True Wireless (TWS) Earphones
What is currently decent in TWS IEMs under $200 and works well with Apple ecosystem? Great grandniece liked the sound of my Audeze LCDi4 EQ’d on ROON, and playing through the L&P W4, balanced using Hart silver cables. But she’s not a fan of wired and her trusty Beats IEMs are starting to flake out.
I’m not really expecting her to fully grasp the gulf here but she did say that mine were real clear and she could hear all the instruments and it sounded good on high notes without bothering her ears.
Why not get her a pair of Airpods Pro IEMs? They’re currently on sale for $189.99 at Best Buy. After buying a pair for my wife last year, I tried them myself and immediately bought myself a pair too.
$169… She says that she has small ears and has trouble putting some IEMs in. How do they fit and stay in? Could you wear them while practice skating for ice hockey? I’m not sure she knows about tip rolling, and these don’t have tips… My thought had been to get her some X-Elastic tips and foam tips to try. But yes, by all accountss the current gen is pretty good.
They do have tips in multiple sizes. Did you look at the non-pro airpods by mistake?
AirPods Pro (2nd Generation) … should be $189 at the moment.
They fit and stay in fine … and come with four different sized tips (XS, S, M & L). They’re extremely comfortable - the most comfortable “IEMs” I’ve used, in fact… And if you don’t like the Apple-supplied tips, companies like Comply also sell compatible tips (normal IEM tips will not fit).
I’ve tried most (all, actually, I think) of the high(er) end TWS options (Sony, Samsung, Devialet, HiFiMan, Sennheiser, Final, Noble) and other than some having some basic (if not very good sounding) app-driven EQ, none of them are worth it vs. the AirPods Pro. Especially not if used with Apple devices.
Put another way … even with the ridiculous gamut of headphone gear I have, I’d say the latest AirPods Pro have been getting 90% of my listening time.
This pains me to admit, as I resisted and ridiculed fashion-over-function Apple for a very long time: If you are in the Apple ecosystem there is no equal to the AirPods family. Multi-OS and cross-device integration causes me to use them when I’d otherwise switch to speakers or read captions. The fit isn’t the greatest but isn’t the worst. The audio quality is “typical” for TWS products and not as good as a $5,000 dedicated headphone setup. No shocker.
Yes, that’s exactly what happened. The link went to standard pods.
Another vote for the APP2. They made me question my wired IEM purchases and I ultimately sold or gave most of them away (most in a similar price range to the APP2; some even more costly). Like @Torq much of my listening time these days is with the APP2.
Fit and comfort is solid, BTW. I can hit the gym or go for a cycle ride or run and they don’t fall out.
Sony Linkbuds S (more of a ramble than a review)…
TLDR version on YouTube: TDLR - Sony Linkbuds S
Today I am going to share my opinions on my experience with the Sony Linkbuds S. These are not exactly a new model, they have been around for a while, but they may still be relevant to those who are looking for a TWS solution from a known brand in the space.
As you may (or may not) know, I don’t exactly review a lot of TWS IEMs (although I do have another set that I will be reviewing soon) as I am not, or rather I wasn’t, someone who used a lot of TWS. I always prefer wired when possible and for wireless, I had been quite happy with the Shanling MW200 (which allows me to use any IEMs of my choice), yet it was actually the Moondrop Space Travel, a set of 20€ TWS IEMs, that changed that.
I ended up keeping the Space Travel in my sling bag (ok, man purse) and would grab them just for quick media consumption on my phones. I was surprised to find that I ended up using them far more than I have ever used TWS in the past (and I have quite a few sets sitting in drawers). This brought me to wanting to try out something a little bit better, although the Space Travel are really not bad for the price at all.
I heard good things about the recent Samsung Galaxy Buds FE (check out FC Construct’s review for a good rundown) and was surprised to receive them as a Christmas present from my wife (she usually stays far away from my headphone world). Unfortunately, my main phone is a Google Pixel and this means that the connection with the Buds FE was limited to AAC, something that is not great on the Google devices (losing quite a bit of treble).
Anyway, I digress, this was basically to say that I returned the Buds FE and wanted something to replace them with. I did want to get a decent sound quality, yet one of the more important things for me was actually the reliability of connection and them connecting first time etc. I wanted LDAC (which is far superior to the AAC on Pixel) and I wanted a decent ANC if possible. For once I found myself putting functionality before sound, although I admittedly always have a set of wired IEMs and a dongle with me, which I use when wanting to listen to music specifically. I also didn’t want to spend a fortune as I was (am) not certain that I would get a huge amount of use out of them. So far, the Space Travel had been an exception to the rule.
So, all that to say that, here I am with the Sony Linkbuds S, a set of TWS with LDAC and ANC that retails for around 140€, although they can be found at lower prices during sales etc.
Presentation…
The packaging and contents of the Linkbuds S is pretty basic. A small box contains the charging case inside which the Linkbuds reside. Apart from this, we get 3 sizes of silicone tips, a short USB to USB-C cable for charging and a basic user manual (plus the warranty info etc.)
So there isn’t really a lot to say about it all. Basic and functional sums it up.
