Headphones.com EQ Repository & Request Thread
Truthear Zero
Confidence: VERY LOW
Uses data from B&K 5128
Preamp: -3.0 dB
Filter 1: ON PK Fc 20 Hz Gain 3.0 dB Q 0.700
Filter 2: ON LSC Fc 135 Hz Gain -3.7 dB Q 0.900
Filter 3: ON LSC Fc 240 Hz Gain 1.5 dB Q 0.700
Filter 4: ON PK Fc 425 Hz Gain 2.8 dB Q 0.500
Filter 5: ON PK Fc 1500 Hz Gain -1.8 dB Q 1.000
Filter 6: ON PK Fc 3000 Hz Gain 0.7 dB Q 1.400
Filter 7: ON PK Fc 4850 Hz Gain -4.0 dB Q 2.000
Filter 8: ON HSC Fc 8000 Hz Gain -0.5 dB Q 0.700
Adjust band 2 for overall bass
Adjust band 4 for warmth/cuppiness
Adjust band 5 for “dynamics” or female vocal presence
Adjust band 7 for crispiness
Adjust band 8 for overall treble
Requesting Drop + Grell OAE1 :grimacing:
Can u make a EQ profil for HD600 to sound like 6xx? :sweat_smile:
Hahaha, I’d say just reducing a bit of treble with a shelf around 2500 Hz and a Q of 0.4 should accomplish that fairly easily.
Sennheiser HD 620S
Confidence: LOW
Uses data from GRAS KB50xx, B&K 5128, B&K 4128, and clone KB006x
Preamp: -2.5 dB
Filter 1: ON LSC Fc 82 Hz Gain 3.2 dB Q 1.400
Filter 2: ON PK Fc 125 Hz Gain -2.7 dB Q 1.400
Filter 3: ON PK Fc 227 Hz Gain 3.3 dB Q 1.800
Filter 4: ON LSC Fc 750 Hz Gain -1.2 dB Q 2.000
Filter 5: ON PK Fc 1650 Hz Gain 1.5 dB Q 1.400
Filter 6: ON PK Fc 2700 Hz Gain -2.2 dB Q 2.700
Filter 7: ON PK Fc 4500 Hz Gain 2.0 dB Q 2.000
Filter 8: ON PK Fc 9000 Hz Gain -2.0 dB Q 2.000
Filter 9: OFF LSC Fc 105 Hz Gain 0.0 dB Q 0.700
Filter 10: OFF HSC Fc 2500 Hz Gain 0.0 dB Q 0.400
Adjust band 2 for mid-bass bloom
Adjust band 7 for grit
Adjust band 8 for sharpness
Adjust (and enable) band 9 for overall bass
Adjust (and enable) band 10 for overall treble
Wanted to ask for this one! Thank youuu :laughing:
No problem! I already had one made for my forthcoming article anyway. :slightly_smiling_face:
Requesting Drop + Koss ESP/95X
Drop x Koss ESP95x
Uses data from GRAS KB50xx (Thanks to Oratory1990 for the measurement)
Preamp: -6.4 dB
Filter 1: ON LSC Fc 90 Hz Gain 6.4 dB Q 0.700
Filter 2: ON PK Fc 1150 Hz Gain -3.6 dB Q 1.400
Filter 3: ON PK Fc 2200 Hz Gain 3.2 dB Q 2.000
Filter 4: ON PK Fc 3500 Hz Gain -1.5 dB Q 3.000
Filter 5: ON HSC Fc 4000 Hz Gain 6.0 dB Q 0.700
Filter 6: ON PK Fc 4200 Hz Gain 6.0 dB Q 1.800
Filter 7: ON PK Fc 5500 Hz Gain -6.4 dB Q 1.600
Filter 8: ON PK Fc 7250 Hz Gain 3.0 dB Q 2.000
Filter 9: ON PK Fc 11500 Hz Gain -7.0 dB Q 1.400
Adjust band 1 for overall bass
Adjust band 2 for honk
Adjust band 3 and 4 for ear gain and intelligibility
Adjust band 5 for overall treble
Adjust band 6 for scratchiness
Adjust band 7 for grain
Adjust band 9 for shimmer
Oooooooook. So. This headphone is Weird™
like… really weird
I have a few measurements now and can provide a preset, but the positioning sensitivity on this design is fairly high, so please make sure your ear is sitting towards the rear of the ear cup/the headphone is pushed forward and low on your head. If not, this likely won’t sound very good.
