Is there any possible way to set up the app with actual pages so that I don’t have to scroll thru 1300 posts to try to find the end or a particular reply etc.?
This would be SO appreciated!
Regards
KC
Regards
KC
You can use the timeline on the right to jump around long topics. On replies to posts, there is a link to the parent post on the upper right of the reply. Unfortunately I haven’t found a way to jump to replies from the parent post.
