Headphones.com EQ Repository & Request Thread
Got inspiration from @Nuance to do a preset for these.
Audeze Maxwell
Confidence: MEDIUM LOW
Uses data from B&K 5128 and clone GRAS KB50xx
Preamp: -3.8 dB
Filter 1: ON PK Fc 20 Hz Gain 3.0 dB Q 3.000
Filter 2: ON PK Fc 140 Hz Gain -1.6 dB Q 1.000
Filter 3: ON PK Fc 220 Hz Gain 0.8 dB Q 2.000
Filter 4: ON PK Fc 400 Hz Gain -1.0 dB Q 2.000
Filter 5: ON PK Fc 850 Hz Gain 0.8 dB Q 1.400
Filter 6: ON PK Fc 7000 Hz Gain 6.0 dB Q 2.000
Filter 7: ON PK Fc 9000 Hz Gain -4.0 dB Q 1.400
Filter 8: OFF LSC Fc 105 Hz Gain 0.0 dB Q 0.700
Filter 9: OFF HSC Fc 2500 Hz Gain 0.0 dB Q 0.420
Adjust band 1 for sub-bass
Adjust (and engage) band 8 for overall bass
Adjust (and engage) band 9 for overall treble
If anyone knows the Freq/Q values for the Maxwell’s in-built EQ app, would be happy to do one for that too.
You’re literally the best dude! Thank you!
Thanks for your hardwork with these profiles. It’s a great resource. I’ve got a bit of a hard one - B&W P9.
Thanks either way.
Hi Listener, Can you please do DT990 pro 80ohm? Thanks in advance!
Hello! Thank you for your unprecedentedly helpful and charitable work!
I’m sorry if this inquiry is not exactly on topic here, as I am not asking for a complete EQ preset (as I’m not yet sure if I’m going to keep or sell the IEMs). Though maybe it would make sense to make one anyway even before anyone asks for it… Whatever.
May I ask you how would you address the upper treble of the new DUSK specifically? Would you say a peak filter at 14000 kHz with Q value of ~2 (basically what Crinacle himself have used) would be effective enough? How much should I expect that elevation (it’s a resonance as per my understanding?) to shift in frequency range due to a fit/insertion depth variation?
Between manual sine sweep and/or pink noise based equalisation proving dishearteningly hard for me to do; and aiming for elimination of all perceived peaks & dips, i.e. a perceived equal loudness itself being not exactly the right approach anyway as far as I understand it… I’m afraid I can’t count on that method.
Thank you for your patience!
Oh, and just one more - Audio Technica wp900. I’ve tried doing it myself, and it does improve it a little. Just seeing if your expertise can make it better. Also your preset for the Th900 mk2 sounds wonderful. To the point where i won’t sell them. Thanks again.
Beyerdynamic DT 990
Confidence: LOW
Uses data from GRAS KB50xx and KB006x, B&K 5128, and HeadAcoustics HMSii.3
Preamp: -7.5 dB
Filter 1: ON PK Fc 20 Hz Gain 8.0 dB Q 0.200
Filter 2: ON PK Fc 20 Hz Gain 3.5 dB Q 1.400
Filter 3: ON PK Fc 150 Hz Gain -2.2 dB Q 1.000
Filter 4: ON LSC Fc 280 Hz Gain -4.0 dB Q 0.800
Filter 5: ON PK Fc 675 Hz Gain 1.5 dB Q 2.000
Filter 6: ON PK Fc 4200 Hz Gain 2.4 dB Q 2.000
Filter 7: ON PK Fc 8650 Hz Gain -10.0 dB Q 1.200
Adjust band 2 for sub-bass extensions
Adjust band 6 for scratchiness
Adjust band 7 for sibilance
Adjust and engage band 8 for overall bass
Adjust and engage band 9 for overall treble
Yep, I’d put a peak filter in roughly the same spot (you should check by ear while listening to music, though) and cut to taste.
Can’t find any measurements for it, sorry.
One last one from me. Its a relatively obscure one - Audio Technica ATH 2000 Ti. Heres a measurement i found. I tried my own eq and the results are a little improvement. Just seeing if you can work a little magic. Cheers!
Uhh, this measurement isn’t labeled so I don’t know which trace is the headphone, what rig it was measured on, what compensation was used, or what circumstance it was measured in.
Sorry, this is not enough to go on.
One for the Sony WH-1000XM4 would be great if possible - thanks in advance!
Highly recommend personalizing this one above 1 kHz, as results across heads were very variant.
