Today is my third day with the HSA-1a (latest revision) and SR1a:
A few random observations thus far
I am very happy with synergies between amplifier and headphone, and the sound of the combo. This headphone system is truly unique and competent across many genres, definitely a keeper. Initially the sound appeared bright, I am getting accustomed to it (equipment and/or brain burn-in) and may leave it as is (no eq or tube buffer - tbd).
Overall the purpose of the HSA-1a is to make the SR-1a shine. This objective was accomplished 100%.
Buy the HSA-1a for that, and take the other features as freebies, then you likely won’t be disappointed. I would not buy the HSA-1a with the expectation of not being tempted to use other amps for different headphones; that would change in the sub $1000 range (probably HSA-1a could compete there), but given the system price of $7k it seems unlikely that potential buyers would be shopping at that level?
HSA-1 with non-ribbon headphones
- The sound is competent, detailed, sufficient slam, quiet, with accurate stage
- At the same time very dry, 10/10 - not my cup of cake, I want to enjoy music, not get a completely sterile reproduction
- With the Sr1a the music is much more coherent, and not as “thin” sounding; the HSA-1a doesn’t exhibit the same virtue with the dynamic and planar phones I tried
- The amp succeeds quite well in reproducing “medium grain” details
- but misses out on sculpting out very fine nuances (like e.g. AK SP2000 on TIA Fourte Noir) and/or the macro flow of the music (Cayin N8-ish, or my ML 585 driving headphones, or even my good old Liquid Fire)
Some headphone pairings I tried (and then lost interest, I might continue with Stellia, Utopia, Audezes, … but right now the SR1a experience is so much better that I have just no motivation to try)
- Sony MDR-Z1R: Not recommended, sounds hollow and brings out the worst out of the Z1R
- Sennheiser HD800: Listen to this if you want to exit the headphone hobby …
- Hifiman HE6 (original 2010 vintage): Best out of the three, needs the full power “Ribbon out” (the left plug), then the amp has a good amount of power to drive (on the low power headphone out I found myself having to turn volume all the way up for moderate levels)
HE6 is the only one I would deem enjoyable from the HSA-1a.
With phones like HD800 or Z1R (see below) would take amps like Focal Arche, Hugo 2 (even though that one is not very emotional either), Cayin N8 ss or tube, … any day of the week.
DAC synergies
As sources I mainly used my Metrum Adagio, also experimented with AK 2000 and Cayin N8 ss and tube, as well as Hugo 2 to get an impression of DAC flavors/pairings and synergies. Adagio is so far most satisfying.
- For complex classical music there was additional detail and sparkle when upsampling with HQPlayer (384k or 768K depending on DAC).
- DSD on the SP2000 and Cayin (from HQPlayer upsampling to DSD128 or DSD256) was an interesting and sometimes enjoyable option that projected a more cohesive flow of the music compared to PCM.
- Longer term listening and other genres work better for me in NOS mode.
Construction
No money was wasted with the HSA-1a on pretentious gold coating or lacquer, this suits me just fine.
Less impressive are some engineering choices to not provide complete insulation e.g. between RCA and XLR inputs. With some short RCA silver cables without insulation connected (used for tests with DAP sources), on the XLR selection there was a significant amount of audible RF noise with no music playing.
); also listen for the drum licks e.g. between 0:40-1’ - do they sound natural?
