Hi,
bought the Focal Clears some months ago. I had heard them a few times at stores and hi-fi shows. I really enjoyed the clarity and separation and thought to myself: I wonder if these would pair really well with the right tube amp?
So I am currently testing them out with my collection of DACs & amps. And I might as well post it here, as it might be of interest to someone else.
Source is desktop PC running Spotify and Tidal Masters. Tidal should be on a bitperfect chain. I dont EQ. Interconnects varies but USB is usually Supra or Wireworld Ultraviolet. Power when not on battery is using Supra Lorad cables connected to Supra LoRad MD06-EU MKII mains block.
I use the Focal Clears for music and casual gaming. Music ranges from proper hifi stuff like Agnes Obel, Leonard Cohen and tracks i Shazam at hi-fi shows to lots of electronic music, folk-pop, acoustic, hip-hop, some rock and then many other genres which I donât even know the name of. Iâm pretty open to any tune as long as it sounds good. But not much Classical or Jazz.
All impressions are my own. And I might even change my view when I revisit a combination later after more listening
. Likely many will be of different opinions on which pairing they prefer.
Anyway here goes:
Focal Clear pairings pt1: Geek Pulse Xfi (2x ES9018K2M, 2x Femto clocks) + SBooster 12V doing quite well. Perhaps bit more weight to the sound is needed. Amp part of the Geek Pulse Xfi is kinda light weight.
Focal Clear pairings pt2: The search for magic synergy continues. Added JDS Labs Atom to the mix. A great entry-level amp. DAC is still Lh Labs Geek Pulse XFi + SBooster 12V PSU. This combo sounds good. But (to my ears) something is still missing, need to try out the Focal Clears with more gear.
Focal Clear pairings pt3: LH Labs Geek Out 450. This is now a 7 year old DAC & AMP, but still extremely good sounding to my ears. It uses a very well implemented ESS9018K2M DAC chip. I think a lot of stuff released after and to higher pricepoint than the original $149-199 RRP simply does not compete. The GO450 drives the Focals with really good authority, clarity and a nice tonal balance. Some slight tizziness on hi-hats and such on poorly recorded stuff, probably due to the clarity from both headphones and DAC/AMP. Soundstage could be bigger not getting the holographic feeling I am looking for. But considering these can be found used for 60-120⏠itâs a solid budget/starter option for the Focals. And actually for almost any headphone, as my GO450 and GO1000 play well with everything I have tried them on Denon, Fostex, Audeze, Hifiman, HD6xx etc. For Focals Iâd stay away from the Geek Out 1000 (usually red coloured) model as its get loud too quick. Itâs really sad the Geek Out is not produced any more, maybe a steady revenue stream would have saved the company?
Focal Clear pairings pt4: Cavalli Tube Hybrid + Hegel HD12. Things are falling into place. I think itâs the best combo so far. And instantly I start thinking of better tubes
Hmm what to get?
Focal Clear pairings pt5: Chord Mojo. Highly enjoyable. There is something with the slightly grainy Mojo sound character that I really like together with the Clears. Soundstage is quite big with sounds coming in from around the head. Maybe a bit more authority in the bass department is needed, not sure need to compare with more amps & dacs.
Focal Clear pairings pt6: iFi Micro iDSD. Dual Burr Brown PCM1793 equipped DAC/AMP. Pretty good synergy to my ears. Enough weight to the sound, soundstage is ok and tonality is good. Somewhat similar grain/crisp as Chord Mojo but authority is better, likely since the iFi Micro iDSD has more power. Flip the Xbass switch for even more grunt. From what I have read the new iDSD Signature and Diablo are differently tuned than the old Micro iDSD silver, hopefully they play nice with Clears aswell. Still have at least 16 amp pairings to try out, this gonna take a whileâŠ
Focal Clear pairings pt7: THX AAA789 + Geek Out V2+ Infinity (ES9018AQ2M DAC). Great clarity and separation but something just sounds off with this combo. Itâs like parts of the midrange is sucked out, some sounds and instruments sound really flat and lack weight. A bit weird, enjoyable and not enjoyable at the same time. I think the THX Amp tech just doesnât pair well with the Clears. Anyway the THX amp is really nice with other headphones, so no worries.
Focal Clear pairings pt8: Chord Hugo. I like this pairing. Instruments have the proper weight and the sound is pleasant. I think 3D and soundstage might be improved with adding additional amplification. Like tubes or a coloured solid-state.
Focal Clear pairings pt9: Chord Hugo + Cavalli Liquid Carbon. Almost instantly when the music started I felt âI might be onto something hereâ. Instruments and sounds were more 3D and presentation was more live and realistic. Compared to some of the flatter âmusic pushed into your earsâ presentations from previous combos. I think the Liquid Carbon expands the Focal Clear sound like Iâve only heard tubes do before, but its still able to maintain the punch and authority of a solid-state. To my ears this is the best combo for the Clears so far. Letâs see which of my DACs work best with the Clears and Liquid Carbon, more on that laterđ
Focal Clear pairings pt10: Chord Hugo + Eddie Current ZDT Jr (Laconic Night Blues Mini). This is the way
Another favourite combo. ZDT Jr makes the Clears sing. The sound reminds of the Liquid Carbon but slightly sweeter, less grainy without getting tube mushy or losing dynamics. And then the 3D-ness of tubes, instruments and sounds can be felt rather than just projected from distance, everything I play just sounds so nice. A âjust one more tuneâ moment. It makes me want to turn up the volume and I can play this combo for hours without ear fatigue. Once you hit that tube magic synergy between amp and headphone, life is good. My ZDT Jr is the revised version with steelband wrapped around the main transformer, but it did have some hum issues with the stock tubes, louder in the right channel. Rotating tubes left/right did not help. Tried with some GE 5654W as the front tubes, hum is more or less gone with the Clears! Tried 2nd pair of Voshkods and those are silent as well. Weird that switching left/right did not help but replacing tubes did. Need to investigate more but Iâm not a tube doctor. So anywayâŠamazing amp, no hum, just had bad stock tubes (the smaller Voshkod 6ZH1P ones). Although still some hum with 124db inears, which is expected as itâs the same even with many solid state amps. Letâs see if I can fix it with some additional modding. I have some Woremor WMF-200 shielding which was suggested at some forums.
Focal Clear pairings pt11: HRT Headstreamer. A combined DAC/AMP using Burr Brown PCM1793. Needed some perspective after enjoying the ZDT Jr for a few days. Initially I felt this is surprisingly good with nice dynamics and detail, considering the price (140âŹ) and itâs age. But after a while the Headstreamers limitations start to shine through. Volume is not an issue but compared to previous devices the sound is quite harsh sometimes. Imaging, soundstage, tonality etc is also better on most or probably all of the previous amps/dacs.
To be continuedâŠ
