Yes most definitely, I get where you are going and your common sense. I’m not that young, and I am fully aware of 8 tracks and vinyls.
I am definitely not rushing into anything. In the sundara post we had some discussion. My computer does have a built in dac and amp. But many details are missing. It says the computer supports 384/32bit and headphones up to 600 ohms. It is a very expensive motherboard, it comes with a whole home theater setup on the IO panel, including a 6.3 mm jack. What we had discussed is that even though those things maybe present a sufficient amount of information was missing. Mentioned in that post.
I was hoping that would run my sundara, at least a 100 dollars worth of dac/amp in the system[computer]. Sure it would run it, but may overload the system, so a secondary dac amp was suggested.
I am not a rich or wealthy person, and personally just wanted to go for a magnetic planar headset. I had a friend who had a nice Audeze, I believe the LCD-2. And I really enjoyed those headphones.
But as I am merely getting my toes wet I’m not trying to jump into anything that crazy.
However, now with all this new things being thrown at me, I would rather spend more on a DAC/Amp for the purpose of any possible future upgrades.
But as mentioned one thing is leading to another, first the headphones are out of the way and now we got the DAC/amp second and now seeing even a third piece of this puzzle. Which I am sure I do not need at this time.
Just feeling around to see what is the best bang for the buck and not later ending up having to purchase more and dish out 300-500 on top of what I’m spending now. Just to get the main part out of the way now seeking the best option.
So like the Asgard 3 is only 199 with no upgrades, a 100 dollars more than the Schitt amp suggested for me by these wonderful gentlemen.
Then I can upgrade the dac for 100 and 200 more jumping to 400 for the Asgard 3 and I’m not sure what’s suitable. Then I see the guy using the Asgard 3 with another device and says the BiFrost 2 will eliminate the need for a third piece of equipment and in their opinion is better.
But I’m sure, as you someone who purchased it, has a much more premium price tag.
So I’m trying to get the Sundara[cost vs performance] of dac/amp/preamp whatever the correct terminology maybe, but that is my point. And my current end goal.
And my motherboard in case you were curious is a MSI Z390 MEG Godlike. Currently the most expensive motherboard on the market.
As mentioned above trying to see if that has any utility as well in combination with an external dac/amp, mentioned in my comments above.
Not taking anybody’s advice forgranted. Just trying to find the sweet spot.
