Hello,
This is a reply to both previous replies.
Hottyson: I have yet to look into HeSuVi. Like I said, I currently use EAPO, and Peace, and have separate peq settings for the headphones I listen to most. This is a stupid question, as I have not investigated your article that you referenced yet, but, is there a way to have your pc automatically switch peq settings based on which headphone you plug in?
For just pc sound, which I don’t care about, I just use Peace High/Low boos setting. But, I also have 3 headphone amps, two solid state and use the xlr connections on them, and one tube preamp, that is used single ended. Is there such thing as a pc setup that will recognize what source I want to use by plugging in my headphones to one of these 3 amps? Currently, although I am satisfied with the sound per se, I have to manually change my sound source in settings to the correct headphone amp, and then also manually choose the eq setting in Peace. Yes, doable, but, cumbersome. I can’t imaging a way that I say: “Oh, I want to listen to quality music now, and just plug my headphones of choice in and be done with it.” I may be wrong here, as like I said, I did not read the article yet.
NickZ: Yes, I love the Grado house sound. It is not a preference for most audiophiles, and why that is I am not quite sure. I guess people like spending 5K on headphones, thinking that by doing that, they are getting the best sound. Sound quality is a “perceived” notion, and as such, my first good sounding set of headphones were my SR80 originals. Since then, I know they have gone through various incarnations. I liked the look of the 325x, but was disappointed to see that oratory1990 did not have measurements on them. Actually, I have another set of headphones that he didn’t have the measurements for, and I actually sent them to him for measurement/settings/graphs, etc… Took quite a long time as he is quite far from me, but, I was willing to wait. This time, of course I have that option again, but so many articles have said they sound like the Hemp or 325e, that I just experimented with those. Sure, not a totally accurate measurement, but, I can live with it.
Thanks to all of you.
Viper
