Although they were leaked earlier today, Campfire Audio has 3 new IEMs they’ve released for May 14th.
Highlights
- 7 Balanced Armature Drivers + T.A.E.C.™, featuring Dual Highs, Single Mid and Quad Lows
- Solid-Body Internal Acoustic Chamber Design
- Crossover-less’ design (no passive electronic components in signal path)
- Titanium Shell with Black PVD Screws
- Black Stainless Steel Spout
- Circular Beryllium / Copper MMCX
- Smoky Jacket Silver Plated Litz Cable
- New Sustainably Harvested Cork Zipper Case in Blue: Hand made in Portugal
Specs
- SPL: 93dB @ 1k
- Frequency Response: 10-26kHz
- Earphone Impedance: 8.5 Ohm @1k
Highlights
- 20% Smaller fit than the original Solaris
- Hybrid Design: Dual Balanced Armature Drivrers + T.A.E.C.™, Single Mid Balanced Armature, 10mm ADLC Diaphragm Dynamic Driver + Polarity Tuned Chamber
- All New Solid-Body Internal Acoustic Design
- Circular Beryllium Copper MMCX
- New Super Smoky Litz Cable
Specs
- SPL: 115dB @ 1k
- Frequency Response: 5Hz - 20kHz
- Earphone Impedance: 15.5 Ohm @ 1k
Highlights
- Anodized Emerald Green Body
- Dual High Frequency Balanced Armature Drivers + T.A.E.C.
- Single Mid Frequency Balanced Armature Driver
- Dual Low Frequency Balanced Armature Drivers
- Custom Beryllium / Copper MMCX Connections
- Machined Aluminum Shell
- Tuned Acoustic Expansion Chamber™ (T.A.E.C.)
- Stainless Steel Spout
- Solid Body Design
- 3D optimized acoustic construction
- Campfire Audio Litz Cable – Silver Plated Copper Conductors with Berylium Copper MMCX and 3.5mm Stereo Plug
- Campfire Audio Sustainable Cork Earphone Case. Dyed Green. Made in Portugal.
Specs
- 10Hz–28 kHz Frequency Response
- 112.8 dB SPL/mW Sensitivity
- 12.8 Ohms @ 1kHz Impedance
What do you guys think? A smaller Solaris seems very appealing since the primary complaint with the OG Solaris was the large fit.
