HiBy R6 2020 - DAP - Official Thread
If you’re looking for the official place to discuss the 2020 revision of the HiBy R6 DAP, this is it!
The R6 is, according to HiBy’s website, an Android lossless digital audio player featuring:
  • Dual ES9038Q2M DACs
  • A Snapdragon 660 SoC
  • A 5.0’’ 1080P large hi-res display
  • Open Android 9
  • MQA 16x unfolding
  • DSD512
  • 4GB RAM
  • 64GB internal storage
  • 3.5mm and 4.4mm balanced connectivity for both phone-out and line-out
  • 2-way Bluetooth™ 5.0 connectivity
It’s available for $799.00 USD.
I’ve spent the last couple of weeks with the R6 comparing and contrasting it to my existing equipment as well as to the iBasso DX300, so I thought I’d write up a quick review of my thoughts on the R6 itself, as well as a few comparisons to other pieces of equipment I have around.
Build
The first thing you’ll notice when holding the R6 2020 is the solid, sturdy build. It feels like it’s made of solid metal and feels great in-hand. The volume knob and each button are solid metal and feel like they’re indestructible (I did not test this theory).
The dedicated dual phone and line out outputs are a huge bonus. It’s really nice not to have to flip between phone out and line out in software when using it as a stand-alone DAC for an external Amp.
However, there is one area where I feel the R6’s build could be improved: the screen. Firstly, the nearly 3:4 aspect ratio of the R6 was very off-putting for me. While this could just be because I’m so accustomed to larger cellphones like the Pixel 4 XL, I felt that the screen space was not typically well-used, especially when watching videos. However, I suspect that if your sole use of this device is listening to music, this is likely not going to be an issue. What will likely be an issue on the other hand is the default scaling of the screen. Despite the screen being plenty bright, I found that the screen could be hard to see in bright sunlight due to the tiny scaling that is applied by default. The default scaling makes text hard to read even under the most ideal conditions, but as soon as there is any glare on the screen it becomes nearly impossible. This is easily remedied through the system settings but be warned that if you enjoy the default setting there is no way to get it back once you’ve changed it to one of Android’s defaults of “Small”, “Medium”, or “Large”.
Software
If you’ve ever used an Android phone or really any other Android DAP, you’ll likely feel right at home with the R6, but the fact that it’s Android 9.0 - a more recent version of Android than many other DAPs - is a real added bonus for those of us who are more accustomed to modern Android versions.
One of the nicest features of this device is that it comes with Google Play Store pre-installed - no need to install via APKPure or any other 3rd-party app installer. This helps to allow you to easily install your favorite streaming apps without any worries that they might have been tampered with. Unfortunately, I could not get all apps to work. Specifically, I found that Pandora and Hulu both had issues either opening (Pandora) or playing content (Hulu). I was able to successfully install, launch, and use Tidal, Spotify, Netflix, YouTube, YouTube TV, and Roon.
The pre-installed HiBy music app seems to work fairly well, but is a bit laggy when it comes to loading album artwork, especially compared to the Mango player that comes pre-installed on the iBasso DX300. I’m not sure if this is just because the R6 has less RAM or if it is something which could be fixed by a software update.
Sound Quality
This is where I feel the R6 really falls flat - especially when compared to the similarly-spec’d (but also more expensive) iBasso DX300.
Let’s start with the best of the R6 2020’s sound quality: the bass out of the R6 is great. It’s detailed, present, and adds just the right amount of dynamics to your music. It never felt muddy or unclear as I find bass sometimes can.
Mids
The mids of the R6 are very detailed, but I never felt overwhelmed by the details. It strikes a very good balance between detail and enjoyment by presenting the details to you and allowing you to find them, rather than shoving them in your face.
Treble
This is where the R6 2020 struggles the most. I’m not a treble-sensitive individual, but the treble on the R6 is harsh and grating even to my ears. It has detail, but it also has a sharpness that I couldn’t get rid of no matter how I tweaked the EQ. At no point in the entirety of my testing of the R6 alone was I able to listen for more than 20-30 minutes without the treble becoming fatiguing.
