This is a companion discussion topic for the original entry at https://headphones.com/blogs/reviews/moondrop-free-dsp-review-measurements
It looks like a new version of the software has dropped recently that looks much improved over what you had to deal with. ![]()
Yes seems to work a little better - still doesn’t support decimal points on gain - it looks like it does but when I load the settings again they are truncated back to just fixed numbers without the decimal
For the folks using the DSP cable, just curious but are you running it off your phones or do you have a separate Android-based DAP for it? The software is pretty sketchy even if I don’t think it’s purposefully malicious.
I configured the DSP using an old Android Phone that I still have but I am currently using it on my new usb-c based iPhone - I did ask Moondrop if they would upgrade their IOS app and I believe they are working on it.
hey, just curious… if I apply positive gain, but I dont use the device on full volume, does it still introduce clipping? I have tried doing that, but I dunno what clipping sounds like… it seems fine
