Just sharing some quick EL34 rolling impressions on the Mogwai (SE):
Was trying to find a good roll for the Utopia on the Mogwai, ended up with this. Pretty close to black noise wise and for me a great compliment to the sound of the headphone. Adding a slight bit of meat and soundstage while compromising as little as possible in terms of detail and speed. Ended up with this:
Tube roll:
Sylvania 6sn7w metal base
Ei EL34 Siemens labeled, saucer getter, black base
Sylvania 5931 double mica version
Input transformer = Off
Jack = 8 ohm
Contenders for the power slots were:
Psvane - EL34PH
I am usually not a big fan of the “extra fancy” reissue stuff, and this tube is no exception in the Mog. The construction, while true to the form of a Mullard innards, it has that cheap replica look on the metal base. In terms of sound, it reallty doesn’t add much from a regular Psvane EL34, if anything it is slightly more coloured and mushy. Still it sound like any chinese generic tube to me, not bad, but slightly dull, flat and unexceptional. Has more colour in terms of warmth than the russian reissues, which some may prefer. I’d just get a real Mullard (these are almost the same price) or save som cash on regular reissues personally.
Mullard EL34 - Xf3s, Blackburn, Philips labeled, single getter
Quite common, middle of the road Mullard, still a solid tube. They have a really good balance of that EL34 body and kindness to them, but are still very detailed and exciting to listen to. In the other amps i’ve had, these would usually be my go-to, but they just don’t click in the same way with the Mog. These are not as warm as the replicas, but still a touch too warm and slow in the Mogwai for my taste. Works out for headphones like HD800 though.
Ei EL34 - Siemens labeled, black base
A very cool looking and characteristic tube in terms of having the top on the bottle. I have rolled these in other amps vs. the Winged Cs, and to me they have been quite similar in those cases. I don’t have any Winged Cs on hand atm for comparison in the Mog. However, they are a less “romatic” kind of tube than the acclaimed Mullards. They still have that distinct EL34 body to them, and good staging capabilities. Seems like a good balance and fit with the Mog in general for me.
Summary:
Found the EL34 tube with the least warm leaning signature to it to be most desireable for this roll. Complimentary input and rectifiers similarly, but also for noise control.
Notice:
No input transformer chosen for a slightly more open presentation, which I think compliments the headphones at hand. 8ohm tap probably a no brainer in this case.
