Does anyone know of a device that is portable and converts USB to either Coax or Optical?
I am looking for something that I could connect to a DAP (or a phone) via the USB port to give me a digital output. Bonus points for something that has both digital output and analog (true) line out. I don’t need a headphone output.
What you’re looking for is called a “Digital to Digital Converter” or you can Google/look on Amazon for “USB to S/PDIF Converter”. Too many options to list.
If it comes with an analog line output then it is, by definition, a DAC … and it’ll be the DAC in that unit, rather than the source, that’ll be output over the line out.
Thanks @torq , I am probably better off with two separate units. I was thinking USB to S/PDIF to connect my DAP or phone to my desktop DACs/Amps and the line out to use in the cars. I think I will just get a DDC for desktop use and something like the Meridian 2 for the cars.
For a simple DDC, I have come across lots of cheap options (AE, Amazon etc.) but I’m not sure if I should opt for something of a higher grade. I know it is only 1’s and 0’s but what if it is dyslexic
But note two things. For I2S that unit uses the PS Audio pin-out, so make sure that’s what your DAC uses (some units can be reconfigured for other standards; this isn’t one of them). And since it’s XMOS-based, if it ever needs a firmware update you’ll probably have to go find a Windows machine to do it from.
Nor am I. I know the D90 can be configured for different I2S setups, but not the specifics.
But given that the D90 uses the same (or better, if you have the MQA version) XMOS chipset, has better clocks than the DDC you linked, and uses I2S internally from the XMOS board to the DAC chip anyway, I’d be extremely surprised if using a DDC like that would’t make things WORSE than just using the native USB input.
If we were talking about coming off a Raspberry Pi or a high-end transport/streamer it might be different.