Build and Aesthetics…
This isn’t the first time I have used Sony IEMs or Headphones and they are usually pretty well built for the price but not exactly excellent. They are consumer grade items and they aren’t built to the highest of expectations like some of the other more premium brands may be but, at the same time, they are of decent quality in their respective price points, being sort of an average to reference other products against.
Some of you may have heard of (or even used) the normal Linkbuds. Those are the ones that are basically a small ring with an open center, made for listening while being 100% aware of your surroundings (maybe some cell phone manufacturers should release a phone with this principle :wink: ). Well, the Linkbuds S are nothing like them. I actually have no idea why they share a name as I really don’t see any similarities between them.
The Linkbuds S are more of a normal TWS set up, yet they are on the smaller side of many. They aren’t the smallest out there but they are small enough to disappear in the ear pretty well.
Personally find them very comfortable and have worn them for many hours while travelling over the past few days, which is what has led me to put this review together while sitting on a train from Venice to Rome.
Comfort is going to be a very personal thing as always but I think that they should work well for a lot of people.
Functionality…
One thing that I have been impressed by is the app that Sony provides to control their range of bluetooth headphones and IEMs. Obviously Sony is a big brand that has much more capability to put together a decent app than a lot of the smaller brands, but that doesn’t always work that way. There are apps from large manufacturers that are pretty terrible.
In this case, I have found the app to work well, be reliable and, although it does have stuff that I am not interested in using, it is not overly bloated with a ton of useless stuff.
But before talking about the app, let me quickly mention the functionality onboard the IEMs.
On each side there is a touch area that is basically the whole outside surface area of the Linkbuds. Although it is a touch and not a press system, I am happy to say that it is not overly sensitive. I have found with many other brands that just brushing slightly will cause all kinds of commands to set off and can be very irritating. In the case of the Sony’s, that hasn’t been an issue. It is nice to be able to remove and insert the IEMs, or reseat them in the ear, without changing track 3 times, calling the assistant and activating Ambient mode all at the same time!
While you can change the functionality of the commands in the app, I have found that I have preferred using the set up that comes stock. That is a single touch on the left cycles through the different modes (ANC, Ambient, Off), a long hold quickly lowers the music and starts ambient mode temporarily and tapping repeatedly lowers the volume.
On the right side a single tap is play/pause, a double tap is next track, a triple tap is previous track, a long hold summons the assistant and continuously tapping increases volume.
That is all the control I want on a set of TWS IEMs, enough to do all the functions I need without having to pull out my phone, yet no additional things that I don’t use enough for them to not just complicate things (like changing EQ etc.).
Now, if we move into the app, here we have a bunch more possibilities. We can do all the above things that we can also do locally on the actual Linkbuds, which is nice, but we can adjust quite a few extra things in here also.
I am not going to list all other settings and parameters that can be adjusted as it is a lot of info for a review yet we can basically change the layout of the controls, we can choose which modes (ANC, Ambience, OFF) we want the IEMs to cycle through when tapping them, we can adjust EQ (I will mention more of this under sound), we can turn on adaptive noise suppression, we can choose assistants, set up spacial audio and many more things that I am forgetting.
As I said a moment ago, I find the app to be quite complete and stable, something that is impressive.
My use case…
Now, before getting into the sound section, which is going to be what the majority are interested in, or maybe not, as it seems that the younger generation are more worried about the looks and who wears them :grin: But anyway, what I was going to say is that, before getting to the sound, I wanted to mention what my use case has been leading to these impressions, as this is not my usual “listen for a week and then sit down and do some detailed listening”, which is how I usually do reviews.
As I said above, I am writing this on a train, while heading back to the airport to fly back to Spain, after spending quite some time on planes, on trains, in stations and airports over the past week, together with watching some entertainment in the hotel room at night.
I did bring along a set of wired IEMs but I haven’t really used them because I wanted to put these through their paces to see how much they irritated me.
To be honest, I feel they have done a good job. No, they are not the most impressive IEMs for sound quality (I am getting there) but with all the travelling, meetings and business dinners, I haven’t really had any specific music listening sessions anyway, more background listening while travelling than anything else, together with a few movies etc.
As far as ANC on the plane and train, they do a very good job in comparison to many other ANC IEMs. Now, I must point out that I am not using the stock silicone tips, I have opted for the Symbio W tips. For those of you that don’t know the Symbio tips, they are silicone tips filled with foam. This gives you the additional isolation of comply/foam tips, while keeping the commodity of silicone tips (i.e: not having to burn them after building up wax and dirt over time). This means that there is additional passive isolation (which is noticeable).
Now, on top of that, the Active Noise Cancelling of the Linkbuds S is fairly decent. It doesn’t place you in a soundproof bubble but it does cut noise down to a level that can only really be appreciated when in silence (so either nothing playing or in a silent part of a track/movie). Even then, it is a rather distant noise and is mostly limited to the upper ranges of voices etc, the droning and rumbling of plane and train engines is dealt with very well.
I haven’t used the XM5 from Sony, but I have used the XM4 (and XM3) and I would venture to say that the ANC on the Linkbuds S has absolutely nothing to envy from the more expensive models of the brand, at least with the foam or Symbio tips.
