Focal Clear Open-back Headphones - Official Thread
It can help if you use a nice smooth amp or some tubes for the Clear…using the thx stuff can definitely make it sound peaky…
Oh, you will get pierced…a lot! But that’s before burn-in. It takes a while to burn-in the VC but once it does I think you’ll definitely enjoy them. I believe burn-in does happen but only within the first few minutes. The VC for some reason takes much longer than that from what I’ve experienced.
Generic is not selling smoke. Moving the Ananda from a Schiit Magnius, to a Matrix Mini-i 3 to a Bryston BHA1 was a revelation in the low end.
Synergy is always the keyword. It’s incredible how an headphone can change in sound with an amp that seconds or changes its nature. That’s why I always suggest to try different solution before changing equipment and why I believe variety is better than one piece.
Great impressions @Seif.
I’m really enjoying my MG Pros, but I’ve been reading that OG Clear pads on these bring back a bit of the OG sound signature, and have a touch more detail and soundstage. Seems like a bit of a fetch, but I’ll find out when I’m home from work tonight! I ordered a pair of OG Pro Pads from Moon Audio. Right off the bat, the MG pads are noticeably thinner. Maybe even a touch softer? Probably because they have 10+ hours on them. I’m awful at explaining, but hopefully soon I’ll be back with some input on feel and sound changes that can actually be beneficial for whoever else is curious.
First pic - Left: Worn MG / Right: OG Pro
2nd pic - Left: New MG / Right: OG Pro
Super vague initial impressions time! The OG pads are an improvement on the MG headphones. Both pads disappear on my head, but because the OGs are thicker, it’s SO slight but I get a better sense of openness with my music. And I’m sure if your ears were touching the drivers with the MG like some people have said, OG pads should fix that. Also the MG pads have a lot more of a memory foam feel for those who want to know.
The MG headphone has never sounded veiled to me, but the OG pads somehow seem to pick out more detail throughout the whole FR. After some quick back and forths on songs, I ended up on Dreams by Fleetwood Mac, and high hats seemed to have more tingy treble presence (I dunno what to call it lol) and I had a better sense of how and where cymbals were hit with OG pads. The bass guitar sounded similar enough on each pad, but details like plucking might have been easier to pick out with OG pads. I’ll have to listen more to gather thoughts on mids. Maybe I’m just subconsciously biased toward the OG pads for being new and different, but I feel that the OG pads are an improvement! I’ll definitely be doing more comparing over the coming days.
Focal Clear Review - The Critical Take
Based out of France and purveyor to some of the world’s finest audio transducers, Focal’s a brand that’s been on my radar for some time. The Focal Utopia, in particular, has afforded me many a moment of yearning. And angst, I should add, looking at that price tag! For mere mortals like myself, then, the Focal Clear was the clear alternative that promised comparable performance at a fraction of the Utopia’s cost. And yes, I’ll try and refrain from more bad puns going forward. Anyways, courtesy of Headphones.com, I’ve been evaluating the Clear for the last couple months.
I know I’m quite late to the party with my review. And if you’ve read any other reviews, then I think it’s already been well-established that the Clear is a pretty awesome headphone. There’s not much fun (for me, at least) in parroting those reviews, so I’m going to do what I do best: Let the critic in me run wild. This is not a review for the faint of heart; however, if you’re interested in a more critical perspective on this highly-acclaimed headphone, then I encourage you to read on.
Source & Drivability
Critical listening was done off of a Burson 3X Conductor, iFi iDSD Micro BL > Macbook Air > Audirvana > lossless FLAC files. That being said, the Clear is a remarkably easy headphone to drive due to a low impedance of 55 Ohms. I was able to listen using a number of portable sources like my iBasso DX300 without an issue. For music used, check out the end of the review where you can find some of the tracks I use for my listening.
The Tangibles
The Clear arrives in a large, black cardboard box with Focal’s branding on it. The following accessories are included:
  • Hard-carrying case w/ storage for one cable
  • 1.2 meter cable w/ 3.5mm jack
  • 3 meter cable w/ 6.35mm jack
  • 3 meter cable w/ XLR 4-pin connector
I really like the included carrying case. It also has a slot for a 3.5mm to 6.35mm adapter so you can get away with just bringing the 1.2mm cable. I think my biggest complaint about the included accessories would be the tactility of the cables. They are fairly…well, janky, for lack of a better word, and I would like to have seen higher quality cables included. They look like the same cables you might find off a desktop lamp from Ikea (no really, I encourage you to check out some posts in the r/headphones subReddit). Then again, you’re getting three separate cables, so maybe that’s fair.
