Is there going to be a dark mode version of this site? The OLED display on this iPhone 12Pro Max in light modes blasts my poor old eyeballs. Please
Profile>Preferences>Interface>Theme>Dark
Bless you Sir looking for my profile.
Be aware that the light and dark menus didn’t seem to use the same font/size (at least a while back). Some of the menu items disappeared, so I was forced to return to light mode.
I had to go out to the regular website to change it, this iPhone was being fussy about it for who knows what reason. Monochromios my eyeballs thank you. Will see what happen otherwise.
I concur, Dark Mode setting is not a simple switch. It does not maintain the same font/size and one has to zoom out to find the menu in the upper right hand corner.
god bless all of you
It’s all worth it for the darker silences between posts, and the deep noiseless background highlighting the wit and wisdom of headphones.com
I find “Night Shift” (found under screen brightness) to be helpful in the evening. The warmer whites is easier on the eyes.
This is very helpful on Mac and easy to set in a while.
