Might be selling my Satin blue mini as the WA33 seems like all I need. Will be putting a few other electronics up as well.
Never hurts to have a capable spare. The GSX-mini is a great unit.
I have a Satin Grey one.
The AC Infinity S6 component cooling fan fits great above the GSX-mini. Justin from Headamp checked this out and noted how it helped keep operating temps down, especially in an enclosed area. Very quiet at the lower fan speeds.
I don’t want to sell the mini but I might have too.
Hope you don’t have to, but crazy times are here…cheers…
BondDaBoom You know it ; )
I hope you do not have to move it.
It is just a fantastic solid-state amp
Thinking, keep the mini and Ares 2 just in case. My back up system incase hugo tt2 and wa33 break. Plus I just found out tubes are expensive for WA33.
What kind of tubes for WA33?
At least you can still find matched sets, I used the Sovtek in my Guitar AMP from time to time.
I have bit of tube tending with few Power Tubes: El34, EL84, KT66, 6v6 and 6L6. On the Preamp/Reverb/Tremelo tubes 12AX7, 12AU7 and, 12AY7 in my current guitar amps. Hence Amp & Sound Headphone amp was my best pick.
I am seeting on Reverb 4 pack or 2a3 are $209 https://reverb.com/item/11962163-plate-current-matched-quad-4-sovtek-2a3-triode-power-vacuum-tubes
Also and 8 Pack is $409 https://reverb.com/item/11962172-plate-current-matched-octet-8-sovtek-2a3-triode-power-vacuum-tubes
How is it going with the Lite?
Im brand new to the tube world. Was always ss person. I’m confused by all the tube brands and what works with a particular tube amp. When I get a chance I’ll post the tubes the WA33 came with.
It is an interesting rabbit hole to run down.
Modern tubes are mainly from 4 manufacturers, note you will see multiple bands. There are still a few boutique manufacturers left as well.
New Sensor Corporation US company - Made in Russia
https://shop.ehx.com. We know them as Electro-Harmonix who early on was known for the Big Muff, Electic Mistress, Memory Man Guitar pedal fame.- Brand(s): Electro-Harmonix, Genalex, Mullard, Sovtek, Svetlana, and Tung-Sol
- OEM: SED, NEVZ-Soyuz, Vaco, and Voshod
JJ Electronic inc. Slovak Republic
https://www.jj-electronic.com/en/ -
Shuguang Electronics Group in China
- Brand(s): Shuguang, 天籁之音 Natural Sound, 珍品 Treasure, 复克 Shuguang Electrical Replica
http://www.shuguangdianziguan.com
Names who buy tubes from the above vendor and rebrand:
- Groove Tube. -Fender Corp
- Mesa Boogie
- Telefunken
- Peevy
- Tube Amp Docter Brand TAD
Small guys like
KR Audio in Czech Republic
http://www.kraudio.com -
Emission Labs
http://www.emissionlabs.com/html/products/products.html -
PSVANE in China
http://en.psvane.com -
Tianjin Quanzhen Electron Tube Company
http://www.tube-fullmusic.com -
Takatsuki Electric Industry Company
https://www.takatsuki-denki.co.jp/en/index.html -
Sophia Electic https://sophiaelectric.com/products/pages-se-princess-300b
Then you have tubes from yesteryear in two forms, lots of brands here. This is the land of Audiophiles. I will stop there:
- NOS New Old Stock
- Used tube
Thanks for asking!
It’s a fun little amp. Plenty of power, and I’m perceiving more dynamics. But that could easily be something like increased bass or maybe even slower decay. But I’m perceiving it as increased dynamics to let’s go with that. It’s very lively and overall is a fun listen.
My comparator right now is a SPL Phonitor e, so any warmth or color is likely to be very prominent. The SPL is amazing though, so I’m sort of setting it up for failure. I’m still playing with it, but as of right now I’m very pleased with it.
As you know it’s light on features (balanced HP outputs or inputs most obviously), so I get why more people don’t choose this in the price range. But for sound quality I think it’s great at $500.
Very Nice. I sound similar to what I was hearing with it bigger middle brother vs the Phonitor x . as you know the x= e in power since it same amp minus VU meters.
This is what I tell myself everytime I enviously look at those VU meters and larger case. ![]()
I saw 2A3 and 6C45. The 6C45 is a new one on me. Might want to verify that one with the manufacturer. It’s not in my Tube Lore or Tube sub books.
Good variants for the 2A3 are 2A3A and 5930 per my sub book. I saw 2A3 was $60 each NOS at where I get my tubes. Kinda pricey indeed.((esrcvacuumtubes.com)).
I would make contact with the unit manufacturer and see if there any other substitutes they would recommend. Keep a set of spare tubes as well.
I just bought a second AS Kenzie and stayed with the same type of amp for tube standardization. My Encore and Kenzie use the same tubes, and tube substitutes. I have a couple of hundred tubes for my various devices. Luckily, they are all fairly inexpensive, or were when I acquired them.
Oh … while I’m not sure why this is in the GS-X Mini thread … the 2A3 tubes used by the WA33 get expensive fairly quickly.
The good ones, at least.
The $250 sets of 4 you’ll generally see (especially on music/pro/guitar fora) … are typically not as good as the stock tubes, let alone the other options.
If you don’t want to step up to a matched quad of at least the KR Audio 2A3s, then I’d suggest sticking with what you have for a bit. Though the NOS RCA 2A3 monoplanes are really the target here (happily my WA234 MKII MONO only need a pair of those).
Is the 6C45 a new production type tube. Don’t see any NOS listings in my tube reference books.
***Didn’t see the minor off-topic drift worthy of its own thread.
We should break this off into a forum thread, I looked. I have only seen on the forum talk about the tube you collect.
On your question, 6C45 was initially built for Soviet military communications and radar applications, the leading supplier is Sensor Corporation, via the Sovtek brand. The DIY audio community is who re-discovered this tube for pre-amp use. Much lower distortion then a 12AX7 with gives you much lower noise floor.
