BUT. Well known. People want them and willing to pay for them. And they sell the DIY wire, so I can make them.
I think my next task if to find a good 22 awg wire and sleeve it, then do a 4 braid cable. Any recommendations appreciated.
Might need to get a solder pot too, open my options to the LITZ wires. Tried to tin some with just the iron and whilst I got it done, bit of a pain. Maybe there is a trick to it I haven’t come across.
I like the idea of these zmf cable kits. Everything you need, one kit.
No sourcing wire from one vendor, xlr connectors from Mouser, Y splitters from some shady ebay listing, etc.
It also means ZMF doesn’t have to spend the time building it, and trust me cables take LOTS of time. Saves you money.
If I didn’t already have more zmf cables than I could shake a stick at, I’d probably have built a few already. And their silver cables are really worth it. My favs.
With a shielded multi-core cable. Do you connect the shield to the ground at the amp end. Be that the ground lug/chassis of a 4pin XLR or the ground of a SE along with the other two conductors?
The interesting (I guess if life is that dull it is) part is I asked the Moon “technician” directly if they connect their shield to the ground at the amp end, and he said that they do.
Then someone sent me a legit Moon Black Dragon cable to reterminate and the shield had just been cut short, heatshrink sealed and just the 4 conductors into the XLR. Plus all the fkn hot glue they love sticking in.
Side note; Forza Audioworks load the last inch of the 8wire braid and all the connector with black hot glue. Thankfully if you spray enough isopropl in and around it starts to break apart and let go, still messy though.
Anyone have any pure silver wire sitting there unused? Looking for maybe 25 feet or so to make a 4 braid cable with. Just hard to find good stuff in small quantities.
I was thinking to make a modular cable too, but now I don’t know which connector or method (1. two cables connected using for example a LEMO connector, or 2. one cable using the OEAudio multi plug similar to the Dunu plug, Dita awesome plug etc.). What should be the more durable and flexible way to do? If the first option, which connector could be the sturdiest, smallest and lightest? I saw the LEMO plugs, the Hirose HR10, the YC 8, others suggestions?
