@Torq I have a very early production copy of the Mysphere 3.2. I was involved with Heinz Renner pretty early on in the R&D cycle and helped him out a bit when he was trying to find Asian dealers. Having spent years trying to perfect a K1000 solution, I was pretty thrilled about the Mysphere and it doesn’t disappoint. Technically it’s not as accomplished as the SR1a but it far exceeds the K1000 in resolution, and accuracy of staging. The 3.2 can handle a bit of power - I use it at home with the same system I run the SR1a’s on - but will also pair quite well with amps as weak as the WA11. They work well with clean and neutral solid states, and since you already have the Linn I’d recommend trying the 3.2 straight out of the taps of the Linn.
Relatively speaking, the 3.1 is the more innovative product to me - a pair of ear-mounted speakers efficient enough to be driven directly from the SP1000 or WM1Z. As a “portable” can the 3.1 is an absolutely huge step up in staging and midrange performance from cans such as the Empyrean and Focal Stellia. With the K1000 you always had to live a dangerous life - the recommend minimum amp power rating is 8wpc, and yet you can quite easily blow the drivers with less than 2w loaded. The 3.1 will run pretty happily on a handful of mw’s which is still pretty amazing to me.
I should mention that the Mysphere’s have a strange pairing guideline (3.2 for solid states and OTL’s, 3.1 for portables and SET amps) which is actually quite true. Woo doesn’t even try to explain it at the booth, but the 3.1 is the “right” pairing for the WA8, WA22 and WA33 while the 3.2 pairs best with the WA11 and WA3.
