Seems like there is a lot of love for planars over 2k like the Rad-0, LCD-4, Susvara, etc.
I’d love to hear the community’s opinions on planars with the following parameters:
Less than 2k new
Assume that you don’t need to worry about the headphone amp (or speaker amp) or DAC, just the headphones under close to ideal conditions (like not a 20k setup, but a good one).
Regardless of price-to-performance as a factor (as long as it’s under 2k).
I have used ZERO of these, though I am considering a similar question and will say that these are the three I would probably most closely look at with a $2k hard stop.
I think Arya ($1600) is the best planar under $2k. The first material step up from Arya, depending on your preference, would be Rad-0, Empyrean, or HE1000se, all of which cost considerably more. In that respect I think Arya punches objectively well above its weight and represents great value.
Alternatively, if you don’t like the Hifiman sound signature then the answer is probably LCD-X(C).
This is a great review! Thanks for pointing it out, I don’t think I would have found it otherwise. I’d love to hear a headphone with such great soundstage.
So you have it over the he6 now?
How much do they weigh?
Do you eq them?
They weigh 578 grams and are very comfortable. They use a similar headband system as ZMF. They’re 2nd tier comfortable to me. But not as comfortable as the 800/800S or Empyrean, but then what is?
I do not use any EQ, because I prefer a smoother/less bright signature, and they have that in spades. You could certainly EQ up a few decibels in the upper mids and treble if you prefer more of a Hifiman and/or Focal signature.
So the HE6 is the only Hifiman model I haven’t heard (not counting their e-stats). I’ve owned almost all of their other models from the 400i, 560, Sundara, Ananda, Edition X V1/V2, Arya, HEK V1/V2/SE, and Susvara.
I’ve only heard the few planars I’ve had, HE-4XX, Edition XX, Mobius, and got the Arya v2 a few months ago. The Arya is one of the few non-ZMFs that I plan to hold onto. For me they’re very comfortable, lightweight and are really so open I feel like there’s basically zero blocking of external noise which I like for a change from more cozy headphones. I do worry about there being problems but none after 4 months and I had no problems with my other HiFimans. I like them having an HD800-sized wide soundstage, which I actually sold once I got the Arya and took me about 30 seconds of listening to decide which one had to go. It seems every bit as detailed but just much more full sounding even aside from the greater bass quantity.
LCD-3 for Jazz, R&B, and a few other genres
HE6se for soundtracks, orchestral, and quite a few others. Especially if modded and powered well.
LCD-X for a wide range of things.
Everything has its negative point. I have a trained neck and I haven’t great problems with Audeze headphones but their weight is really important and it is something that stops many people from using them.
For me it’s not Audeze’s weight on the neck but their side pressure on the jaw. Regardless of the sound, it’s hard to enjoy headphones when you experience constant pain when using them.