Hell, even with this preset it probably won’t sound that much better.
I have to say, this is a design I think is fundamentally flawed in numerous ways, and if you have this headphone I earnestly recommend trying to return it and buying something more normal. This preset won’t match the “target” precisely, because the unit I have on hand sounds bad if I don’t go quite a bit further with the upper midrange cuts. So keep that in mind; you will need to adjust manually above 2 kHz or so.
That said, here’s the preset:
Grell OAE-1
Confidence: LOWEST
Uses data from 5128, Clone KB50xx, Clone KB006x
Preamp: -6.0 dB
Filter 1: ON PK Fc 72 Hz Gain 2.0 dB Q 1.400
Filter 2: ON PK Fc 150 Hz Gain -7.2 dB Q 0.200
Filter 3: ON PK Fc 650 Hz Gain 3.0 dB Q 0.900
Filter 4: ON PK Fc 925 Hz Gain -2.0 dB Q 2.400
Filter 5: ON PK Fc 1300 Hz Gain 1.4 dB Q 1.000
Filter 6: ON PK Fc 3200 Hz Gain -2.0 dB Q 2.000
Filter 7: ON PK Fc 4750 Hz Gain -9.5 dB Q 1.800
Filter 8: ON PK Fc 5900 Hz Gain 10.0 dB Q 3.200
Filter 9: ON HSC Fc 9900 Hz Gain -5.0 dB Q 2.000
Filter 10: OFF LSC Fc 105 Hz Gain 0.0 dB Q 0.700
Filter 11: OFF HSC Fc 2500 Hz Gain 0.0 dB Q 0.400
Adjust filter 6 for raspiness
Adjust filter 7 for glare/scratchiness
Adjust filter 8 for fixing the ridiculous hole in this area
Adjust filter 9 for adjusting the balance between mid treble and upper treble
Adjust (and enable) filter 10 for overall bass
Adjust (and enable) filter 11 for overall treble
Good luck, and please please make your own adjustments in the treble above 2 kHz and bass. It is necessary.
Would it be possible to do 3 different q values at the same freq, just to educate us how they affect the respons.? Eager to learn.
cheers
Mike
From the JRiver MediaCenter Wiki:
Green line is flat at 99 dB.
Red, blue, and gold lines all show peak filters centered at 500 Hz, +6 dB gain, with varying Q factors. The red line is for Q=1, the blue line is for Q=2, and the gold line is for Q=5.
So, as you can see, higher Q provides a narrower peak and lower Q provides a broader peak. Q doesn’t change the height (gain) just the range of frequencies influenced.
Ha ha! Thanks for the cautions. I’m not convinced Harman is an appropriate target for these, I just want to experiment. I think EQing them is going to be a challenge as they seem to be sensitive to both individual HRTF and placement.
Sure I can see doing that if this was my only headphone. But since I own a few better choices if I want to maximize, say, timbre or detail, I’m going to keep these for their unique staging.
Looking forward to a Headphones.com review, even if it is negative.
Thanks for the graph, Lou
Mike
Which pads did you use for the Meze Empyrean II? The Duo leather/Alcantara or the Angled Alcantara?
Whichever pads Resolve liked, think it was angled Alcantara.
If you have the opportunity try the hybrid pads, for me the best pad combination with the Empyrean II:
Thanks! I will definitely check these out… once my hobby budget recovers. :smirk:
It looks like his EQ is based on what he calls the hybrid pads, which Meze calls the Duo Pads. Sorry I should have thought to check Resolve’s review.
Which is good because your EQ preset sounds great on the Duo pads. On the Angle Alcantra… not so much. Too lean/clinical for me. :sunglasses:
Ah okay, it was whichever pad he liked so Duo it is then!