Usually, in the past, when travelling I would either use a set of over ear XM3 or a cheap set of over ears with decent ANC, and place a set of wired IEMs underneath them. The Linkbuds S are not up to that level of isolation (which is eerily silent) but they are still more than enough for the flights of 2 to 3 hours I have been taking over the past week. They might not impress me as much on my next transatlantic, although the batteries wouldn’t last that long anyway, but for my usual travels around Europe, they have done fine.
As you may know, I have a database of isolation measurements of IEMs (achoreviews.squig.link/isolation), however, my usual way of testing doesn’t work with ANC IEMs, at least not most of them, due to the way the microphones work, and I haven’t had time to sit down and do measurements with the pinna, so I’m afraid I can’t show you the result of the ANC on paper.
One last thing to mention under functionality is that they can connect to two devices simultaneously and the app can be used on one of the devices even if you are are using the other device as a source. This means you don’t need to worry about having the app on both devices. This is handy for me as I use two phones, for different purposes, and can make changes if needed without having to take the other device out of my pocket.
Sound…
So, finally, on to the sound section and I am sorry to say that this might be a bit of a let down as far as a review is concerned. I have not actually had a specific detailed listening session with these, in other words, I haven’t sat down with them and my test tracks and noted the good and the bad with the specific tracks that I usually use for final impressions in reviews. These are the musings I am putting together on a train and the listening sessions, as I said before, have all been “in movement”.
Another thing to point out is that there is an EQ available in the app which I would recommend people to use. In fact, for specific musing listening, I would suggest using a parametric EQ outside of the app, which I have been doing, but if you can’t do that or just don’t want to, then at least make a few tweaks inside the app.
There are multiple different EQ presets available in the app which do generic things to the sound, here is a quick graph to show them:
Now, personally, I wouldn’t use any of those!
Luckily there are two custom slots that you can save your preferred EQ in.
I am glad there are 2 as there is a difference in frequency response between ANC on and off, which means that I would suggest two different profiles (I turn ANC off when not needed to save on battery).
Here are the differences between ANC on and OFF (and also ambient mode which is identical to ANC mode anyway, just with amplified surroundings):
So, what I have done for my personal use case is create 2 custom EQ profiles, one for ANC on and the other for off.
The problem is that the EQ is very limited in its functionality, so you can make these IEMs sound much better with the use of external Parametric EQ, but that is not always something we can use, like when watching a movie or YouTube etc. I will usually set the EQ profile that I intend using the most (ANC on or off) and if I do decide to listen to music for a longer period, I will switch off the EQ in the app and have another preset I have saved in UAPP for these IEMs. Well, two actually, one for ANC on and one for ANC off.
But this is not telling you anything about what they sound like!
I know and I apologise, but how would you like me to explain them? with no EQ? with one of the included 8 presets? with my custom EQ in the app? with my custom EQ in UAPP? with ANC on or off?
There are so many variables that anything I say will only be relevant to one specific use case.
I guess the correct way would be to do it with them flat, like I do with all other wired IEMs, however, the difference here is that the EQ is part of the IEMs, so use it!
Without EQ and with ANC off, they do sound a little strange.
As you have seen in the graph above (if you take any notice of graphs), there is a bit of roll off in the subbass regions, yet it is the upper mids and lower treble that is missing quite a bit of presence to clear things up. As they are out of the box (again, no EQ and no ANC), they can be a little dark and murky, a lot like many other Sony ANC sets I have tried.
The app EQ can help to bring these alive, not in a spectacular fashion but at least to a level that is more than adequate for general media consumption and even music listening if you are not searching for that perfect SQ.
As the EQ in the app is pretty restricted, you can’t expect too much but as a basic EQ reference, my personal preferences has been to use the following with ANC:
Clear Bass= 0
400 = -2
1k = -2
2.5k = 0
6.3k = 0
16k= -2
As I am cutting the lows and 16k, this serves to actually boost the upper mids lower treble. One thing to note is that, as there is no gain option, this does actually cut the overall output volume, which may or may not be an issue depending on your source and listening levels.
An alternative is to set the ones I have at 0 to +2 and leave the rest at 0. I don’t find that it causes any noticeable distortion and it will give you a bit more overall volume.
Obviously this is just a slight adjustment and is very limited by the 6 bands that are available. It doesn’t make them sound great but it is an improvement over stock.
If using a source, such as UAPP, that has the possibility of parametric EQ, then these can actually start to sound pretty decent. They are not going to be on the level of some of the wired alternatives, even at a lower price point, but that is one of the things we give up when looking for the commodities that the TWS bring.
In this case I turn off the app EQ and use UAPP to adjust the sound.
While it is possible to make even more tweaks using the full 10 bands available in UAPP, I have found that the difference between using the basic 6 band PEQ and the 10 band PEQ is not really huge. Yes, it can sound better but if we are getting this deep into fixing sound, then I don’t think they will ever meet your demands in general and would suggest sticking with wired alternatives for music listening. Even something like the 7Hz Zero (1 or 2) or the Cadenza, both under 30€, will offer better sound quality.
