I use two kinda separate systems, currently running off of one DAC. I use an RME ADI-2 DAC fs fed by USB from my desktop, which I know isn’t ideal but the usb on the RME is galvanically isolated so I am not concerned about noise. My ‘critical listening” setup is the RME feeding a SingXer Sa-1 which drives LCD-XC bubinga wood with 2021 pad revision. My “fun” setup is the RME feeding a Feliks Euforia OG and I switch between ZMF AC and VC depending on the type of music. I tend to like closed back headphones because I live with others and don’t want them hearing my music. I also have 6XX, which was my first good headphone.
I’m perfectly happy with the critical listening setup; details are crisp and clean, and there’s tons of separating between instruments.
In terms of the fun setup, it sounds beautiful right now but I know it can be better. I mostly want the most immersive and 3D stage as possible. I want to be placed inside the center of the music and have sound coming from all directions. The VC does this well already and the AC has a very wide stage for a closed back but is not as 3D. I have heard that R2R DACs emphasize this quality, although they don’t necessarily have the best technical performance. But in the fun setup, I don’t really care if some of the technicalities are obscured if the music is engaging and makes me get lost.
I hope my preferences help you all help me make a decision.
Thanks!
