ZMF Headphones - Official Thread
I would say this is on point, 100%. Matches my preferences for Verite and Aeolus. On Aeolus I actually use the Auteur perforated suede pads instead of the universe version, there is just a subtle difference in stage but pretty much sounds the same.
Edit: on Verite Closed I’m using BE2.
@ProfFalkin @antdroid, Thanks guys. I’m actually going to use the ZMF pads for my Lawton mod. I think I’ll end up trying a few, but I’m thinking to go with the Auteur Lambskins, or possibly the Ori Lambskins.
I’m leaning towards the Auteur. :thinking:
One thing I noticed with stock th-x00 and the Teak is that the thinner the pad, the better the sound. No clue if that holds true with Lawton mods. If it does, universe and Auteur pads would be the way to go. Ori and Eikon pads are thicker.
Thinner being opening?
That’s what I was thinking. :+1:t4:
Thinner as in thickness, or distance from driver to ear.
Oh, okay. Like the stock TH900 pads.
I was thinking the size of the opening as well.
It has a bit to do with it, sure. I think the th900 pads are super bright for treble, so maybe don’t go too big.
Be2 perforated on the closed??? What… tell me more, tell me more…
@TylersEclectic - More.
Well played… well played… I walked into that one :sweat_smile:
Praying at the alter of music with ZMF as my guide! Seriously love my ZMF headphones!
They really are something else! If you ever get the chance to listen to them…jump on it! Especially the Aeolus and Verites!
I wonder if at CanJam NY I’ll be able to find some ZMF, specially Aeolus. Base on your comments plus others member experience, I think I’ll love them.
I believe ZMF will be there with their booth! Say hi for me! Zach and Bevin are the best!
Do you know if they will attend CanJam Socal too?
I’m pretty sure they attend all the CanJams…they were there last year! I still need to buy tickets…
Killer ink man! I just started on my left arm.
Buy tickets ?!?! Is my first one ( if I make the chance). Do I have to buy the tickets in advance ?!?!
Thank you! I’m a big fan of tattoos! I need to finish coloring in my upper left arm…then I’ll start my back and sides up again…followed with chest and stomach…then I’ll finish up my calf’s lol…
You can usually buy when you get there, but if you prepay, you can skip the registration lines. Cost is the same either way.
No, you can buy on the show floor! But I think it is pricier by $5-$10 I recall? But they aren’t super expensive tickets to begin with lol
Edit: I stand corrected thank you @ProfFalkin
