I need to re-work a lot of EQ profiles. But MM-500 should be fairly easy. I’ll update once I have that done.
I really appreciate this and it means a lot to me!
I’m still fairly new to EQing but found I much prefer headphones on the FiiO K9 ESS EQ’d as they come across a bit warmer / less harsh for my ears… especially since finding oragtor1990’s EQ settings unfortunately he hasn’t done the Audeze MM-500 yet though he did however save me from returning my DT 1990 Pro’s.
Hopefully in a few more weeks I’ll be able to EQ myself just really good at copying presets from other audiophiles right now ![]()
The MM-500 is one incredible sounding headphone regardless though I will say
Just pulled the trigger for this from headphones.com, and should get it tomorrow! This will be my second high end headphones, since buying the Focal Clear from headphones.com in Feb. 2022. I really like this community, so I’m glad I can support the headphones.com guys.
I typically don’t EQ, but I would like to dabble in it beyond Oratory 1990’s Harman presets. Does anyone have Resolve’s EQ setting for this headphone?
or request here:
So, I just got MM-500 and am happy with Adi-2 as DAC/AMP. Can anyone suggest a clear amp upgrade that matches well with low-impedance low-power headphones like this? What I see is most amps’ SNR drops dramatically with 50-100 mW @ < 16 ohms.
Looking for something around $1-2K and thinking about Schiit Mjolnir 3 or HeadAmp GS-X mini.