As I like to keep different devices on level playing fields where possible, I usually don’t share EQ settings and this case is no different. You can use the PEQ of UAPP (or any other source with PEQ) to adjust them to your personal preferences, they don’t need to be mine. If you don’t know where to start, then you can head over to achoreviews.squig.link and use auto EQ to give you an EQ to match these to some other IEMs of your preference. Of course they are not going to sound the same but it will give you a good starting point and you can start adjusting from there. As I said a moment ago, I find that they can start to sound fairly decent with some decent PEQ.
I also find that with EQ, the Linkbuds S can take quite a decent boost in gain without noticeable distortion or suffering. This does come in handy when listening to music that may not be recorded at the level that some of the modern music is recorded.
Conclusion…
I could probably ramble on for a lot longer, I still have 3 hours of train ride and a 3 hour flight ahead, but to be honest it is all just going to boil down to what your expectations are and what you do with EQ.
No matter how much you EQ, the Linkbuds S are not going to suddenly become amazingly detailed and high performing IEMs, they will still be beaten by the vast majority of wired IEMs available at half the price.
What you are getting is a reasonably priced set of TWS IEMs that has (almost) all of the features of the more expensive alternatives from the brand, with an adequate performance (for what they are), a tiny format that will fit in a fifth pocket and an app that works well.
I was looking for some specific features and the Linkbuds S have delivered them. I have no complaints about them as they do what I wanted them to do. Yes, I would love better sound quality but that doesn’t mean they are bad, they will be great for many many people out there (including the bass heads, as they can do a lot of it when needed).
And with this I am going to end this ramble disguised as a review :grin:
As always, this review (or ramble) is also available in Spanish both on my blog (www.achoreviews.com) and on YouTube (www.youtube.com/achoreviews)
All FR measurements of IEMs can be viewed and compared on achoreviews.squig.link
All isolation measurements of IEMs can be found on achoreviews.squig.link/isolation
*edited as spell check decided they are “Symbian” and not “Symbio” tips!
Rose Technics Ceramics
TLDR version on YouTube: TDLR - Rose Technics Ceramics
The Rose Technics Ceramics have been sent to me by Linsoul in exchange for the publication of my thoughts in this review. Linsoul have not made any requests and I will do my usual best to be as unbiased as possible.
I will leave a link (non-affiliate link, as always) to the Ceramics via Linsoul on my blog.
Intro…
While I have always maintained that I don’t review or spend a lot of time with TWS, lately that seems to not be quite true. You may have seen my recent ramblings (I can’t really call it a review) about the Sony Linkbuds S, where I said that I picked commodity over sound quality, something that is not usual for me personally.
It is true that the sound quality of TWS IEMs is getting better but I am still of the opinion that they have a long way to go before matching the sound quality of many of the cheaper wired alternatives. This is something that I find true at all TWS price points that I have tried, even sets costing around 600€ that sound decent but are no match for other wired alternatives that come in at a third of the cost.
While there are some sets that are using very high quality drivers and some in depth processing to make things a lot better, the truth is that they are still fighting against a very difficult thing to overcome. Size. You need to fit the drivers, the DAC, the amplification, the DSP, the battery, the charging system for the battery, all into a very small space while still managing to leave enough of a cavity for the air that the drivers need to work well.
But really, at least for now, TWS is not about sound quality, it is about the commodities of having something so small and easy to use, without being tied to a device by means of a cable. I am sure that these will continue to advance and at some point we may start to get options that do rival cabled alternatives, but for now, I feel that we are still looking at the best functionality we can get while also getting a “decent enough” sound.
Why am I saying all of this? Well, I want to make it clear that I don’t think it is fair to compare TWS IEMs with wired IEMs, at least not in similar price brackets, therefore it would not be fair if I do a direct comparison of the Ceramics to a set of wired IEMs in the sub 40€ price bracket, which is what the Ceramics sell for at the time of putting together this review (EDIT: They are actually less than 30€ at the time of publishing this review).
My current bench mark for TWS are the Linkbuds S, not because of sound quality but because of functionality and I think that, even though the Ceramics are less than a third of the price of the Sony, the comparison is fairer than putting them up against something like the 7Hz Zero (1 or 2), paired with an Apple dongle, which come in at around the same price (including the Dongle) is not really fair.
So, basically what I am saying is that my reviews of TWS IEMs should be treated as an independent thing. Much like the difference between me reviewing a set of IEMs and a set of over ear headphones.
Anyway, enough with the rambling and on with the review…
Presentation…
The Rose Technics Ceramics arrive in a fairly basic white package that features an image of them on the cover, along with the model, brand and “Hi-Fi True Wireless Stereo Earbuds” underneath. On the back of the box we get some basic specs, line the operation range (15m), Bluetooth version (5.3), charging time (approx. 40 mins) and the impedance (32 Ohms).
It is a little strange to see the impedance mentioned on a set of TWS as it isn’t really relevant due to the fact that they already have all the amplification built in etc, yet there is no mention of the codecs that the Ceramics offer.
Inside the main package we find two smaller white boxes with the Rose Technics logo on them, one labelled as “Earphone Box” and the other as “Accessories”.