The Clear itself sports a substantial build. It has an aluminum frame, leather headband with perforations, and memory foam cups with perforations for breathability. There is some play to the yoke when moving the cups from side-to-side, but that’s not necessarily a bad thing, as it affords a more comfortable fit when the headphone is being worn. The cups themselves also have a very cool spring system which contours the cups into place so you don’t have to worry about adjusting the headphone as much. Again, really solid stuff overall. The only thing I’m somewhat on the fence about is the lighter color of the pads. They’re prone to discoloration given time (and replacement pads are not cheap!).
For fit and comfort, the Clear is certainly not as comfortable as something like the HD800S, but it is far from being the least comfortable headphone that I have worn. I think most people would be fine, as I’m quite picky about headphones and don’t wear them often. Because this is an open-back headphone, do be aware that there is zero isolation. I wouldn’t purchase this headphone expecting to use it on public transportation or in louder environments.
Sound Analysis
Twitter-review summary: The Clear presents a neutral-warm sound signature that’s reasonably well-balanced sans some quirks in the upper-midrange and treble. In tandem with its technical presentation, it is a forward, engaging listen that demands attention.
I actually have the venerable Sennheiser HD800S on-hand at the time of this writing. Suffice it to say that I was not impressed with the HD800S’s bass response, and switching to the Clear presented an immediate improvement. The Clear’s bass is pretty much exactly what you would expect of a higher-end, dynamic driver headphone. It is near-neutral and extends fairly deep. I would say it’s on the faster end of dynamic driver bass; not the hardest hitting nor crazy clean like a planar, but simply…good. I would certainly prefer more sub-bass quantity; of course, that’s personal preference. Oh, and before I forget: If you’re wondering about the oft-cited driver clipping, unfortunately, I don’t have any input as I don’t listen remotely loud enough for it to occur.
The midrange is where things get more dicey. The Clear transitions into the lower-midrange properly - it’s dead flat - followed by a peak at roughly 1.5kHz. This part actually sits fine with me. While it certainly contributes to the Clear’s slightly boxier presentation, I immediately noticed that it flies superbly with the likes of piano. I’m no musician, but to my ears, piano tones sound incredibly exuberant and rich on the Clear. In general, the Clear is a headphone with a focus on the lower-midrange. Now, I think the Clear’s second midrange quirk will be more contentious. It is a dip at roughly 4kHz. This is not necessarily an issue standalone - in fact, many of my favorite transducers recess this region - but the Clear contrasts this with a minor peak at 6kHz in the lower-treble.
The end result is a double-whammy, as I hear substantial amounts of sibilance and grate with female vocals. If you’re not familiar with the term sibilance, it’s when certain consonances are emphasized over others with a hissing characteristic. A quick example I can point to is Girls Generation’s “Flyers” at 0:45 on the lyrics “peace sign”. It almost sounds like the “s” has shifted into an abrupt whistle. Before you say “It’s your garbage K-Pop tracks!”…well, yes, it is partially baked into the track, but I don’t hear this on any of my other transducers, or at least not to this degree. The Clear also has what I would consider a fairly textured timbre (it certainly leans more textured than, say, the venerable Sennheiser HD6XX). To my ears, these instances of sibilance unnaturally highlight the texture to the degree of which I use the word “grate”.
You know, it’s unfortunate that the Clear’s 6kHz peak contrasted to the 4kHz dip is just enough to result in sibilance. Because despite measurements citing that fairly pronounced 6kHz peak on the Clear, the peak was barely audible based on sine sweeps I ran by ear. I want to say that the Clear’s treble response is actually more mid-treble oriented. Like so, I observed a peak somewhere at roughly 9kHz, followed by a significantly stronger one at 11kHz. After this point, the Clear slopes off not unlike the Sennheiser HD6XX; it’s not a particularly airy headphone to my ears. But frequency response only tells us so much. How does this actually translate to practice?
To my ears, then, the initial impact of percussive hits are pulled out longer than they should be, and there’s a type of dirty resonance that harkens to the Hidition Viento-B. I don’t think it ever quite comes across as smeared - the Clear has fairly good nuance - however, it contributes to what some might describe as a “metallic” timbre. Doesn’t sound pleasant, right? But here’s the thing: I have to admit that I don’t dislike it. It’s a peaky treble response to be sure, but there’s an edge of authenticity to the Clear’s treble that appeals to me. For example, when the opening cymbals of SawanoHiroyuki’s “Cage” drop, there’s a tasteful sense of authority; it’s almost like you’re on stage right next to the hits.
