Thank you very much! ![]()
Gotcha! I knew what ya meant ![]()
Glad you’re finding the presets useful!
Focal Bathys on Bluetooth. looking for an EQ to make them sound dead neutral (perfectly aligning with the target frequency response of the BK 5128) . I want it to sound as accurate to the BK 5128 target response it can be.
Hi Listener, thank you so much for doing these!
Any chance you can do the Hifiman HE560 (V4)?
Andrew already measured the HE560 on a recent video, but did not upload any EQ for it. I also noticed the measurements are similar to the HE6SE v2 on Oratory’s database, but that did not specify which version HE560 it was.
I would advise against only taking results from one head.
Focal Bathys
Confidence: MEDIUM
Uses data from GRAS KB50xx, B&K 5128, and HeadAcoustics HMSii.3
Preamp: -5.0 dB
Filter 1: ON LSC Fc 105 Hz Gain -0.5 dB Q 1.000
Filter 2: ON PK Fc 350 Hz Gain -2.4 dB Q 0.700
Filter 3: ON PK Fc 850 Hz Gain 6.0 dB Q 1.400
Filter 4: ON PK Fc 1100 Hz Gain -2.0 dB Q 2.000
Filter 5: ON PK Fc 2450 Hz Gain 2.5 dB Q 3.000
Filter 6: ON HSC Fc 3000 Hz Gain 0.5 dB Q 0.700
Filter 7: ON PK Fc 3200 Hz Gain -1.8 dB Q 2.000
Filter 8: ON PK Fc 5000 Hz Gain 6.3 dB Q 1.400
Filter 9: ON PK Fc 10000 Hz Gain -6.3 dB Q 1.000
Adjust band 1 for overall bass
Adjust band 2 for warmth
Adjust band 6 for overall treble
Adjust band 9 for sharpness
5128 Only
Preamp: -5.2 dB
Filter 5: ON PK Fc 2550 Hz Gain 5.0 dB Q 3.000
Filter 6: ON HSC Fc 3000 Hz Gain 1.0 dB Q 0.700
Filter 8: ON PK Fc 5000 Hz Gain 4.8 dB Q 1.400
Filter 9: ON PK Fc 10000 Hz Gain -4.0 dB Q 1.000
Filter 10: ON PK Fc 6000 Hz Gain -2.0 dB Q 4.000
Unfortunately I don’t have much data at all for this headphone
Confidence rating will be extremely low for that reason
Hifiman HE-560 v4
Confidence: EXTREMELY LOW
Uses data from B&K 5128
Preamp: -6.0 dB
Filter 1: ON LSC Fc 95 Hz Gain 6.0 dB Q 0.700
Filter 2: ON PK Fc 2100 Hz Gain 6.4 dB Q 1.400
Filter 3: ON PK Fc 4000 Hz Gain -3.0 dB Q 1.400
Filter 4: ON HSC Fc 5000 Hz Gain 1.2 dB Q 0.700
Filter 5: ON PK Fc 10000 Hz Gain -6.0 dB Q 1.000
Filter 6: ON PK Fc 1050 Hz Gain -0.8 dB Q 2.000
Adjust band 4 for overal treble
Adjust band 5 for sharpness
Thank you! I was mostly trying to dial in the bass and 2-4kHz range, as it just did not sound that natural with my previous EQ settings. But adjusting your settings in that area did the trick!
Hey Listener,
Thanks so much for the help! It sounded mostly how I wanted, and with a couple tweaks of the different frequencies I got it there! Super helpful!
Hey Listener!
Once again, I’m inquiring about another EQ! could you possibly do a focal bathys eq as close to the most recent harman target? That would be very helpful! trying to figure out my listening preferences!
Thanks, Camí
Focal Bathys - EQed to Harman 2018 only
Preamp: -3.9 dB
Filter 1: ON PK Fc 200 Hz Gain 1.4 dB Q 1.000
Filter 2: ON PK Fc 385 Hz Gain -3.8 dB Q 0.300
Filter 3: ON PK Fc 850 Hz Gain 7.0 dB Q 1.700
Filter 4: ON PK Fc 1175 Hz Gain -2.0 dB Q 3.000
Filter 5: ON PK Fc 2300 Hz Gain 4.2 dB Q 2.400
Filter 6: ON PK Fc 2750 Hz Gain -1.8 dB Q 3.000
Filter 7: ON PK Fc 3850 Hz Gain 4.0 dB Q 5.000
Adjust band 1 and 2 for warmth
Adjust band 3 and 4 for midrange fullness
Adjust bands 5, 6, and 7 for upper midrange structure and clarity
Hifiman Arya Organic (inspired by the new video from BadSeedTech)
Confidence: MEDIUM
Uses data from GRAS KB50xx and B&K 5128
Preamp: -3.3 dB
Filter 1: ON LSC Fc 80 Hz Gain 3.5 dB Q 0.500
Filter 2: ON PK Fc 95 Hz Gain -1.2 dB Q 1.400
Filter 3: ON PK Fc 300 Hz Gain -1.5 dB Q 0.800
Filter 4: ON PK Fc 1725 Hz Gain 3.2 dB Q 2.700
Filter 5: ON PK Fc 2225 Hz Gain 2.1 dB Q 5.000
Filter 6: ON PK Fc 3000 Hz Gain -2.4 dB Q 1.800
Filter 7: ON HSC Fc 6300 Hz Gain -6.0 dB Q 0.800
Filter 8: ON PK Fc 6500 Hz Gain -0.2 dB Q 2.000
Filter 9: ON PK Fc 11000 Hz Gain -1.0 dB Q 2.000
Adjust band 2 for midbass boom
Adjust band 5 for ear gain/clarity
Adjust band 7 for overall treble
Adjust band 9 for sizzle/shimmer
Thanks so much, sounds mostly neutral and tonally balanced to my ears!
