Experience, frames of reference, cut through the bullschiit. Those are the 3 things that will best help you decide how to proceed. You don’t know what you don’t know, right? So you gotta go find out first hand.
One of the biggest problems I see is that people take a reviewer’s words as gospel, or worse… science. It’s not. It’s just opinion.
Forums, Reddit, YouTube and the like: Useless. These will do absolutely nothing for you if you have no frame of reference for the items you’re trying to get information about. The only way to combat that is by experiencing different headphones.
I can tell you all day long how the Ultrasone Edition 10 is the best headphone ever, but does that help you? No. You haven’t heard it. Unless I directly compare how it is different to something you’ve heard, how can you possibly know if I’m giving an honest opinion or just blowing smoke?
If a reviewer cannot compare one item to another (preferably to a well known baseline item), then it’s not really a review, it’s just an advertisement. That’s why I disregard any review immediately if they can’t give me at least that.
Getting experience takes time and effort. There is no shortcut. Try everything you can get your hands on. It’s a lot more difficult to do that thanks to Covid, but, if/when things get back to normal then go to meets and events, find a local retailer that sells items you’re interested in, rentals, loaners from forums, etc. I don’t advocate using a return policy as a method to demo gear, but it is important to purchase from places that do offer a bit of a safety net.
In the mean time, here is what I would do. Take a headphone you already have (even if it’s one you hate), and go look for audiophile reviews about it. Look for reviews that match your own opinion of them. You aren’t trying to see if your opinion is valid, you’re trying to see who reviews headphones in a way that indicates you have something in common regarding preferences, hearing, and so on. Before you take advice from any review, you need to know that your opinions and preferences have something in common. If it doesn’t, chances are you might not want to consider their reviews valid for you.
(Avoid places like Cnet, Verge, Forbes, or Consumer Reports crap, because those guys couldn’t find their ears with both hands and a map.)
For example, Zeos. He’s popular. While I was trying headphones and comparing them to his reviews I discovered that he likes treble centric headphones more than I do, and he prioritizes qualities of headphones far differently than I do. He seems to be mostly concerned with tone. He is also usually pretty good at describing if something is uncomfortable.
Beyond that we have nothing in common. I think his opinions and preferences also change every time the wind blows. (He’s also probably mostly deaf, and in it for the money at this point, but… that’s a different conversation.)
Other people’s reviews I can trust because I know HOW their preferences differ from mine. @Torq for example - if he says anything about tone, dynamics or resolution of a system, 95% chance I will agree. If he says a system isn’t quite bright enough, I’m already running for the hills. If he says something is sibilant, my head already exploded. He can take more treble and air than I can. Knowing this, I can apply it to his reviews and opinions, and come out fine.
The common denominator here is: Experience and frames of reference. Everything about this hobby is complete crap until you can establish those two.
… Even then, you’ll find 60% of the stuff is still crap, 30% doesn’t pertain to you, and 10% is useful. It’s just how it is.
Maybe a good place to start is finding a headphone that is very popular and well-reviewed, like the HD650 or Sundara, and see what you like about it. There are so many reviews about those headphones out there, finding your own preference with those might be the best way to go.
Maybe a dac/amp like the Asgard 3 w/ AK4490 card as a starting point. Or the iFi Zen dac/amp. Or JDS Element.
The headphone is the most important part though. The DAC and amp do add flavor, but not like a headphone will.
Identify what you want to improve on. If your headphones fatigue you, is that from comfort or sonics? Is everything too “in your head” and you wish it had better staging or sense of space? Identify the issues. Go from there.
Find suitable upgrade item. Do your research, find something that best addresses the problems. Try not to get caught up in flavor of the month gear.
Rinse and repeat.
