itâs very enjoyable, Iâm sure.
Try âMeâ by Tamia.
Try âMeâ by Tamia.
Yeah. I tend to go this route with planars that donât mesh well directly from the tube amp itself.
Morning gents! I have the little one today so I will have to wait until this evening to continue my listening of the Elise Mark II but the burn in continuesâŠ
Quick IPhone
snaps
Nice abode. Dedicated burn-in cans
Thanks @bpcarb hahah yup! 6XX does my burn
in lifting
Hey @antdroid and @MRHifiReviews how is the combination of the Bifrost 2 and Elise when driving the Vérité? Does it become too much of a good thing (lush/dark)? Or is there a good synergy effect between the two and the Vérité?
I have been considering the BF2 and a Feliks amp as my next upgrade and would use them with the VC, VO and Auteur.
Hey brother @Deepy ! I think it will greatly depend on your preferred sound signature. The BF2 sounds lusher than say the D90 with the Elise MKII I have based on my listening last night. I need to do more listening and testing and I promise a full review of the amp discussing both dacs as well and will keep updating this thread with my findings too =) I honestly enjoy both with the D90 sounding a bit more energetic and forward in itâs presentation to my ears and the BF2 sounding a bit more laid back and warmer with a more euphonic stage.
Tried out the Elise last night with the Rad-0 and It didnât sound quite right. Some of the Rad-0 sounded very good at times but the bass was loose and at times I could hear some distortion. I feel this is where the Euphoria has the advantage. I wonder how much current the Elise outputs from its single ended output⊠switched over to the pendant and the Rad-0 sounded much better.
Whatâs the Zout on the SE?
@perogie no idea
The fact that the amp supports 32-600ohm could be part of the problem as the Rad-0 are 29 ohm I believe. The amp sounds great with the Verite Open, Aeolus and 6XX. There is also a 50mw output power difference between the Elise and the Euphoria according to upsacale audios website but their site also states the Euphoria is 32-600ohm. There are several people who sing the praise of the Euphoria with Planar headphones, this may just be a poor match for the RAD-0.
I was just wondering as what you are describing sounds like impedance mismatch.
Yeah I think so, I had a couple other Rad-0 owners said they used their Rads with the Uphoria with good sound so I thought I would give it a shot with the Elise, no dice.
Sounded like my experience when I plugged the Susvaras into the Echo. Sounded good but then you could hear the distortion in the lower end.
Those pesky current hungry planars.
Iâve gathered the Elise has a Z-out of 45-50 ohms, the Euforiaâs Z-out being 20 ohms. This is consistent with my own experience auditioning the Elise and Euforia side by side using my 32 ohm Empyreans. The Elise noticeably stuggled with controlling the bass at medium-high volume levels, while with the Euforia I need to push the volume to around 90 dB SPL on bass-heavy tracks before the bass starts to show signs of current/damping deficiency, which is louder than I ever listen to consistently.
The RAD-0âs specs seem to be very similar to the Empyreanâs, so I would expect a similar result based on that. I wouldnât be able to comment on how the subjective synergy would be between the Euforia and RAD-0 though. With the Empyrean itâs a bulls-eye match, but the Euforia Mk2 was optimized specifically with the Empyrean as Feliks Audioâs primary planar reference in collaboration with Meze Audio, so it would seem that the Euforia + Empyreanâs excellent synergy was to be expected anyways. Itâs not a guarantee that itâll have similarly excellent synergy with the RAD-0, but since the Euforia has a fairly neutral signature I donât expect there to be any major synergistic concerns.
And fyi, I found FR measurements of the Euforia on SBAF with (blue line) and without (green line) the Euforiaâs analog crossfeed circuit activated:
Disclaimer: As per usual, this FR graph doesnât provide a reliable way to determine the sound of the amp. In my experience the Euforia sounds brighter than it measures in a very pleasant and inoffensive manner, possibly due to its outstanding dynamic capabilities(?).
Anyways, in order to prevent this discussion to transition to the Euforia as the main subject, Iâd say it might be best to discuss further in the Euforiaâs own thread if thereâs anything else youâd like to ask about the Euforia.
Doing some amp rolling with pre-outs for Sheldon @bigshel99 with his Koss ESP-95X
Giving him some sound impressions as he was kind enough to loan me his personal pair, thank you
Another view
Lately Iâve been using the Elise as a pre-amp tube buffer to the Topping A90 to power my Hifiman Arya. I think this is actually a very good combination for planars. The A90 is transparent enough but has plenty of power for planars while allowing the tubes to color the sound. As I stated in my A90 review in the past, I noticed the subtle tube changes more so on the A90 than I did on other solid state amps I had at the time.
For the Verite, I still prefer the Elise alone. I havenât put a lot of ear time on the HD600 unfortunately, since my wife has confiscated that set.
Awesome! I tried it recently as well with an electrostatic energizer and was Impressed
, I actually moved my A90/D90 next to my Elise to try this combo too!
Hey guys many of you have been asking for a direct shoot out Pendant vs. Elise would Friday afternoon work for you guys if I did a live stream or is next week better with the holiday? Thoughts?
Count me in. Barring any conflicts with dinner, Iâll be there.
That would be a great comparison. Iâm on UTC +1 time, so not sure if I could catch the stream. But I would very much want to hear your thoughts on how the amps compare.
