So, struck with boredom as many of us probably are during these weird times, I decided to dig my dad’s old AV receiver (Pioneer VSX D1S) out of the basement to see if I could use it as a nostalgic, overkill headphone amp to drive my HD6XX.
Apart from a good amount of dust on the inside, it’s in incredibly good condition considering its age.
I plugged in the power, got my SDAC and plugged that into the LINE input, and plugged my computer into the DAC. The receiver fired up right away, relays clicking the exact same way I remember years ago. I could practically smell the cabinet that it sat in for years next to the TV.
Anywho, after plugging in a pair of sacrificial headphones (Just in case something went bang) and turning the volume knob up a bit, I could hear sound, but it was very crackly and fuzzy, the left channel being much worse than the right.
After a couple hours of fiddling with it, resetting it and trying different modes/inputs and trying my Hidizs Sonata HD as the DAC, the sound seemed to get gradually better.
Right now, if I turn it on, it will start off with lots of crackling, but when I turn the volume up probably 10-20%, it seems like the sound breaks through a barrier and sounds much cleaner, no matter what volume I have it set at.
When I turn it off, then back on, the same thing happens. Need to turn the volume up to a point where it gets clear, and then I can turn it back down again.
There also seems to be an imbalance between the left and right channels, and once it starts playing sound cleanly, there’s a very noticeable hissing noise when I pause the music.
Can someone explain what’s going on, and maybe give some suggestions on how to fix/improve the output? I’d love to have it to 100% again.
Cheers!
