How would this translate to the Qudelix 5k? There are only 10 PEQ options but 12 here
On the OPTION tab, you can switch EQ MODE to 20 BAND.
Using this ATM. It might be more applicable to more people, though keep in mind I wear glasses so you might not want to do the bass shelf I did if you don’t wear glasses.
So torn between open box Bathys versus new Azurys for the same-ish price.
I have an HD6XX that serves me fine - could use more thump for my electronic music but hey it’s not as bad as people make it seem. On the go AirPods Pro 2, can’t beat the convenience.
Bathys or Azurys would serve the purpose of using in my office. Stick it into my backpack and take it to work. While wireless and ANC are super convenient, not sure I will really need it as I have a closed office for myself. Also, not sure if these could be used for Zoom calls or if I’ll just end up switching to APPs
Gahhh
It’s tough because APP2 is legitimately great, as is the HD6XX. So I guess I’d question whether you… neeed a closed back of any kind.
I love the APP2 and the tuning of the K371, but I’d love another closed back for listening in a shared office. The K371 is an awesome headphone (no build issues for me, my only complaint/desire for another option is because of the microphonic mini-XLR catching on my shoulder). I don’t mind spending a few hundred more.
How does the Azurys compare tuning wise? Really want to get very close to the K371 ideally. I’ve been looking at the Beyerdynamics Pro’s of various kinds but often they seem to have a treble boost or bulge in the upper bass which I’m worried will sound bloated.
Another option I’ve looked at is the Audeze Maxwell which looks well tuned from the Soundguys and Headphones.com graphs and pretty close to the K371. It would be interesting to try a planar!
Unfortunately I have to buy ‘unheard’ hence my graph reliance but interested in hearing from others who might have similar preferences.
I’ve replaced the blue cloth earpads on the Azurys with the black ones from my Bathys. The effect is significant on my head. I think the Azurys (unsurprisingly) sound more like the Bathys with the black Bathys earpads in place. Darker tuning is the result, less apparent glare in the treble.
Perhaps the blue cloth Azurys pads (and the brown ones, slightly different on the Hadenys) are contributing a lot to the weird tuning in the 3.5 kHz (and maybe also in the 6 kHz) region.
By the way, I used @Resolve’s PEQ settings for the stock Azurys using the Roon MUSE PEQ processor with fairly good results, but I prefer the response of the Azurys a lot better with the Black Bathys pads.
I’d be curious to find out if the ~3.5 kHz peak is attenuated (or even absent) with the black Bathys pads in place.
To conclude: I am a lot happier with the Azurys now with the black Bathys pads. The 3.5 kHz peak bothered me quite a lot with the stock blue pads. This is not at all apparent to me with the Bathys black pads in place instead. I am running the Azurys flat now, only a couple dB boost at 20 Hz using the Chord Mojo2’s DSP EQ. To be clear, I use the “red” (lowest setting) cross feed with the Mojo2. I’ve read elsewhere that this may have some effect on the midrange response.
AirPods Pro 2 for convenience is totally understandable
@Resolve I watched one of the “recent” livestreams where you mentioned being able to EQ the Focal Azurys to sound more dynamic than they ordinarily would with your glasses and in-situ FR. Would it be possible to post that EQ profile for experimentation purposes?
So the problem there is that I made that one specifically for myself, using in-ear mics to get the blocked canal data for myself, and that will be different from how it is for you. The key thing in my case was that I wasn’t getting the same measured bass response when on the rig, which led to a less intense response for that quality. But as far as what I did when measuring the in-situ response at the canal entrance (sufficient for bass level), is change the bass shelf into more of like a rising slope, up from the lower mids. And then I also had to compensate overall for the leakage effect of the glasses.
I don’t know if that helps you but it’s worth experimenting with how you hear the bass level if you do wear glasses. You may have to increase the bass a lot higher in frequency than you would otherwise do.
Roughly what frequencies did you EQ for this? Essentially something like an upwards gradient from 300 down to 20hz?
In my case it was all the way up to like 400hz. But for you it may be different.
Good review! I think the Azurys are fantastic as well, and I’d like to hear the Lensys, but I’m not sure how I might get the chance to do that . . .
Interesting that these measure as being much more flat than the Azurys on the 5128, with almost a DF-neutral treble, and DF-neutral bass.
Could this be simply attributable to unit variation? Or something about how these models tend to interact with the 5128? Or seal issues?
Has anyone used the Focal Azurys with the Dekoni Elite Sheepskin or Dekoni Elite Suede pads yet and can share their experience?
Usually I would just split the difference and buy the Dekoni Elite Hybrid which tend to be a safer bet overall, but the Elite Sheepskin / Elite Suede are the only two pads currently available for the Azurys (and Hadenys and Bathys).
I needed a pair of decent closed-backs, already have Sony XM3s for whenever I need ANC or wireless (which is seldom for me, and they get the job done-ish), so I landed on the Focal Azurys. I can’t make up my mind about them, and am wondering if anyone has any experience with these.
Sometimes these sound great, sometimes they sound slightly messy and shouty, so I’m wondering if these just aren’t the right headphones for what I predominantly listen to (which is metal). I’ve a passable understanding of EQ (via Roon), but I can’t seem to iron out the chaos.
Especially strange to me, and perhaps this is my headphone inexperience showing, more so than with any other headphones I have, these seem to behave very differently depending which amp I’m using. (Yes, taking into consideration the gain settings.)
Which are:
- Macbook Air headphone jack
- SMSL DL200
- Oppo HA-2 (the old pre-MQA one)
- Marantz SR7011 headphone jack
- HifiMan EF2C (line-in only; the DAC stage is notoriously garbage in these)
The Azurys love the SMSL best overall, HifiMan tubes sound great BUT can really emphasize that shoutiness, and the Oppo, never the best or worst, struggles to tame the mids when passages get crazy.
One last thing: has anyone noticed a sharp pressure at the very top of the skull? If so, does it go away as the band and materials flex/break in?
Have you pulled down the ear gain at 3500 Hz yet? Something like 3500 -3 with a Q of 3.
You could also fill in the dip around 200 Hz.