Opening the Earphone box reveals a largish black plastic case with the Rose logo on it, which I thought was the actual case of the IEMs and my first thoughts were “this is rather large”. However, opening the black flip top case reveals a much smaller case on the inside which is actually the IEMs storage/charging case. The larger black case is quite nice with a padded interior although I couldn’t help wondering why they decided to pack a case inside a case, inside a box inside a box.
Inside the accessories box we find a USB-A to USB-C charging cable and three sets of silicone tips. In addition to this we get a user manual explaining the functionality (and contents) of the package.
You may be thinking that this is not exactly a lot of content but it is exactly the same content as received with the Linkbuds S at more than three times the price. Well, it’s actually more as we get the extra case to store the case :wink:
The Ceramics are available in 3 different colours, all black, grey with black internals and white with pink internals. I received the grey set and I think they look pretty good, although they do have sort of a beige tint to the grey, depending on the light.
The storage/charging case is very compact, around the same size as the Linkbuds S case and even a little thinner overall, meaning that they fit easily even in a fifth pocket and will not be something irritating to carry around with you (which is very important to me, as I think one of the positives of TWS is having them always available). This does mean, however, that the internal space of the case is not really very big. I can fit them in the case with Symbio medium sized tips installed but anything larger will mean that they don’t fit in the case properly (they wont fit with Symbio large).
The charging port is located on the bottom of the case, which is something I would usually complain about as you cant charge them standing up, yet in this case (pun intended), it won’t stand up anyway due to the rounded shape of the bottom.
The IEMs (or should I call them buds like everyone else?) are also very compact. They are almost round in shape and sit fairly well inside the ears, although they do stick out a little more than something like the Linkbuds S.
In general I like the size, they seem to be well built and the aesthetics don’t really displease me either.
Functionality…
Pairing for the first time is pretty straight forwards as it is with most TWS. Open the case and take them out, then look for them in your device and pair them. They can also connect to two devices simultaneously, which is a little more complicated (although the manual explains it well) but does work correctly. I could listen to music from one phone and then take calls from the other phone with seamless switching over between devices and back again once ending the call. I know that not everyone uses two phones but it is handy to be able to connect to a tablet or computer while still having a connection to a phone.
As far as I am aware, there is no App for the Ceramics (EDIT: I found out after putting together this review that there is actually an App. However, after trying for more than 30 minutes to connect it to the Ceramics and failing, it’s like not having an App). Personally I prefer no App over a buggy and bad performing App but, in this case, I wouldn’t have minded an App to remove some of the functions from the IEMs themselves as there is a lot going on and it can get confusing when you are using different sets of TWS (i.e: different control set ups).
Each side is a touch surface which is not really over sensitive but still suffers from touches when adjusting the IEMs in your ear etc. As you will see now, depending on how many accidental touches you make, you can make quite a few changes.
Volume up - Single tap on right
Volume down - Single tap on left
Previous track - Hold left for two seconds
Next track - Hold right for two seconds
Play / Pause - Double tap on right or left
Answer / End call - Double tap on right or left
Reject call - Hold for 2 seconds either left or right
Voice assistant - Triple tap on right
EQ mode - Triple tap on left
Game mode - Quadruple tap on left or right
As you can see, there is a lot going on and even after reading the manual (which we all know is not my first step :wink: ), I still found myself confused by the control layout.
I appreciate the fact that you can adjust volume from the IEMs, something that I have complained about with other models, but in this case the volume of the Ceramics is independent to the actual phone volume.
The fact that it is a single tap and there are many other functions with multiple taps can make it a little more complicated, yet the steps are pretty large. As I listen to all kinds of music, a lot of the time on random playback, there are many volume differences between tracks and turning up for a quieter track may lead to overly powerful levels on the next track, in the end, I found I grabbed my phone to change the volume rather than using the onboard controls and volume, which sort of defeats the object.
Also, both the EQ mode and the Game mode are things that I really don’t need to change on the fly, in fact, I don’t really need to change them at all, so these are things that I end up changing by accident and finding myself unsure of what I have done.
There is a voice that informs you of changes made but for some reason, there are two different voices depending on what you have done. It leads me to believe (just making assumptions here) that the control system was taken from a different model and extra things were added to the Ceramics.
There is no real mention of what the gaming mode does, although the Rose Technics web (and Linsoul) does mention that the Ceramics can offer latency as low as 60ms which ensures a “quick response in FPS games”. I honestly don’t know what it changes as far as the internal set up when activated but it doesn’t change frequency response and I don’t game, other that the odd retro session etc., so I can’t say I have improved much in the FPS gaming world :grinning_face:
One thing it does mention about it in the manual is under troubleshooting:
"Q: Noise in game mode?
A: Game mode is for gaming only. For other scenarios, please witch back to music mode"
So it obviously does something.
EQ I will mention in a moment under sound, so that just leaves the charging case. This is stated as having fast charge, with 10 minutes offering six hours of uninterrupted playback, but it doesn’t really say anything about the charging of the actual case. As I haven’t actually run it down to zero, I can’t say how long charging of the case takes.
There is a status LED on the front of the case which tells you the level of the battery, the charging state etc. All of this is explained in the included manual.