Furthermore, these issues plagued every mode of the device I tested, be it stand-alone as a fully-fledged DAP, as a USB DAC (using line-out to a Topping A90), as a USB DAC/Amp, as a Bluetooth DAC (using line-out to a Topping A90), or as a Bluetooth DAC/Amp. It’s really unfortunate that these issues exist, given how nice the bass and mids sound on this thing.
Conclusions
I won’t be keeping the R6 2020, due entirely to the treble issues. If it weren’t for the harsh treble, the R6 2020 would be a welcome addition to my collection, especially at its price point. If you have more skill with EQ than I do (which admittedly isn’t a very high bar) I suspect you may be able to get rid of the treble imbalance with the R6 2020, but for this reviewer it was not doable. It’s otherwise a great, truly portable device once you dial in the rest of the system settings to your liking.
“If it weren’t for the harsh treble”
What headphones/speakers were you using? I have used Sennheiser HD800s, already known for emphasized treble, and have had no difficulty. I have done AB testing between the Hiby and my RME ADI-2 running Genelec speakers and have failed to hear a difference. If anything the Hiby seems completely transparent.
Now I’m older so I can’t hear past 14khz. Your issue must be pretty far up in the highs, wondering if there are any measurements to check this.
I’ve been using the following with the R6:
  • HD6XX
  • HiFiMan Sundara
  • Focal Radiance
  • 64 Audio U12t
  • 64 Audio Tia Fourte Noir
The 6XX were the least problematic, but I still had issues - it’s possible the issues are over the 14kHz range, but I unfortunately don’t have the equipment to test that :frowning:
One day I hope to be able to provide more definitive answers by getting some measurement equipment but I’ve only just started looking into that particular adventure.
Just to confirm, @CrankyRat, are you talking about the R6 or the R6 2020 revision?
R6 2020 revision with Focal Radiance, Hifiman Ananda, HD800s, UM Mest, and Genelec speakers.
Interesting. I’ve been chatting with MusicTeck (who I bought the R6 from) and it’s possible that my unit is defective, so I’m going to be sending it back to them and see if there’s something wrong with it.
sigh the entire dap world needs more QC and product testing.
I can always recommend Cayin. Price/performance hits the spot in my opinion.
Of course, UI is not perfect either but the sound quality even for the little N3pro is amazing.
Also you have can have tubes!:ok_hand::wink:
I’ve actually been using the R6 2020 and the iBasso DX300 with my Cayin C9 and that thing sounds fantastic. I never fully realized just how important the amp stage is until I got the C9.
Not cheap though the C9😉
No, no it is not. But, for me, it’s 100% worth it.
Topic switch: My R6 2020 does not start on battery. The red light on power button pulsate. It does start plugged in but the power up time is really long.
Thoughts?
Open the settings menu, on the upgrade menu click the 3 dots on the top right, clear cache
Hey, thx for the thought. However, I’ve tried that.
I’m sending it back to China.
In my case it’s solved with that way…
Sorry, can’t help :pray:
Anyone have experience with the Hiby r6 pro and the 2020 version? Any improvements? If so, what? I have the r6 pro, just wondering where the improvements are.
Thanks!
How does r6 sound with hd800s? Is it any good?
I’m having some issues related to video streaming apps such as Netflix, HBO Go, Vevo, etc. They just crash every time when started. An error message apear in some of them (on Netflix the message error is 500.-1006), and some say that I have to activate the browser cookies (don’t have any idea of how to do that). Netflix is even worse, since it’s not available at the GooglePlay, so I’ve installed from APKMirror but also unsuccessfully. Don’t know if is something related to my country (since I can play YouTube and Tidal videos normally). Apparently the Android OS installed cannot change for developer mode and some resources are restricted. Don’t know if there is anyway to fix it.
Get this:
The first unit HiBy sent was defective. I sent it back and they sent a new one. But the operating system was in Chinese. I asked for it to be replaced but instead they tried to have me fix their problem. I tried in good faith to work with them (15 times with back-and forth emails), then asked that I send it in for them to fix. They offered this solution but then reneged, stating it was a" waste of time and money". So, 9 months and no music. Interestingly, I bought a Sony Walkman at the same time and I’ve been listening to it for 9 months, trouble free. (Also, it sounds really good!)
Unbelievable, but I just found a company that has more HS customer service than my cable company.
Does the treble fatiguingness sound like typical Sabre glare? Maybe this DAP has the IMD hump.
