Maybe you misunderstand … or more likely, I’m not being clear …
When I said I would rather listen to the SR1a than anything else, I mean any other headphone (or IEM - though IEMs, as amazing as they can be, are already an “only when I must” proposition).
I already have a nice speaker rig. It’s an all Linn Exakt setup, including the 4-way Akudorik Exakt (Katalyst) speakers, which is about as sophisticated a setup as I can find for the space I have available for it.
The “stands” for those speakers include:
- A matched Chakra amplifier for each drive unit (about 800w in total)
- A dedicated Katalyst AK4497 DAC for each drive unit.
- Space Optimization+ - which is a room and drive-unit* correction system.
- Custom DSP and digital filtering.
- Network Interface
- Dynamik Power Supplies
Without the room correction processing, I couldn’t run speakers properly at my current place. The huge array of full-height picture windows would preclude it. With it, it’s almost as good as purpose built-listening room in my last house.
What I can’t do with the Akudorik Exakt setup is use it to drive other speakers (other Exakt systems can, if they run external Exakt Boxes and amps) - hence checking out various speaker amps for the SR1a. Though one of the ones I will be trying is a “conventional” Linn AK4200 (Chakra) amp.
On the STAX front, it’s no big deal. There are some genres I think they’re amazing for. I just don’t find them as good as some of the other options for all genres … and I listen to such a broad array of music, that it has either required genre-specific bias in headphones (one reason why I have so many of the bloody things) or other accommodations. The SR1a is just the first headphone I’ve come across that can manage 99% of that coverage with their basic setup and a little EQ.
It won’t be a setup for everyone, but I’m tired of using headphones as “EQ+”.
Before …
If I wanted killer bass and some semblance of depth to the stage, then out would come the AB-1266 Phi CC driven off my tube-amp. If I wanted an intimate projection with lucid mids and a warmer tone, but still wanted solid bass, then out would come the LCD-4. When I wanted better resolution and low-level detail retrieval, it’d be the Utopia, and if I wanted a bias towards stage vs. dynamics as well, then HD800S. And so on …
With the SR1a resolution and micro-detail are ahead of every other headphone I own. Bass texture and articulation is on par with the Abyss, and I can bring the level up to match them as well, without other artifacts, since there are no cup/housing/baffle interactions to cause other issues. Add this much bass boost to most other headphones and they just get boomy (or even distorted) and usually intrude on the mid-range. The SR1a stay clean and clear.
Stage is a function of the music and how far the drivers are opened, and doesn’t require using a different headphone to accommodate.
As I’ve said, I think the SR1a need EQ to be what most people think of as neutral. Without it, they’re great for mixing and for anything where you want a bit more treble energy and a fair bit less bass from 30 Hz down. But with, or without, it, they remain the fastest, most resolving, most flexible transducer I know of that I can use when speakers are a no-go.
With that EQ I have a single headphone that will do 99% of what ALL the others will do, in one package, and with one EQ setting (I could use multiple, for different things, but I haven’t’ found the need yet).
What they won’t do is:
- Play off a regular source/amp or DAP.
- Provide any isolation from, or attenuation of, outside sounds at all.
And I still need/want to do those things.
Just not enough that I’m willing to keep more than a dozen headphones and a bunch of other gear to do it. So I’ll settle on a very small set of cans that do the best “overall” there. But otherwise expect I’ll be listening via the SR1a.
*The individual drive units for every Linn speaker are measured at the factory before they are built. When you setup Exakt w/ Space Optimization+, you tell it the serial numbers of your speakers, and it looks up the specific corrections required for the individual drive units installed in your particular pair).
