Price: 1,275.00 OBO
Currency: USD
Ships to: US lower states - Fedex Ground free
Heading south for the winter and these will just sit around. These are the Fazor models, and both earpads and drivers were replaced by the factory on 2/14/18 and under warranty until 2/14/21. Included are:
- custom 10’ Silver Dragon cable (1/4" Furutech Gold - $440)
- original standard cables
- original 4-pin XLR balanced cable
- a 6.56 2.5mm Trrs Balance cable for use with a digitial audio player (Astell&Kern AK240 AK380 AK320 onkyo DP-X1 FIIO X5III XDP-300R 2mr)
- Audeze phone plug to standard 3.5mm jack adapter
- Original wood box, original Audeze packing carton, certificate of authenticity, etc.
Excellent condition. No nicks or scratches or cosmetic issues. One of the Silver Dragon cable connectors has a small rough spot - which I use as a marker for right side.
----------------------------------------- The LCD-3 is a high-resolution headphone that always sounds musical, spacious, with powerful bass, an engaging midrange, and an extended top end. Its rich, vibrant sound has real scale and authority. It features a deep soundstage and reveals music in a very ambient way with exciting transparency and detail. The LCD-3’s natural timbre, especially through the midrange, has been called a thing of beauty. You’ll find yourself emotionally connected to the artist and music. Pair it with a high-quality headphone or integrated amplifier for best results. Its impedance is 110 ohms. Acoustically engineered for accuracy.
“Words fail to describe the level of accuracy the LCD-3 are capable of, or the absolutely jaw-dropping level of detail with which they extract every nuance contained within music.” - Digital Trends
Manufacturer’s description: Audeze’s innovative planar magnetic technology delivers clear and accurate sound that reveals everything on the recording. Diaphragms thinner than a human hair. We use space-age materials in an ultra thin diaphragm four times larger than typical headphones for fast response times, dramatically reduced distortion, higher resolution and improved imaging. Near zero distortion. Double-sided magnet arrays delivers a uniform driving force across the entire diaphragm for near zero distortion. Internal waveguide. Patented Fazor Elements guide internal headphone soundwaves to avoid resonances for a more accurate waveform.
