Final Sonorous VI Amp/dac Pairing
i am most likely going to go and buy the final sonorous vi (Pandora hope) but finding a great amp that pairs well with them is a challenge! They have an 8 ohm impedence😤 I was wondering if any of you have any suggestions. I have a budget of like 600 max for both and I’m totally ok with buying used as well.
You really don’t need an amp with them. They can be easily driven from pretty much any source which was part of their design. If you really do want to pair them with an amp though, I wouldn’t be looking much higher than the Dragonfly Black.
