Thanks for your response, when I think of environmental noise I would expect it to also affect other components in the same manner. Specifically other tube amps, where I had not run into those issues. On one tube amp I have, the noise could be traced to a power tube and that was quickly replaced with a another tube that fixed the issue.
As a consumer I would like to find out why this brand is more susceptible to noise than other tube amps. What I find boggling is many responses so far have basically accepted it as an external fault, not a fault of the amp design itself.
So these noise issues, based on the few of you kind enough to share your experience it seems itās a feature rather than a bug to live with it. Props to those of you who are able to overlook this, outside of @eric75 and his Kenzie Ovation all of the Amp&Sound amps suffer from the low level noise at a minim, it is hit or miss on the ground loop, or antenna like noise.
So for those of who have listened, but not owned any of the amps, what are your thoughts?
I wonder if I can hide my Ovation or Pendant in my filing cabinet⦠
