ranges. However, it is the treble that is not quite right on the TA1. The roll off in the treble happens earlier than I would like and at the same time, the treble is not open and clean. This adds more to the effect of the smoothness I keep referring to, as there really isn’t much brightness in the treble range. This also creates a sensation where the treble seems to be slightly veiled and details are not as present as they are in the lower and mid ranges.
I am not saying that these have terrible treble, they are certainly not harsh and uncomfortable, I just feel that more openness and better clarity would turn these IEMs into something that is great rather than decent.
The detail overall is good, except for in the higher regions, and the DD driver does a great job of controlling the low end, without getting stressed under pressure. If only it had that bit of extra clarity up top.
As far as soundstage, the width is around average, certainly not above average, but inside the width they work with, the location and placement of images is well done. Songs like “Letter” and “Bubbles”, both by Yosi Horikawa, are a fun listen and the location of the images in the latter is fun, there are just not quite as many details as I would usually hope for.
When I first started listening to the TRN TA1, I found them very enjoyable and, to be honest, I still do. I really like the lows and the mids, they are presented in a smooth way that never becomes overpowering. The treble is the part that lets it down a little, making it seem like there is much less detail than there is.
As a BGM earphone, they do a good job and I have enjoyed using them for general listening purposes, just hitting play on Tidal or Spotify and letting random songs play. It is when I sit down to analyze the sound that I start to see the issues.
To be totally frank, if you are looking for a set of IEMs that look good and present music in a nice and relaxed fashion, then I think that the TA1 are a very worthy option, it is only if you sit down to dissect the music that you will start to notice that high end roll off and lack of clarity.
For 30€, there are many options at the moment and none of them are perfect, I think all of the IEMs I have reviewed at this price point have one issue or another, it is just a case of choosing the sound signature that suits you.
I have been testing the new CCA CSN hybrid IEM.
This product was supplied for review by Denise of IZ POP at Amazon.com. Product link:
Here is my opinion of it:
The CCA CSN (not to be confused with the similarly named model from CVJ) is the latest in a recent batch of releases from CCA. It is a dual-driver hybrid (1DD + 1BA), the first such design from the company since the CA4. It employs a 10mm dual magnetic dynamic driver for the bass and a “customised” version of the venerable 30095 BA unit covering the upper frequencies, which is is not placed in the nozzle. Based on images online it appears that the DD unit is the KZ XUN design. The quoted impedance is 22.5 Ohms with a sensitivity of 112dB.
The CSN is presented in a small white box similar to those from KZ, TRN, etc., with a colour image of the IEMs on the front of a removable sleeve and some specifications printed on the back. Inside, the earphones are displayed in a cardboard cut-out, and underneath the card are the spare eartips, the 2-pin cable and documentation.
The contents comprise:
CCA CSN IEMs (1 pair medium tips pre-fitted)
Silver plated 2-pin cable with QDC connectors
Spare white silicone eartips (S, M, L)
Documentation
The IEMs have a silver-coloured zinc alloy faceplate with an engraved CCA logo within a shield-like design and there is a small extended “tail” with a small vent. The body, which is similar in shape to the CA16, is formed from a blue-tinted resin and the raised 2-pin sockets are in a clear plastic. The nozzle is fairly long with a prominent lip to secure the tips. The medium size eartips are pre-fitted. The build is very solid and excellent for the price.
The supplied cable is the standard silver-plated 4-core braided type seen on previous CCA and KZ models. There is a long run from the chunky Y-split to the QDC connectors, which are clear plastic and it is difficult to see the channel identification on them. There is no chin slider so the cable tangles very easily. It is terminated in a right angle 3.5mm plug. The ear guides are quite tightly curved.
The CSN was tested principally using an Xduoo X20 DAP but a CD player and smartphone were also employed. The stock cable was used and a burn in period of 100 hours was carried out before evaluation. As with the CS16 and CA16, I obtained a very good fit and seal with the medium supplied tips. The sensitivity was fine on all sources with no need for additional amplification.
First Impressions
The CSN sounded very good out of the box. The general profile was balanced with solid bass, well detailed forward mids and a smooth treble. The overall profile was W-shaped and the tonality was warm. The soundstage was open, airy and spacious. The powerful bass occasionally dominated the presentation. The overall impression was reminiscent of the CA16.
The CSN’s bass was deep, powerful and well-textured. The emphasis was in the mid bass. Sub bass displayed some rumble, but there was just a little looseness and the bass was sometimes a little overdone. There was some bass bleed into the mids.
“Le Tresor”, from “Ixlandia” by Jonn Serrie, is a romantic electronic composition featuring a meandering guitar solo over a lush synthesised backdrop with a very deep bass foundation, typical of this artist’s work. The bass was full and deep with a warm tonality providing a solid basis for the piece but it was occasionally a little soft with some lack of definition at times.
