Not sure if this is who you are referring to, but Capistrano Cables on Etsy has a system like this. I haven’t owned a cable from them but I’ve talked to people who have done business with him and really like his work.
Also, Hart will put the interconnect at the Y-split as well if that is what you want. Just select the 18" split option then you can get a 4ft interconnect (or he can make them longer if you request.)
Has anyone ordered anything from Norne Audio recently? I was looking at an item and it says “in stock” but I know Norne has been iffy with wait times in the past and wasnt sure what in stock means for them: already built or materials are available but still needs to be put together?
Im tilting between Norne or Forza. Forza seems to have actual built cables in stock as they state item numbers and they change depending on how you option them.
That is indeed backward from ZMF / Audeze 3 = -, 1 = +
I wonder why they didn’t use the standard pin out. If course, it’s not a standard really.
Either way, it sucks for Hedd and their customers. Knowing the levels of OCD that takes place in this hobby, enthusiasts aren’t going to like having to buy yet another cryogenically treated, 110% single crystalline silver wire, anointed in children’s tears, unicorn-wool sleeved headphone cable. Hehehe
Just got a call from Corpse cables in Montanna…questioned them about the dilemma with the wiring differences between the HEDDs mini xlr convention and others like LCD…they spoke to HEDD in Germany and they indicated this is not an exact science and it should work both ways and you should be able to use your Audeze cables with the HEDD’s…Corpse has wired them both ways and can not really tell any difference…so there!!
The lowest cost from Corpse is approx $130 mogami type cable 4 ft length and they will wire them up either way…
If you wired a balanced cable like that, even accounting for the fact you have the pin numbering for the 4-pin XLR on the amp end reversed (the proper pin numbers are visible on the connector itself) which would cause your channels to be swapped, and plugged it into a recent Audeze LCD headphone, you would short your amp and probably kill it.
What I would like is a simple wiring diagram on how to properly wire a 4 pin XLR male to the two 4 pin mini-xlr left/right connectors females that matches the HEDD’s.
Or if you want to do braided cables… Let me know what you find. DoubleHelix sells some. There is lots on ebay and AliExpress, but i haven’t tried any of that.
I know some people buy mogami 2534 quad cable, and strip the 2 clear wires from the cable, then use that to create braided cables. It means you need to buy 12’ of mogami to make a 6’ headphone cable. You can use the blue sleeved wires and cover it with paracord too, I suppose.
We should probably move this discussion to the cable building thread…
Ok so I have sourced the 4 pin XLR male connector and the 2 Reon 4 pin mini xlrs and the main cable, now what size and where do I get the fancy paracord outer covering and some appropriate heat shrink?