Technical Performance
But while the Clear’s a brighter-leaning headphone, I don’t get the impression that it’s using frequency response to compensate or “fake” the perception of detail. Indeed, the Clear is a remarkably strong performer for a sense of internal detail. I would mainly point to the Clear’s microdynamics - reverb trails, decay, and the nuance of individual instrument lines. I freely admit that I struggle to hone in on this stuff, and at the end of the day, it’s mostly me acting on gut instinct. Nonetheless, most readers will know that I come from a strong IEM background where (in my opinion) microdynamics are largely non-existent. The few IEMs I have heard with the ability to scale more intimate fluctuations tend to have a certain, say, “micro-texture” to the way notes decay. The Clear definitely has this quality, and I think it pays compliment to its macrodynamic ability.
Speaking of which: the Clear’s excellent macrodynamic contrast. In any given track, there are decibel peaks and valleys; macrodynamic contrast is indicative of a transducer’s ability to scale said gradations. Pro tip? A hallmark of a headphone with good dynamic contrast is one where you find yourself turning up the volume on quiet sections of tracks and, conversely, turning down the volume on louder parts of tracks. The Clear is not a headphone for listeners who want to kick back and relax after a long day’s work; believe me, this is a headphone that demands your attention. Watch those listening volumes with the Clear!
That said, I still have bone to pick concerning the weight, the second derivative of macrodynamics to my ears, with which the Clear rides dynamic swings. What do I mean? If you have ever heard a 2-channel system - heck, even some IEMs like the 64 Audio U12t and Tia Fourte - you might notice that there is a sense of intensity, pressure, as certain tracks build. On Taeyeon’s “Make Me Love You,” for example, the opening bassline should successively wash you with a gentle, yet firm sense of authority. Then when the song transitions into the chorus at 0:50, it should be the auditory equivalent of a wave slamming into you. In this instance, the Clear’s a fairly punchy headphone with a good sense of immediacy to be sure, but I think its ability to articulate that more innate sense of body, gravity if you will, could use some work.
Of course, this is me nitpicking. For most listeners, I think the Clear’s most apparent weakness will be soundstage size. The stage of the Clear is a more intimate one and, if I had to guess, this is due equal parts to the forwardness of treble and to the bump at 1.5kHz. This is particularly evident relative to the HD800S which chooses to cut the 1kHz region; instruments sound slightly squeezed on the Clear. To be fair, these headphones are going for two very different things. The Clear is certainly warmer, and I think it maintains solid imaging chops, at least on the front of positional accuracy. The Clear’s soundstage depth, like most headphones, is something I don’t think is worth commenting on.
The Verdict
The Clear was not quite what I expected it to be. In many ways, it is the antithesis of my time with the Sennheiser HD800S. I felt that the HD800S sacrificed microdynamic engagement and bass in the pursuit of a more analytical sound. By contrast, the Clear is a more visceral, energetic expression of what’s possible from a dynamic driver headphone. I want to reiterate that I have been intentionally critical throughout this review. While it’s far from perfect, the Clear is still a fantastic headphone in my books, one that I once considered purchasing for myself. If you’re okay with living with some of the flaws that I’ve outlined, then it’s my pleasure to recommend the Focal Clear.
Reference Tracks
  • Aimer - Hakuchuumu
  • David Nail - Let It Rain
  • Everglow - DUN DUN
  • Girls’ Generation - Galaxy Supernova
  • Illenium - Broken Ones
  • Joe Nichols - Sunny and 75
  • Keith Urban - Defying Gravity (2009)
  • Keiichi Okabe - Weight of the World (NieR:Automata Original Soundtrack)
  • Sabai - Million Days
  • Sawano Hiroyuki - Best of Vocal Works Remastered (2020)
  • Taeyeon - My Voice (2017)
  • Tiffany - I Just Wanna Dance
Great review! I’m happy that you’ve begun reviewing over-ear headphones. Keep ‘em coming; perhaps a midrange to high end planar driver transducer next.
Great review and nice pictures! :+1::blush: Thank you
I don’t usually go in for EQing headphones because once I start EQing I can’t get myself to stop thinking about it and I get caught up in comparing the differences instead of enjoying the music :space_invader:
THAT SAID, this Focal Clear EQ by Innerfidelity (via SoundSource) usually beats no EQ for me…
That u12t EQ also rocks
current chain:
Apollo Twin X → 789 (Balanced) → Clear
Reference Playlist (Spotify)
Note that it is the headphone FR measurement that comes from Innerfidelity while the EQ used is generated by AutoEQ software based on that measurement (GitHub - jaakkopasanen/AutoEq: Automatic headphone equalization from frequency responses). There is a significant difference in sound between the oratory1990 EQ that you need to add as a custom EQ into SoundSource and the AutoEQ based on oratory1990’s FR measurement that is built in even though they are both using the Harman target.
Very interesting!
