The Vérité and SR1a are very different experiences. It’s a major shift going from listening to the SR1a and switching to the ZMF can. And it takes me a few minutes to adjust - as initially the difference is quite stark. Much more so than, say, going from Utopia or HD800S to the Vérité.
Once adjusted, there’s no problem. I am not focused on the differences and am just enjoying the music. But the transition back and forth has, so far, always prompted strong and immediate recognition of how very different they are in what they do and how they do it.
And … I want both … for different reasons and different times … and not just because the Vérité works with my DAPs and headphone amplifiers. I’d still want the Vérité even if it had the same requirements as the SR1a (or the SR1a could work without a speaker amp).
I’ve always needed (or at least wanted) more than one headphone. At the peak, which was just a couple of months ago, I had 25 pairs. I knew I would have to significantly rationalize that before heading off around the world, but honestly had no idea how I was going to do so and still retain the overall set of capabilities I had become accustomed to.
The path to achieving that rationalization started to become much clearer, with me having more faith that it was actually possible to do, started with the arrival of Vérité. They consumed so much of my listening time … and I really didn’t want to listen to anything else for the first month after they arrived. I was getting a very close amalgam of the best, most enjoyable, traits from my other headphones, without giving up anything significant on technicalities.
That was, and remains, a huge step forward.
That wonderful reverie was only interrupted by the Stellia showing up - sort of a forced interlude. And here I found the solution to the other big conundrum … how I was going to deal with the closed-back side of my collection, as I do need at least one closed-back can.
So between Vérité and Stellia I’d found a way to significantly reduce the number of cans I needed or wanted. The actual rationalization … not just thinking about it, could now begin.
Stellia turned out to be the first closed-back headphone that made me think it would even be possible to live with only a closed-back headphone. Right now, I wouldn’t do that unless I could literally only have one headphone, but if that were the case, and it had to be closed, the Stellia would be that choice.
Now that that “veil of belief” has been pierced, I am anxious to hear the rumored closed-back Vérité later in the year.
Ahead of that, and getting back on topic …
Vérité enables a lot of consolidation in my collection, without giving much, if anything, up. Stellia enables some more. And the SR1a finishes it off. In fact the only reason I think I’ll have more than these three headphones going forward is that the SR1a does need a speaker amp, and I need something more like it, but that can run on normal sources, for the foreseeable future (probably Utopia).
Between these three, headphones I never thought I’d want, let alone be able, to give up, are already on the chopping block - either listed, or about to be, for sale - or actually gone already.
Remarkable stuff!