Finally, as far as Codecs, the options are SBC or AAC yet I found that setting it to SBC in Gaming mode would break the connection and stop them from working. In music mode, both AAC and SBC work fine. There is also something to note and it is the fact that the Ceramics only have 44.1kHz sample rate, meaning that everything will be resampled by them to 44.1kHz.
Sound…
All tracks mentioned are clickable links that allow you to open the reference track in the streaming service of your choice (YouTube, Tidal, Qobuz, Spotify, etc.)
Let’s start off by addressing the EQ modes on the Ceramics. There is no “flat” or “off” setting, so you have to choose between either “Hifi Music Mode”, “Pop Music Mode” or “Rock Music Mode”. Just to repeat that there is no difference between Gaming and Music modes as far as frequency response. The same three EQ settings are available in both modes and the response is the same.
Ok, so here is a graph of the 3 EQ modes (just in Music mode to not show an extra 3 irrelevant lines), with my usual preference curve for reference:
Ok, so where do I start?
Usually I would just tell you which of the EQs I prefer and then go on to explain my opinions with that setting, maybe with a few notes about the other settings along the way. However, I really can’t say that I “prefer” any of them.
So, rather than follow my usual frequency categories, I am going to mention a few of the tracks from my test list, those that I usually refer to the most, and then say how I find that track with each of the 3 EQ settings.
Of course we have to start with “Chameleon” by Trentemoller…
Hifi Mode: There is a noticeable lack of rumble on the Ceramics compared to many other sets. Let’s face it, this track is pretty crazy in the low end, so I can’t really say there is a lack of bass but it doesn’t rumble like it should. There is also a lack of lower mids and mid range in general, with things clearing up a little due to the excessive presence between 2.5 and 5kHz. This makes certain sounds stand out while others seem to be darker and merge together.
Pop Mode: Ok, here we cant say there is a lack of rumble, what we can say is that there is a lack of clarity in the lower ranges of the track. While the drivers don’t seem to be struggling, they also don’t seem to be defining the subbass either. There is, again, a lack of mids in general, with the (even more excessive) upper mids/lower treble giving clarity to some sounds but struggling to do so due to that immense rumble happening at the other extreme.
Rock Mode: Now we are just getting silly :slight_smile: I know that there are people who will find this quantity of bass great but I am not one of them. The low end rumble just takes over the whole track and even that excessive 2.5 to 5k can’t really break through that wall of rumble. Personally I find this to be nauseous and is literally just rumble with not much else to be appreciated. I am literally grateful to get to the end of my detailed listening with this track and this EQ.
Another track I mention almost as much as “Chameleon” is “Crazy” by Daniella Andrade…
Hifi Mode: In this mode the overpowering reverb in the lower ranges is avoided yet it does give the overall track a focus in those upper mids, making her vocals sound a little thin and harsh. To this we add a treble that is not really smooth and details stand out but do sound a little artificial at times. There is also a slight hint of sibilance on occasions, with the sounds of her mouth (lips etc.) seeming over emphasized at times.
Pop Mode: Here there is even more emphasis placed on those upper mids with sibilance being more noticeable than with HiFi mode. Although there is more present in the lowest ranges, it is mostly below where the guitar reverb resides, so it doesn’t really affect the low end of this track much in comparison.
Rock Mode: This is my preffered option out of the three for this track. There is still a hint of sibilance but the upper mids/lower treble doesn’t come across quite as exaggerated with this EQ. Again the low boost is mostly below the reverb, so there is a slight touch more but not enough for it to become overly present in the midbass, although it doesn’t seem quite as clean.
Something with a bit of electronic subbass but without the excess of “Chameleon” is “No Sanctuary Here”…
Hifi Mode: Here I find that the low ranges of the track are rather dull in comparison to what I would usually expect from this track. There is also a lack of body to the vocals of Chris Jones, leaving the upper mids exposed. This is not as bad as with female vocals, not as harsh, but does lose a lot of the excitement that this song brings.
Pop Mode: Now the excitement of the subbass is back, although I think it is a little overly present for the rest of the track, or at least overly present for the mids, which again lack the body to the vocals, making them take a back seat behind the subbass. The thing I found here is that the vocals are ok while there is a break in the bass but when the bass comes back, it does overshadow them, even with that 3k presence.
Rock Mode: Again I find that the subbass is overpowering when in this mode with this track. It eliminates all sense of clarity and while I still maintain that the driver doesn’t do a bad job, all you are really experiencing is subbass with some other sounds in the background. Not something I would pick personally.
Seeing that we have a “Pop” mode, lets try something I would consider modern pop, “Don’t Start Now”…
Hifi Mode: Here the bass is actually pretty impressive, with nice clean hits, keeping the rythm entertaining yet not overpowering. The issue here is that once more, we are missing some body to the lyrics of Dua Lipa, with the upper mids sounding a little fragile. There is the slightest hint of sibilance at times but nothing that I would complain about. I would actually complain more about certain sounds that suddenly sound harsh when they coincide with one of the upper peaks, such as the pluck of a bass string etc.
Pop Mode: This is what should be selected for this track, no? Well, I have to say that the bass is possibly even more impressive than in HiFi mode, especially if you like a nice amount of it. The bass isn’t bloated and its clean and decisive in it’s rithym. The issue here is that things sound even more fragile in the upper ranges. Sibilance is slightly more present but not terrible, just peaky overall in the upper ranges.