More variables / controls = more anxiety for me because I can’t shut off my audio production brain - so the “one-button” EQ solution is particularly attractive so long as it sounds good. I’ve tried re-creating several different people’s Focal Clear EQ settings using FabFilter Pro-Q 3 and I’ve never come across one that beat out having no EQ on most of my test tracks.
Try this:
Preamp: -4.9 dB
Filter 1: ON LS Fc 105 Hz Gain 5.5 dB Q 0.71
Filter 2: ON PK Fc 90 Hz Gain -4.9 dB Q 0.30
Filter 3: ON PK Fc 1330 Hz Gain -6.0 dB Q 1.00
Filter 4: ON PK Fc 2200 Hz Gain 1.4 dB Q 2.5
Filter 5: ON PK Fc 3000 Hz Gain -2.6 dB Q 3.00
Filter 6: ON PK Fc 3700 Hz Gain -2.1 dB Q 5.00
Filter 7: ON PK Fc 4300 Hz Gain 2.0 dB Q 4.00
Filter 8: ON PK Fc 5950 Hz Gain -4.1 dB Q 10.00
Filter 9: ON PK Fc 6600 Hz Gain 2.0 dB Q 7.00
Filter 10: ON PK Fc 7500 Hz Gain 1.0 dB Q 3.00
Copy and paste that into Focal Clear.txt then SoundSource → Headphone EQ → Add Other Profile… and open Focal Clear.txt.
Interesting! I’m not sure how to load this into Headphone EQ but I recreated all of these bands on FabFilter Pro-Q 3 and it sounds v different compared to the Innerfidelity preset. On Pro-Q you can set the “gain scale” - so 50% gain scale halves all of the dB amounts. It sounds much closer to the Innerfidelity preset when the gain scale is at 30%…
Click on the Headphone EQ drop-down select box like you would if you were changing the current EQ profile. At the top is an option Add Other Profile… Clicking that will open a File Open dialog where you can open the .txt file and it will create an EQ profile that is the same name as the .txt file.
But if you don’t like it in FabFilter then you probably shouldn’t bother. :sunglasses:
Hi all, wondered if anyone could throw some light on an aspect of the different characteristics of headphones that’s been bugging me… I did a comparison test between the Audeze LCD-X and Focal Clear and recalled the vocals being far more forward on one set than the other. That surprised me as I thought the relative positioning would be governed by how a particular recording was mixed, rather than the characteristics of a specific headphone. In the end, I decided on the Clears, the LCD-X sounding relatively muffled to me. Appreciate that all headphones will have different dynamic responses in relation to the Harman curve. What I don’t get is how aside from soundstage (which I understand can be influences by the angle of the drivers), headphones can have different relative positioning of vocals/ instruments in a given recording. Would welcome any thoughts and views on this.
hi Chap704!
we perceive things as closer to us when they’re louder. different headphones emphasize different frequencies. if an instrument’s fundamental frequency or some combination of its harmonics are emphasized by a particular headphone’s frequency response, it’s probably going to sound louder / closer.
a lot of people on this forum apply EQ to their headphones - especially headphones by Audeze which allegedly really need the EQ to sound normal.
I’m a huge fan of the Focal Clear with and without EQ.
welcome to the forum!
PS
Focal Clear vs Orphean Sound Darkvoice (stock tubes)
I’ve been testing out the Clear with a Darkvoice tube amplifier. I usually prefer the cleaner, more precise presentation of the 789 but the Darkvoice is a nice touch on some records
the Darkvoice does a wild thing to the Clear’s soundstage. it’s like the imaging is a little drunk. maybe a lot drunk. instrument placement is less precise and more spread out.
tonally, the Darkvoice sounds like it elevates the Clear’s low end in a way that I don’t love. I much prefer the neutral tonality of the 789 on most material.
does anyone have any tube recommendations?
shout out to everyone else with disgusting old Focal Clear pads
Thanks. Eventually realised that the answer was probably as simple as that - mid frequencies for a particular headphone making vocals apparently closer. Thanks for confirming……
Recently bought Naim Unity Atom (headphone addition) for use with the Clears, which I’m delighted with. Seems to me ( as you’ve experienced with your amp) to add significantly more soundstage. Previously, I’d been using a Dragonfly Cobalt DAC/amp. I’ve no idea how it achieves that, but a definite improvement anyway.
I’m a bit late, but I’ve heard great things about the Feliks Audio Echo. The v2 is out now which is supposed to pair much better with the Clears compared to the v1.
Really really dig the Focal Clear OG + Darkvoice combo despite the impedance mismatch. Dying to hear what the Clear sounds like with something like a ampsandsound Kenzie. Has anyone heard that combo? What impedance did the Kenzie have?
What other tube amps have you liked w the OG Clear?
