Shows $399…must have to be a club member
Oh weird, yeah when I open the copied link it changes from $119 to $399. Sorry
I ordered a set to give them a shot. Hope they’re better than the LX I got on the Valentine’s Day sale…pretty awkward fit. Guess you have to get used to them. Should probably get the cipher cable to get the most out of them. Keep reading it makes a big difference.
If you want to use them with iOS, you really want the Cipher cable. Not only does it have an integral DAC made for the IEM, but it provides corrective EQ. And in addition the app does custom parametric EQ. If you use them on other systems you will find you need EQ. ROON has EQ by Audeze if you’re not using the Cipher.
