I bought and returned one of those mega cables. My concerns were physical rather than electrical, for those cables can be insanely stiff. This limits routing options, and results in likely unexpected strain on the small plastic IEC sockets on the back of most equipment. The often flimsy mainstream $2 to $10 cable sockets were designed for conventional cables.
Absolutely agree. If one is running off standard wall power without a fancy UPS unit or regenerator, cables will affect basic electrical properties such as conductance, resistance, interference, etc.
See above regarding slightly different electrical properties. For a given construction material and size (e.g., copper plated aluminum, OFC, silver plated copper, pure silver) there will likely be similar electrical differences and they’ll likely be audible under some circumstances. As @ProfFalkin notes, many cables are produced in small numbers (e.g., $1,000 items) and not often critically evaluated either.
In my experience shielding always makes sense, and it may be the only thing that makes sense for us non-regenerators. My setup (and many) have a rats nest of power and RCA interconnects. Frankly, I’m less concerned about the power cables than their potential to leak and affect the very sensitive audio content RCA lines nearby.
One might look for RF/EMF leakage and hotspots with a simple meter, but I’ve never tried this. I’d want to research such products before bothering too.
I’m more concerned about the quality of power coming into the house (e.g., older, newer, shaky wiring, rats eating the insulation, overtaxed substation, etc.) and nearby RF interference. Mediocre equipment often has mediocre parts throughout, so there’s no guarantee (nor an a priori probability) that power cables will be the weakest link.
I tried something like that, and it may have smoothed the sound a bit (or was a placebo effect). Again, consider the last-three-feet impact on capacitance, resistance, and interference as a direct explanation. One can also tweak the output characteristics of an amp by changing capacitors and resistors inside the amp itself (see Bottlehead Crack and Darkvoice 336 discussions in online forums). A cable-induced change isn’t a good thing IMO because it limits the potential to directly tweak the sound downstream, as possible with a controllable EQ.
I’ve absolutely, positively heard major changes with interconnects. As above, I believe this follows from capacitance, resistance, and interference differences. One can attempt to modify the tone in a broad, general way through cables or do it directly through amps and EQ. The end results may be indistinguishable.
EDIT: Cable electrical properties calculator here: Calculation of Cable Data
