Ok! Here goes…
(Feel free to mentally add IMO, YMMV, and the like as you read this.)
But you don’t know for sure, right? Because you haven’t evaluated the Phonitor like you have the THX amps?
Wire with gain is a myth. It’s a description of the ideal. Of perfection. Impossible. It also completely ignores the possibility that personal preference exists. It’s a horribly flawed concept, and NOT something one should chase after. Ok, so…
I’ve had the 789 amp in my chain. I’ve owned the phonitor x. Darth has had both. Cariad as well. If one person says a thing, you can chalk it up as opinion. When multiple people agree on a thing, from direct experience, there’s probably something to it. It doesn’t mean it may apply to your personal preferences, BUT… It seems to me that unless you also have had direct experience with both, then dismissing out of hand their shared experience is just fanboy-ism at best, or worse, willful ignorance. Don’t do that bro. It’s something I see quite a bit from the measurement fascist side of the hobby.
I know what I just said could be offensive, but I mean it in the nicest possible way. It seems you’ve closed yourself off to other possibilities, and you shouldn’t. Please try to be open to the possibility the Phonitor line sounds (much, much) better than the THX amps. Also, be assured that neither are my cup of tea. I like coffee. Ok, anyway…
Measurements. I think if you let measurements dictate to you what sounds good and what doesn’t, you’re going to miss out on a lot of amazing sound.
Measurements do not invalidate a person or group’s experience with how something sounds.
