M9xx and APO Eq Not Working
Models
  • Drop m9xx + official drivers
  • Windows 10 19043.1165
  • APO 1.2.1 + Peace 1.5.9.1
  • Spotify app
Issue
Can’t get the APO equalizer to work, no matter what I try.
I change all the settings to on/off and zero difference to the output sound
Tried
  • Uninstall & reinstall
  • Troubleshooting checked with experimental drivers without original APO
  • Windows disable enhancements is off
  • No hardware acceleration (option isn’t even there)
  • Reset global preferences
  • Tried with and without Peace
References
I did see this thread, which I feel is similar to my issue however I can’t determine if mine is ASIO or WASAPI
I don’t believe EQ APO supports either ASIO or WASAPI.
You have to use the standard Windows audio path.
The only time I had this placebo was when audio enhancements were disabled. Therefore, you must have this checked in your device properties:
Other than that, I’d have a look in the troubleshooting section of APO documentation:
https://sourceforge.net/p/equalizerapo/wiki/Documentation/#troubleshooting