Rock Mode: Ok, if I wanted to impress someone with bass on a set of TWS, then this track with this mode is pretty amazing. It stays clean and defined, with plenty of bass and I find it sounds better than Pop mode to my ears. Here the upper mids are still a little fragile but not as bad as with the other modes, mainly because they hide behind a a lot of bass. I still wouldn’t say it sounds good, the upper ranges are by no means something I would choose but I still admit that the bass on this track is impressive in this mode.
Seeing that we did Pop, I guess we should do something for Rock also, so let’s use a classic, “Whole Lotta Love” by Led Zeppelin …
Hifi Mode: The thing that stands out to me the most here is the upper ranges of the electric guitar as it hits those higher chords. In general the track is sort of dark and distant but then suddenly those chords cut through like a knife in the left ear. The track is listenable although lacking presence in the mids, until those chords appear and are, let’s say, uncomfortable.
Pop Mode: When the track starts, the bass guitar sounds rather impressive but I wouldn’t say it sounds like it should. As soon as it mixes in with the other instruments and vocals, it then becomes a sort of wall that makes it difficult to actually separate what is going on.
Rock Mode: We saw that Pop mode didn’t really work for Pop, at least the track I selected, so does Rock mode work for this Rock track? Well, not really. Again the bass could be considered impressive at the beginning but it again turns into a confused mix when multiple things are happening. To be honest, this is not exactly a complex track but things just don’t sound right on it, with certain parts seemingly like a wall, while other suddenly cut through and sound like they are from a different recording.
Conclusion…
These are a budget set of IEMs, coming in at 40€ (EDIT: Now less than 30), and I have to say that they try to pack in a lot of things for the price, maybe too many things, and unfortunately sound quality is not one of them, at least in my opinion.
There are 3 EQ modes and the only real difference between them is how much subbass we get and how harsh it is around the 3k to 5kHz mark. I appreciate that not everyone has the same tastes and the fact that they have aimed to cater for 3 different profiles, yet none of them match my personal tastes (which is ok, I understand I am difficult) but they also don’t sound great.
The details are pretty decent, yet the peaky treble makes them sound artificial at times. The upper mids and lower treble are just too present and give things a harsh and fragile sound. The mids are the opposite, lacking in presence and leaving many vocals without any real body to them.
That just leaves the bass. I have to say that the bass is pretty impressive. That doesn’t mean I like it, there is too much of it for my tastes, but I still have to admit that it can be impressively clean and present on certain well mixed tracks. Of course, it didn’t work well with “Chameleon”, due to the track being overpowering and adding the additional overpowering bass of the Ceramics. But still, I can’t deny that these TWS have enough bass for most of the bass lovers out there.
I really can’t say I am a fan of these TWS IEMs and, although I do think that some people will enjoy them just for that excessive bass, I feel that there are other options in this price range that make much more sense.
As with all my reviews, this is also available in Spanish both on my blog (www.achoreviews.com) and on YouTube (www.youtube.com/achoreviews)
Truefree O2
TLDR version on YouTube: TDLR - Truefree O2
While those who read my written reviews will not have seen it, I mentioned in my last video that I was going on vacation for a couple of weeks and that I planned to disconnect, something that I achieved. I spent a couple of weeks camping with my family and completely disconnected from the internet and also from headphones and IEMs in general.
I did actually take a couple of sets of IEMs with me to try out but didn’t get around to sitting down and spending time listening to anything in particular. When I wasn’t having fun with the family, I was sleeping and trying to recuperate the energy I needed for the next day!
The only thing that I have really tried out during these past two weeks are the Truefree O2 that I have here today. These were sent to me directly by Turefree some time ago and I thought that it would be a good time to give them a try.
Truefree have not requested anything in particular and the O2 can be found on Amazon. If you would like a direct link to them on Amazon, just visit the version of this review published on my blog. As always, it is a non-affiliate link.
Intro…
I hadn’t heard of Truefree (at least as far as I can remember) before they reached out to me and, although I haven’t really had great experiences with bluetooth earphones from brands I haven’t heard of in the past (most of them never make it as far as being reviewed), I was interested in giving the O2 a try as I was curious about the form factor.
While they are labelled as Wireless Earbuds, yet they are more like little speakers that sit just outside your ear canals, but I will explain a little better in a moment under build.
They usually retail for around 60€ on Amazon but, at the time of writing this review, they are on sale for 48€, placing them inside the ultra budget category.
Presentation…
The presentation is rather simple, with a black box arriving inside an outer sleeve that shows an image of the earphones on the front, along with the brand, model, and some basic specs. On the back we get some more basic specs, along with the CE approval etc.
Inside the box we find a charging case that is sort of a dark grey/black stone effect with orange highlights and the brand on the top. Inside the case, which is orange, we find the earphones in a matching colour scheme.
Underneath the case we get a user manual in 9 languages (which is nice to see!), along with another small black box that contains a short USB-A to USB-C charging cable.