Hi for the final time!
The last thing EQ I ask for is what you think would make the Bathys sound the best they can possibly be. My preferences are in terms of tuning seem to be around neutral, however I’m quite interested to see what an expert like you would improve about the FR of the Bathys! Thanks!
The first EQ I made would be the one I choose as a baseline, and then I would make preference adjustments as needed from there (likely reducing bass and > 8 kHz treble even more).
Hi Listener,
These EQ profiles are awesome. Very helpful as starting points to tweak to personal taste. I find I’m surprisingly changing very little on the ones I’ve tried other than reducing bass filters on all of them. I find that preference curves are way too “bassy” for me. I’d love a Profile for the Focal Elex. For such a popular headphone, I’ve found very few online EQ profiles to try. I’d like to add my thanks for the incredible work to compile all these profiles. Bravo!!!
Focal Elex
Confidence: LOW
Preamp: -6.7 dB
Filter 1: ON PK Fc 20 Hz Gain 4.0 dB Q 0.600
Filter 2: ON LSC Fc 90 Hz Gain 2.8 dB Q 0.700
Filter 3: ON PK Fc 185 Hz Gain -2.0 dB Q 0.600
Filter 4: ON PK Fc 630 Hz Gain 0.8 dB Q 1.000
Filter 5: ON PK Fc 1500 Hz Gain -2.8 dB Q 1.100
Filter 6: ON PK Fc 2100 Hz Gain 1.2 dB Q 3.000
Filter 7: ON PK Fc 2700 Hz Gain 1.8 dB Q 1.900
Filter 8: ON PK Fc 3550 Hz Gain -1.8 dB Q 3.000
Filter 9: ON HSC Fc 4500 Hz Gain 1.0 dB Q 0.800
Filter 10: ON PK Fc 4800 Hz Gain 5.0 dB Q 2.000
Filter 11: ON PK Fc 5900 Hz Gain -2.0 dB Q 2.000
Filter 12: ON PK Fc 9000 Hz Gain -3.5 dB Q 2.000
Adjust band 2 for overall bass
Adjust band 3 for warmth
Adjust band 5 for punch/viscerality
Adjust band 7 for ear gain
Adjust band 9 for overall treble
Adjust band 10 for grit
Adjust band 12 for shimmer/sizzle
Beautiful! Thanks, Listener.
Can u make for OG HD800 , HD600 og hifiman He1000v2 stealth to ? ![]()
Hi there! Could you make an EQ profile for Truthear Zero (blue)?
@Wild-ArT Per the post I am currently replied to from @Vilmalith, I can’t find any HE1000v2 Stealth measurements, sorry.
For the HD 800, I’m going to say following the EQ for the HD 800 S from the first post in this thread is what you should do, and then manually lower around 6 kHz with a Q of 2 until you are happy with the sound (in addition to the other prescribed adjustments).
Sennheiser HD 600
Confidence: LOW
CAUTION: THIS HEADPHONE VARIES A LOT BASED ON PAD CONDITION
Uses data from GRAS KB50xx, B&K 5128, B&K 4128, and HeadAcoustics HMSii.3
Preamp: -10.8 dB
Filter 1: ON PK Fc 20 Hz Gain 5.5 dB Q 1.000
Filter 2: ON LSC Fc 65 Hz Gain 5.5 dB Q 0.700
Filter 3: ON PK Fc 78 Hz Gain 1.0 dB Q 2.700
Filter 4: ON PK Fc 195 Hz Gain -3.4 dB Q 0.480
Filter 5: ON PK Fc 725 Hz Gain 1.3 dB Q 0.700
Filter 6: ON PK Fc 1500 Hz Gain -3.0 dB Q 0.500
Filter 7: ON PK Fc 2000 Hz Gain 0.3 dB Q 3.000
Filter 8: ON PK Fc 3333 Hz Gain -2.4 dB Q 2.700
Filter 9: ON PK Fc 5000 Hz Gain 1.0 dB Q 2.000
Filter 10: ON HSC Fc 7000 Hz Gain -1.5 dB Q 0.900
Filter 11: ON PK Fc 8000 Hz Gain -2.0 dB Q 2.000
Adjust band 1 for sub-bass
Adjust band 4 for warmth
Adjust band 10 for overall treble
Adjust band 11 for sharpness
