Hey, thanks so much for your insight into this and for the link to the Crinicle database. I had only seen Antdroid’s prior to this, so another data point is always good!
Without some type of showroom/meetup, trying a bunch of different headphones is hard to do. It’s even more challenging with IEMs because you really need your own tips to fit them properly. So bearing that in mind my strategy is the following:
- Start buying IEMs that are highly-rated AND match my preferred signature. My current list (in no particular order) is:
- Sony IER-Z1R
- Sony IER-M9
- Thieaudio Monarch
- 64 Audio U12T
- 64 Audio Tia Trio
- Vision Ears VE8
- UM MEST Mk 2
- EE Odin
- Oriolus Isabellae
If they’re as good as my experience with the Andro’s then STOP and keep them. Otherwise sell and move on (may need to keep a couple at a time for comparison)
If I’m “stuck” with the Andro 2020’s, I’ll just file down the case to knock off the point and hope that solves my problem. Of course this option drops the resale value significantly, but if these are my end-all be-alls then it shouldn’t matter!
Again, thanks for all the info!
