The reviews of these IEMs looked very promising to me. DMS released his ode to Mega5EST exactly when my wife was visiting their hometown - Chengdu, China. So, I pulled the trigger on them and a few days later my wife came back home with this nice souvenir.
As I shared above, I was a bit confused in the beginning whether it’s my thing. Recently I took the Mega5EST to the Munich Hi End 2024 and used it as my reference IEM there. After the trip and rolling a gazillion of eartips I can give it a better review.
TL;DR: Hisenior Mega5EST is a great Harman-like-slightly-V-shaped reference IEM that can do a fantastic job if you find the eartips that make these IEMs shine for your ears. I would appreciate a bit less sub-bass and a tiny shift towards mid-bass though.
Tonal balance
Well, you can see the frequency response measurements in the posts above and it sounds like it measures.
There is a plenty of sub-bass. If you don’t get it, then the seal is not working, try larger tips. It’s not crazy overdone and most people will find the bass of this IEM very pleasing. To my taste, the sub-bass shelf is actually the main issue of this earphone: it masks the mid-bass, and because of that the bass does not feel so punchy and controlled as it potentially could. I haven’t tried to EQ it, but it would be interesting to see how sub-bass reduction would change the character of these IEMs.
The mids are pronounced, clean, and clear. The vocal-centric tracks is probably not the main reason to buy a V-shaped earphone, but Mega5EST is good at vocals too. Depending on how the track is mixed, it is capable of reproducing them as “in your head” as well as “out on the stage”.
My favorite part is the treble though. This is where the preferences may vary the most I guess. To my taste, Mega5EST gives me exactly what I want: a strong treble presence without excess energy, lots of detail without sharp spikes, and nothing that I would complain about (i.e. sibilance). The cymbals sound like what they are, the brass shines and sizzles like you are in a Jazz chamber. I was listening to several over-head e-stats at the show, and the little Hisenior was on par with the better tuned ones in the treble region.
Detail retrieval
This IEM is perceived as very detailed. Acoustic information is present evenly across the frequency spectrum, there are no areas where it rolls off or misses something. Now add perfect layering in the mix, thanks to the tri-band design.
In busy passages with fast transients and a blend of high and low frequency phrases this IEM keeps doing a great job where many other headphones and IEMs give up and produce an indistinct mish-mash. In slow pieces with strings or brass you can feel the texture and tiny vibrations.
This quality together with a good tonal balance is what I guess makes others say that this $500 IEM outperforms many >$1000 IEMs, which it really does.
Punch and engagement
This is not the punchiest earphone, but it can do a pretty good job at hitting your eardrums and making you tap with your foot, if you find the right eartips.
Earlier I complained that Mega5EST sounds very well balanced but somehow distant and not very engaging. Some posters here commented that this can be fixed with tip rolling, and I confirm. After a lot of trial and error I found the tips that liven them up for me.
Sound staging and imaging
Is also very tip-dependent. Some tips make you hear everything like the sound drilling inside your head. Some other tips open everything up and put the instruments in space around you holographically. With some tips it’s somewhat in the middle.
Amplification
Sorry, what? Aplification for IEMs? Yes, an Apple dongle or a standard 3.5mm output on your laptop won’t do it for Hisenior Mega5EST. At least because it comes with a 4.4mm-terminated balanced cable
For IEMs they are not super-sensitive, which means you can experiment with the pairing a bit. I found them to sound very pleasing on the new Aune S17 class A amp. Significantly wider and more musical than my Questyle M15 dongle that I was carrying with me.
Tips on tips
Try a lot of them. Different tips will work for different people. E.g. the best ones for me so far were the ML-sized tips from A&K Zero2, but for my wife they sound too much “in the head” and don’t feel comfortable. For her, the M-sized Kinboofi silicone tips did the trick.
The stock tips are a miss IMO. The “wide” tips give better staging, but are too shallow, so that for my ears there is no punch and the IEMs feel like they can fall off any time. The “narrow” tips are a bit longer, but the narrow hole ruins the sound stage for me. Both silicone tips are very thin and give me some weird resonances in bass region. Foam tips - can’t say anything about them, they just don’t fit in my ears.
The nozzle is indeed quite wide - it’s 6.1mm or even a bit more in diameter in the wider part at the edge. I’d go for wider inner diameter and denser silicone material for the tips in general with these.
So, if it doesn’t work out of the box, try other tips from third party. I’m still waiting for Divinus Velvet tips to arrive.
