End of an Era
It took me many months to come round to this, and I am glad I was not influenced by anyone else, cos I independently arrived at a less is more conclusion, with respect to EQ, also based on not hearing any true improvement, from any extensive EQ effort. What led to this?
A few days ago, I was struck by these points.
  1. Every measurement rig is different, especially anything measuring IEMs and headphones.
  2. There will be unit variations, from my own copy of the headphone/IEM, whose measurements have been published.
For this reason alone, the likelihood that any EQ correction I attempt to do based on published measurements, will be effective, is indeterminate.
Furthermore :
  1. I do not have that much intimate knowledge of the auto-correction algorithms, of sources like AutoEQ.app, and the oratory database. I respect their efforts, but any effort to base correction on their algorithms, is like a shot in the dark.
And from that moment, I stopped using any filters which attempt to correct specific nuances of a headphone/IEM, in any extraneous detail - especially the kind that uses any more than one or two broad filters.
In certain cases, with my AKG K702, for example, where there is broad acceptance that it could do with a lift in the low frequencies, I have no problem with applying some gentle low Q low shelf or high pass filter, to “shape” what I’m hearing, to my preferred taste. I also would have no problem with doing similar tailoring with a broad Q high shelf, or low pass filter, to boost or cut the high frequencies, to my preferred taste. Either of these adjustments, simply to fit with how I prefer to hear things. So I would still advocate that it’s fine to apply EQ, in a broad manner, but of course this is optional. This way, I do not have to invest in a fair number of headphones/IEM’s to discover the one that best fits my preferred hearing, when I can use a little bit of EQ, to adjust any headphone/IEM which is already close to my preferred, to better align with my preference.
Nevertheless, most of the time, I no longer apply any EQ, preferring to just listen to the IEM, I consider is the most accurate to source, of the things I own. Which happens to be the ARTTI T10, its the best that I own. And I find that I no longer need to use any EQ with it. Same also with the 7hz Zero 2 - I think the stock sound is about as good as it will get. And for me EQ will not improve the sound of the Zero 2.
With IEM’s I must however qualify, the paragraphs above, with this. The choice of eartip, already confers on the IEM, an overlay of EQ, as each eartip choice changes the frequency response. So identifying the eartip, which delivers the most desired outcome in an IEM, is in itself an unavoidable application of EQ.
BRAVO. Similar findings to me. And, I think @generic.
What I find is that in the places where I may want to use EQ, particularly if I’m listening to a range of different music, is that the fast and easy way to dial in something good for my ears is with the Schiit Lokius. The choices of which points to use for EQ, and the fact that adding more has the effect of increasing the Q, makes this a way more pleasant tool than the multi-band EQ sliders of the 1970s.
Enough better that I might someday spring for the Lokius Maximus.
Following from my education, I come at audio from a different perspective than most of the measurement crowd: psychoacoustics and perception are central, and literally the only thing that can possibly matter to any human listener. You are stuck with your personal ear structures, you are stuck with your particular brain, and stuck with your brain’s ability to interpret the output of the ears.
Despite biological limitations and in-born characteristics, people also constantly learn, adjust, and adapt to their environments. As such, some EQ corrections lose value and importance as you listen. Very coarse tone changes do indeed matter, but humans habituate (stabilize to their senses) quite well to whatever they are hearing. They thereby tend to routinely fail blind ABX tests…no matter what a person desires or imagines, one cannot transcend the body. You will like what you like and return to what you like…just like a moth to a flame.
Gearheads and frugal dragonslayers love to discuss electrical measurements and “talk shop,” but they’ll always perform only how their bodies allow.
The Lokius handles the bulk of my EQ needs. It’s nice to have saved presets, but detailed EQ is a tedious waste of time and energy. Habituation is universal and inescapable.
We’ve landed in very similar places. I bought my Utopia OG in 2020, and despite a good faith effort since then to try every headphone I could in a journey to see if there is anything I’d like more (including the RAAL SR1a), I always end up preferring my Utopia - and it’s not even close.
I’ve recently been doing a bit of a nearfield speaker rabbit hole, but I’ve felt mostly “done” with my headphone setup for some time, and genuinely have no upgrade-itis. Thanks, Focal (and Chord, and Donald North Audio, and Roon, and PS Audio, and Enleum, and Common Ground Cables)!
Happy forumversary to you andris!
My ink pen journey was another complete obsession. I probably had two dozen high-end in pens, and even had nibs specially ground for some of them. LOL, probably getting ink on my fingers was the dealbreaker here. I ended up selling all of them and using standard rollerball pens.
I just got a new fountain pen that will write under water.
                                  It will write other words too.
You are as relentless as I am! :sweat_smile:
