Neckband Speakers
Monster Boomerang Petite (mini review)
A few years ago, annotated somewhere on this forum, I had walked into a Best Buy store and tried on the Bose Soundwear Companion portable speaker neckband. A bizarre departure for its time, the neckband contained small nearfield speakers and a lot of signal processing. At over $300, it provided an interesting experience, marred by the amount of signal processing going on, which I found distracting. The sound was surprisingly good, and you were not isolated from the rest of the world, but it seemed as if music phase relationships were off, and you might be simultaneously in two different sized spaces.
It appears that BOSE has given up on this product now, and is trying to sell you sunglasses with speakers instead. As one of the primary uses for the neckband might have been TV or gaming, I’m not certain of the sunglass idea. Perhaps they should consult with Dyson for their next audio mashup.
The personal neckband speaker, however has not gone away. It has been embraced by Sony, Panasonic, Monster, and a host of other (probably Chi-Fi) companies wishing to put out something different. The Panasonic is gamer-intensive, and was developed to play Final Four. Sony has two models, one specific to certain Sony TVs, and one more general audio. Monster has the Boomerang and more recently the Boomerang Petite. Prices range from several hundred at the high end, to $75-119 in the middle, and as low as $30 for off-brand crap.
Why would someone buy a neckband speaker? Not bad for exercising, doing work. With bluetooth you can take calls and not have weird headgear or white grubs hanging down from your ears. You can have a goofy neckband instead on your zoom. In my case, I was going to be away at meetings for a few days, and with TPTB having booked a ski resort in the summer and weather predictions wet, I figured they would be good to binge Ted Lasso Season 3. I was right.
My choice was the $89 on Amazon Monster Boomerang Petite. Looked like the newest Monster electronics, and although having perhaps smaller speakers than the regular Boomerang, the available reviews didn’t show much difference. The Boomerang Petite is light, under a pound. I’m guessing under 250 grams. You don’t notice it on your shoulders. It charges via USB-C, and a charge seems to last longer than I’ve used it at reasonably loud volume, more than 5 hours.
If I had to describe the sound and frequency response, I’d say it was consumer-oriented, midrange focused, with surprisingly clear upper mid and lower high, and depth extending smoothly to mid-bass. No sub-bass and not much deep bass, although some reviewers have said the bass gets better with break-in. An audiophile would find it lacking, but unobjectionable compared to typical consumer stuff with boosted mid-bass.
It’s forte is the nearfield soundstage. Almost ethereal. Much wider than any headphone I’ve heard. I thin there is less signal processing going on than there was in the earlier Sony, and attention is paid to location of tweeters and woofers on the band, so you do have several inches of depth not that far from your ear producing sound. It’s not a “natural” soundstage as you would get from a 5+1 or 7+1 speaker setup, or even a 2 channel system, but it is actually pleasant.
In the photo above, you see how they look on, twisted slightly to show the controls. Holding the O turns it on or off and accepts calls. The triangle engages bluetooth mode and does pauses, and the + and - control volume. It’s supposed to be waterproof, mostly, but I didn’t test that with water or adult beverages.
In use, it’s very good for TV. I watched Lasso via my MacBook Pro’s HDMI to hotel 55 inch Samsung TV, and the sound was far better than the standard TV sound. Dialog was clear, sound effects were positioned well, there was some front-to-back feeling and plenty of dynamics. It does not get super loud, but more than adequately loud.
I’ve used them when getting ready to sleep, and they are far more comfortable than a headphone or earbud if you’re drifting off.
Above I engage the Boomerang “Stealth Mode” attempting to appear inconspicuous. Sound is slightly muffled, and this effect is somewhat ineffective.
So, is the Boomerang Petite worth it? For $89, I think so. There are more than a few times when I choose to use it rather than something else. I suspect a gamer might enjoy the more expensive Panasonic.
I don’t see any real category for this type of gear here, so I’m just dropping in into the general discussion. Moderators feel free to adjust. And note that this probably qualifies enough as a “review” to continue to justify my “Core Team” label and access to any secret areas of the forum that may or may not exist.
Thanks for sharing, I’m surprised it’s that small for a speaker and the stealth mode with a collar is rather clever. Personally, I’m actually a fan of these neckband style formats. I remember when they tried to create wireless IEMs based on these and I would love to see a comeback in that form factor as a wireless module that I can hook-up my own gear to, as long as there’s some sort of mechanism to attach or hang the IEMs while not in use instead of dangling around like you mentioned.
Did you ever try those bone-conduction things? It sounds like the neckband here has better sound quality and an easier fit. The last time I tried an Aftershockz product I barely felt the bone conduction and it was mostly the tiny, tinny speaker right by ear doing most of the work.
All the rage in 1979. In a drawer and ignored by 1981.
The Sony Walkman took over…for very good reasons…
I was in Best Buy the other day, and tried one of the wireless bone conductor things. Not impressed. Do you remember the handshake “buzzer” toys of the past? Tin stuff. Well the bone headphone seems like a shouty EarPod with a buzzer on my cheekbone,
I also tried the Bose eyeglass speaker. These were also shouty, no bass, but of better quality. They should have photosensitive lenses (they don’t) or ones that can be electrically darkened. Don’t know if they have prescription lenses available. It’s astonishing how many bad ideas can get through the marketing departments.
I can see how it would be difficult to use if you need to wear skates and squat while listening.
It’s difficult to even look at neckbeard speakers.
Looks ready for Amish Paradise! :laughing:
I purchased a pair, and had prescription sunglass lenses made and installed in them. They work pretty well particularly when you need to be aware of your surroundings (so you don’t get run over). The tradeoff is in lower bass response than IEMs. But for certain use cases, they work very well.
I use it occasionally. Works fine near field, but has little real bass. Very specific use case. Most of the time I’ll prefer AirPod or Sennheiser momentum 4, both four times more expensive.
Good for tv, situations where you don’t want to be cut off from the world. Fine near pool or beach, no worries about losing, theft, damage.
Also not bad if you plan to nap. I have never found a good solution for going to sleep that’s portable and relatively private. So you’re going for a specific convenience rather than quality sound. That said, they sound better than might be expected.
@pennstac
A certain similarity :man_shrugging:
I hope this doesn’t cause any pain :laughing:
I know this is an older thread, but I’m wondering how this works for video calls? Does it have echo cancellation?
I had an Avantree Torus that worked great for Zoom style calls. But it is dying if old age and they don’t make it anymore.
I purchased a Bugani neck speaker as a replacement (highly reviewed on Amazon) but it was awful. Unusable for video calls due to the echo (everyone on the call hears their own voice echoed back to them).
I’m looking for recommendations for a neck, or similar, speaker for zoom calls.
Tia!
Hello, and welcome to the forum. I noticed that no one replied to you, but I fear that neckband speakers are not a primary, or secondary, or even tertiary interest in this community. As you note, they can have issues.
I myself have no relevant experience, other than trying a BoneFone a long, long time ago. I use PC speakers in a quiet room, or the AirPods Pro for this use case. The APP has all sorts of interesting features such as remote amplification, noise canceling, serving as a customized hearing aid, etc. Their main issue is that one must put them in the ears and deal with the complexities of stuff in the ears.
But I have used it for video calls and Zoom. Worked fine, no feedback issues. But I usually use and prefer Koss PortaPro with Yaxi pads if I’m using the phone, or my work system that uses a Shure directional USB mike to pick up my voice and monitor speakers for sound. I don’t use AirPods pro for this, although they do work well, but I think having the little white things in your ear is goofier than using PortaPro.
I tried Sony neckband speakers, and found them totally inadequate. I returned them.
Yeah, and they also cost 400% more than the cheapies I got.
:wink:
Sad doggie!
20 char blah blah
That’s a really helpful breakdown, Neckband speakers definitely seem like a nice middle ground between headphones and speakers, especially for comfort and awareness. Good info for anyone on the fence about trying one.