“In Church” is a movement from the “Slovak Suite” by Viteslav Novak. In the version by the RLPO under Libor Pesek’s baton, the prominent organ part was presented with depth, weight and power, creating a tableau redolent of a ceremonial occasion, with the solo organ nicely balanced with the harp and strings.
Mids
The mids were possibly the best feature of the CSN, being open and forward with very little recession. The timbre was very natural. The lower region was warmer due to the influence of the bass and the upper mids were brighter with an attractive presence, but there was no harshness.
“The Plateau of Mirror” is a classic ambient album by Brian Eno and Harold Budd. The opening track, “First Light” showcases a treated piano lead set against an evocative electronic soundscape. There was plenty of detail here and the balance between the solo instrument and the accompaniment was nigh-on perfect. Layering and separation, so important in this kind of material, was praiseworthy and added greatly to the enjoyment of the piece.
Ryuji Kunimatsu’s solo classical guitar in his performance of “Chiquilin de Bachin” by Astor Piazolla sounded very natural with a rich and warm tonality. Details like fingerings were clearly depicted and the ambience of the recording venue was reproduced very well. The woody resonance of the guitar body was convincingly conveyed.
Treble
The treble was bright yet smooth, fairly well-extended and free of peaks. Detail retrieval was good and there was a surprising degree of delicacy on offer, unexpected at this level.
The delicate tones of “Z Op. 1”, by Gabor Presser from the album “Electromantic” were testament to the level of detail produced by the CSN. While remaining smooth and free of undue emphasis, the clarity was maintained with the interplay between the various elements well rendered.
Bach’s “Brandenburg Concerto No. 3” received a lively and entertaining performance from the Saar Chamber Orchestra under Karl Ristenpart. The bouncy and energetic bass line was nicely balanced by a bright and detailed string section, supported by harpsichord continuo, with everything remaining in focus and only a slight blunting of transients from time to time.
Soundstage
The CSN possessed a soundstage roughly equal in all three dimensions. Although the image did not extend beyond the head, the reproduction of ambience was very good, producing the effect of a larger stage.
“Exogenesis” is a track from “Rosetta” by Vangelis. Deep and weighty sub-bass rumbles formed a foundation for sparkling electronic effects and staccato keyboard runs, all set in a huge acoustic evocative of a space journey. The stereo imaging and panning were very effective.
The brooding quality of Sibelius’s “The Swan of Tuonela” was faithfully presented in the wonderfully atmospheric recording by the Lahti Symphony Orchestra conducted by Osmo Vanska. Thunderous bass drum, expressive strings and a haunting cor anglais solo all combined to produce a luminous portrayal in a spacious environment with black silences.
KBEAR KB04
The KBEAR KB04 possesses a warm V-signature with a pleasant well-contoured treble, yet not lacking in detail. It avoids the mid/treble emphasis found in many other models and has a smoother presentation perhaps inspired by the BLON BL-03. The overall profile does resemble that of the CSN but the CSN has more forward mids and a brighter treble and is cooler in tonality.
KBEAR Lark
The Lark is the newest hybrid from KBEAR and has a refreshingly neutral/bright profile with the bass, mids and treble nicely balanced. The upper region is brighter than the CSN but is not harsh. The CSN is more V-shaped and not quite so refined and is a little bit darker but more relaxed. The bass is not as tight and there is some bass bleed which is absent on the Lark.
CVJ CSE
The latest model from CVJ is a little more V-shaped than their previous offerings which were neutral/bright. The CSE has a more balanced profile and a brighter top end than the CSN, but there is some sharpness in the upper mids and treble. The CSN is warmer and has a more “polite” tuning, and is more relaxing to listen to.
After a recent trend for single DD designs there has been a resurgence in affordable dual hybrids with KBEAR’s Lark, TRN’s TA1, the KZ ZST-X and the CVJ CSE all coming on to the market. The CSN joins this crowded marketplace but by dint of its lively, all-round ability it is a real contender. Its well-balanced and entertaining sound, solid build and excellent value should place it on your shortlist if you are looking for a quality IEM in this price range.
Another really fab read @Nimweth. Great review as always. I have a pair of CCA 10 's I think they are (to be honest they are in their box somewhere) and my bug bear with them is that they feel a little flimsy and not really well made. Soundwise though they are ok for what they cost me. The fact that they languish in their box say it all though.
Hello Paul, thank you for your kind comments. Yes, I agree,the C10 was quite good but a little bland for my taste. I have donated it to charity!
Look out for my next review, the Whizzer HE01, coming soon.
As usual, this review is available also in Spanish on my blog and on YouTube, links at the end of this post.
Intro…
The Openheart Resin are a set of IEMs that I have seen mentioned a few times amongst the lovers of budget IEMs and the mention of these were what led me to purchase the Grado-style OH2000 that I reviewed recently.
In the case of these IEMs, I also don’t know much about them at all, all I know is that they don’t have a model name other than “Resin”, at least to my knowledge.
