I made this cable a few months ago and took a chance with Lunashop on AliExpress after a few friends recommended it. Anything labeled as “Extreme Soft” on their bulk wires should fit the bill.
The Universal Eidolic 3.5mm TRS plugs fit (they have an extended, sleeve), though they are narrower than the recessed opening, so there is a gap around them, and the extend further than they need to.
I believe the Amphenol Extended Collar plugs fit, also, but that’s 2nd hand information - not tried them myself.
Does anyone have recommendations about adding a cable neck Y splitter to a finished cable? I bought a DIY cable from someone and it works fine, but I hate the neck divider/splitter they used. I’ll be able to cut it off, but am wondering about installing a replacement.
This is a typical design, but they must be installed at the start of the build:
Thanks. The ends were both glued and heatshrunk into place, and the cable isn’t that good overall. I bought and keep it as a convenience niche cable and don’t want to throw too much good money after bad.
I’m building a 4.4 (male) to 2x XLR (male) adaptor (to go from a dap to an amp).
There seems to be a sort of ground loop: when i touch the portable device feeding into the amp.
I just connected L+ to L+ etc but nothing to ground on the XLR connectors.
Didn’t think it was necessary on this kind of cable (and not all 4.4mm connectors have sleeve internally)