Sony WH-1000XM4
Confidence: LOW
Uses data from B&K 5128, GRAS KB50xx, and HeadAcoustics HMSii.3
Preamp: -3.4 dB
Filter 1: ON PK Fc 127 Hz Gain -6.0 dB Q 0.800
Filter 2: ON PK Fc 395 Hz Gain 1.5 dB Q 2.000
Filter 3: ON PK Fc 1000 Hz Gain 1.8 dB Q 2.000
Filter 4: ON PK Fc 2450 Hz Gain 4.0 dB Q 1.200
Filter 5: ON PK Fc 4000 Hz Gain -1.2 dB Q 1.400
Filter 6: ON PK Fc 9000 Hz Gain -3.0 dB Q 1.400
Filter 7: ON LSC Fc 105 Hz Gain -0.5 dB Q 0.700
Filter 8: ON HSC Fc 2500 Hz Gain -0.5 dB Q 0.420
Adjust band 4 for clarity
Adjust band 7 for overall bass
Adjust band 8 for overall treble
Hi,
I own both the Beyerdynamic DT 700 and 900 Pro X and would like to test your eq suggestion.
Hi listener, I would first like to thank you for the eqplayground website its really awesome, but I wanted to know where did you find or get the clone kb50xx measurement of the maxwell?
I would love to also obtain it as I would like to compare the fr across different measurement heads, thank you :smiley:
Thank you so much Listener for the incredible work you put into this thread! I would love to try one of your presets, the feedback has been great.
I recently picked up a pair of Sennheiser HD 700, do you think youd be able to make a preset? :slight_smile:
Hey! Sorry I’ve been slackin :smiley:
Beyerdynamic DT 700 Pro X
Confidence: LOW
Preamp: -4.4 dB
Filter 1: ON LSC Fc 82 Hz Gain 2.7 dB Q 1.100
Filter 2: ON PK Fc 150 Hz Gain -2.2 dB Q 1.000
Filter 3: ON PK Fc 256 Hz Gain 5.5 dB Q 1.400
Filter 4: ON PK Fc 1900 Hz Gain -1.8 dB Q 2.000
Filter 5: ON PK Fc 3200 Hz Gain 4.0 dB Q 3.000
Filter 6: ON PK Fc 8600 Hz Gain -4.0 dB Q 1.000
Filter 7: OFF LSC Fc 105 Hz Gain 0.0 dB Q 0.700
Filter 8: OFF HSC Fc 2500 Hz Gain 0.0 dB Q 0.420
Adjust band 5 for midrange clarity
Adjust and enable band 7 for overall bass
Adjust and enable band 8 for overall treble
Beyerdynamic DT 900 Pro X
Confidence: MEDIUM
Preamp: -4.1 dB
Filter 1: ON PK Fc 20 Hz Gain 2.1 dB Q 1.400
Filter 2: ON LSC Fc 90 Hz Gain 2.0 dB Q 1.000
Filter 3: ON PK Fc 230 Hz Gain -2.7 dB Q 0.500
Filter 4: ON PK Fc 1400 Hz Gain 1.8 dB Q 1.400
Filter 5: ON PK Fc 3200 Hz Gain 5.5 dB Q 2.000
Filter 6: ON PK Fc 6500 Hz Gain -6.0 dB Q 0.400
Adjust band 1 for sub-bass extension
My friend Ish has it on their squig.link!
Sennheiser HD 700
Confidence: MEDIUM HIGH
Uses data from GRAS KB50xx and two different HeadAcoustics HMSii.3 heads
Preamp: -7.1 dB
Filter 1: ON PK Fc 20 Hz Gain 8.0 dB Q 0.700
Filter 2: ON PK Fc 60 Hz Gain 3.5 dB Q 0.700
Filter 3: ON LSC Fc 105 Hz Gain -1.5 dB Q 0.700
Filter 4: ON PK Fc 190 Hz Gain -5.2 dB Q 0.500
Filter 5: ON PK Fc 1000 Hz Gain -0.9 dB Q 2.000
Filter 6: ON PK Fc 1950 Hz Gain 5.2 dB Q 1.000
Filter 7: ON PK Fc 3750 Hz Gain 2.5 dB Q 3.000
Filter 8: ON PK Fc 6350 Hz Gain -8.0 dB Q 2.400
Filter 10: OFF HSC Fc 10000 Hz Gain 0.0 dB Q 0.700
Adjust band 3 for overall bass
Adjust band 9 for overall treble
Adjust band 10 for overall air
IMPORTANT: Adjust band 8’s frequency and gain according to where you hear this peak. It will vary depending on your anatomy, and likely won’t show up with the exact same frequency or magnitude as the measurements on these heads, as even the data for these heads have a bit of variance in this region.
Also, please remember to report back with your thoughts on the presets, y’all! Definitely want to know how people are enjoying them, especially relative to other methods out there, if y’all are testing vs. eg Oratory or Jaakko’s settings.