At a price of around 20€, this is another entry into the budget category, far below my sub-50€ barrier, where there is more and more competition lately.
Presentation…
I purchased the Openheart Resin without a cable, appreciating the fact that it is an option and doesn’t involve me having another cable I won’t use (although the Openheart cable that came with the OH2000 was actually quite nice).
They arrived in a small brown cardboard box with Openheart written on the top. Inside, the IEMs were in a small antistatic ziplock bag with another smaller bag containing a selection of silicone and foam tips in various sizes.
The only other thing included is a small microfiber cloth with the Openheart logo, this is something that was also included in the OH2000 so it must be a standard for them, even if it is not a common thing to receive with headphones/IEMs.
Build and aesthetics…
The IEMs are solid resin shells (as the name may suggest) and in my case they have a light blue tint to the clear resin.
The shape is very reminiscent of the Tianderenhe TD02 that I reviewed recently and I find them very comfortable when in place. They do seem to be slightly lighter than the TD02 although there certainly isn’t much in it.
The IEMs use a 10mm Dynamic Driver enclosed inside the cavity which has a small vent tube running from it to the outside of the shell.
I don’t mind the looks of the Resin at all, although I don’t think they look as nice as the TD02. It is also probably worth noting that there are absolutely no markings on the IEMs (brand or model).
Sound…
My first impressions with the Resins using the included silicone tips was that they were slightly sibilant and had a bit too much bass and were not quite controlled enough in the lower regions. I played around with various tips and the included medium sized foam tips just clicked for me, giving me great comfort and the sound that I am about to share.
Starting, as usual, with the sub-bass frequencies, there is plenty of extension down into the lowest regions, giving plenty of rumble on those tracks that need it. The subbass was a little more present with the silicone tips but the foam tips cleaned it up a lot and made the lowest hits sound cleaner and more defined. Listening to some D&B and some electronic music with extreme bass drops, the Resins provide plenty of that low end.
Moving into the higher ends of the bass, they remain controlled and very clear, with a slight emphasis on bass which should be enough for the bass lovers. Whilst they do have an elevated bass range, this is not too exaggerated in my opinion. In songs that use real instruments rather than electronic samples, the bass sounds very realistic and natural, except for that slight boost which I don’t find annoying, just not my preferred tuning as you all probably know by now.
In the lower mids, there is a slight overhang of the bass into the lowest mid frequencies but it is not enough to be unpleasant, just a touch too much for the most realistic timbre of the lowest acoustic guitar notes.
There is a dip in the center of the mids, as with all V shaped IEMs, which can make voices sound a little recessed in their roots depending on the amount of bass in a track. For example, “Way Down Deep” by Jennifer Warnes does exhibit that little extra bass that can sometime overshadow her voice in the lowest registries but in general the sound is rather pleasant on most songs and vocals are not too bad if you are someone who likes this kind of signature.
The higher end of the mids rises to a peak somewhere between the 2 and 3kHz mark, bringing back the presence of vocals. Although the avoid most of the harshness or nasal tones in vocals, this can prove to be a little shouty with brass instruments such as in “Diamonds on the Soles of her Shoes” by Paul Simon.
Up into the higher registries, sibilance is reduced a lot by the foam tips in comparison to the included silicone tips, it is not totally absent but it is reduced to a level that allows tracks like “Code Cool” to be listenable, although you can still notice it. Strangely, I heard more sibilance on Paul Simons vocals with these than I have on other IEMs, whereas my usual test tracks weren’t bad. There must just be a certain frequency in Simons voice that resonates.
The high end obviously suffers from the usual single DD roll off, however, it doesn’t leave the sound dull or seemingly lacking in treble. That slight touch of sibilance sort of adds an impression of air that is not really there. To be honest, I don’t really have any complaints about roll off, sure they could extend more, but they are better than many others I have tested.
The speed and dynamics of the Resin’s is pretty good, not seeming to become overly pressured when listening to fast tracks and the details are also quite impressive for a set of IEMs in this price range. They are not amazing but they do portray a sense of detail, especially in fast tracks, that is superior to many others in the sub-50€ price bracket.
As far as stage width, they are in the average bracket, maybe slightly better than average in this price range. However, image placement inside the width is rather good and makes it easy to locate and place different instruments and effects, even if they are not that wide.
Conclusion…
At 20€, the Openheart Resin are a set of IEMs that offer far more than their price range would suggest. In comparison to other similarly priced IEMs I have reviewed lately, these are certainly one of the better options.
The tuning is not quite my preference but it is not irritating and the cleanliness and control of the low end (with foam tips) makes it much more to my liking.
We have seen a lot of options around this price bracket lately, some of them being very good and these are one of those sets that firmly contends for the sub-50€ bracket. I still feel that the Tin T2+, the KZ ZAX and the KZ DQ6 are above these in my preferences but the gap is starting to get smaller and smaller.