Build and aesthetics…
The build is a combination of plastic and rubber, with a shape to them which is strange (if you are used to IEMs etc.) but also very comfortable, at least I have found them to be. I literally forget that I am wearing them as they are so light and just sort of hang on your ears.
At first I was trying to work out how to wear them, as when you push them towards your ear canals, they obviously sound louder. I was subconsciously looking for a seal that doesn’t exist. After checking the manual, it just says “place the hook over your ear and rotate the earbuds until you find the most comfortable position”. I did just that and they just sort of disappear.
As they sit so lightly on your ears, I thought that they would move around and fall off, but they actually stay in place well, again due to the fact that they are so light plus the fact that the pill shaped part at the back gives them very good balance.
As far as build quality, they seem to be pretty decent. I obviously can’t vouch for how long they will last with daily abuse at the gym etc, but they are designed for that, so my guess is that they will hold up fairly well. They are also stated as IPX5, so they should do pretty well with sweat and even a few unexpected rain showers if out running.
In general, the build, the looks and the design are aimed at using them while doing sports or exercise and they seem to have done a decent job.
Functionality…
The earbuds feature a touch panel on the outside that offers all of the functionality that I would want from a set of wireless earphones. You can control volume, next/last track, control calls, use the voice assistant and even enter game mode (something that I really don’t need but it’s there).
It did take me a while to get used to the controls as, because the earphones are just sitting in your ear, they move around a little and can be a little finicky at times. But they do work and once I got used to them, I really didn’t experience any issues with response.
There is also an app that can be installed on Android and iOS to control some other features, such as EQ, turn off the touch controls, etc.
As far as EQ, there are 9x preset EQ’s, along with a 10 band graphic EQ which allow you to store custom EQ’s. The bands are obviously fixed on the graphic EQ but at least they are at sensible frequencies (31, 62. 125, 250, 500, 1K, 2K, 4K, 8K, 16K), giving you a decent amount of control over the sound.
There is also a function called “Adaptive” that plays test tones and has you tap when you hear them, adapting the EQ to best suit your hearing. I can’t say that I was amazed by the results but it didn’t sound bad, I just preferred playing around with the graphic EQ personally.
One thing to note about the app is that it does make you register your email address to be able to use it and it also shows publicity (Truefree publicity, not 3rd party) each time you open it. It also has quite a few translation errors in the Spanish version, with a few Italian words and some non-existent words to be found.
In general, I can’t complain about the functionality. Yes, there is certainly room for improvement but it is better than some other “better known” brands out there.
Sound…
Let me first say that these are not a set of earphones that are designed for sitting down and listening to music. They are designed to be used while in movement, with what they refer to as an “open-ear” design, not to be confused with “open back” as we find in headphones.
Basically these are 15mm speakers that sit outside the entrance to your ear canal and reproduce sound in that general direction. There is no seal, so don’t expect these to perform like IEM’s or even like flathead earbuds. They are meant to play background music while you are doing other things, like jogging, while keeping you connected to your surroundings and avoiding you getting run over by a car in the process.
Saying that, considering the limitations of the design, they don’t do a bad job. As the surrounding sound comes in naturally, it is not like a transparent mode on a set of noise cancelling IEMs, it is more, well, natural.
There is not a ton of bass of course but it is not totally absent. I did try the “Chameleon” torture test which is, of course, fairly bland in the low end. Boosting it with EQ helps a little but overboosting will soon bring more distortion than bass.
But that doesn’t mean there is no bass, if you like listening to things like EDM while working out, then you will certainly be able to follow the beat, just don’t expect them to provide you with deep thumping bass.
As there are so many options with the onboard EQ, I can’t really give you a specific run down on exactly how they sound in depth but, as I said before, these are not made for detailed listening anyway.
With some tweaking of EQ (or maybe just the “Adaptive” function”, these provide ample sound quality for the times when music is just as a background accompaniment and not a forefront experience.
Conclusion…
I think the Truefree O2 have their place and are clear about what they are made for. They are not something that should be judged on sound quality, rather something that should be judged on how they are used and what they provide.
That doesn’t mean that the sound quality is terrible, again, I think they are decent enough for when you are more interested in your surroundings than the actual music experience. In other words, when you are out jogging, walking through the city, hiking or even cycling (please don’t use earphones when cycling, cars are crazy and have no respect, but if you have to, then the O2 will give you a better chance of survival!).
These are even a good option for those who go out jogging or walking in pairs or groups, as you can all listen to your own music while still being able to have a conversation.
So, my conclusion is that these are not something that are going to blow you away with sound quality but if you are looking for something for a use case similar to those that I described, then these are a very reasonably priced option.
As always, this review can be found in Spanish both on my blog (www.achoreviews.com) and on YouTube (www.youtube.com/achoreviews)
Press Release
Noble Audio Fokus Rex 5
New TWS (1 DD, 1 Planar, 3 BA)
Press Release:
I love that Noble is making big moves in the TWS space. I hope they use it to broaden the reach of their legacy designs.
I’m super excited for these announced at CES 2025, as the last model (AZ80) is criminally overlooked in the market. AZ80’s are easily the best TWS I’ve heard.
When they release I’ll try and update this with some measurements off a friend’s rig
