What about NuForce / Optoma?
Thinking about IEMs because I haven’t found any I really like, I think they are not comfortable, and since I don’t favor them, I probably haven’t heard any good ones.
@Torq points out that better ones actually have crossovers.
Massdrop has NuFoce HEM8 and HEM6 at a good price, so I probably could make one of those “here’s a bargain, what do I have to lose” mistakes. No reviews on this community, but they send out comp sets to likely reviewers on the usual blogs/communities.
Any thoughts on these? Save my money?
Im not a NuForce fan as the stuff I’ve heard is quite mediocre for their price. There’s probably a reason they’re half off and still making money. It’s overpriced to begin with. :slight_smile:
For the price, I recommend the Kanas Pro, KXXS, Etymotics ER2XR or SE, ER3XR or SE, Galaxy Buds, etc. It does depend on what you like – I prefer a neutral-warmish shound so these fit that case.
I don’t know about Nuforce, I’m very cheap and stingy when buying IEM, but KZ ZS10 pro is amazing for $34 ( was the prime day price).
CCA C16 are also incredibles for $86 ( again, special price in some kind of sale on Ali Express , as I said, I don’t like to spend too much on IEM).
Thanks. What I’m waiting for is the Massdrop HD-6xx of IEMs. Something not overly expensive and universally recognized as a Bronze prizewinner.
Undoubtedly I won’t find it. IEMs are considerably more quirky than standard headphones.
If comfort is a primary consideration, but sound quality and value are not to be sneezed at either, I recommend the Final Audio e3000. I can’t think of any other IEM that ticks those three boxes so well.
I appreciate the callouts to the KZ ZS10 and the Final Audio e3000. However, I’ve got the KZ ZSN and a 1More Triple driver, an older Vsonic, and somewhere in the house is a pair of Etymolic ER-6’s hiding under something. My go-to IEM is the Sennheiser IE 40 Pro, which I find pretty acceptable (in the $99 context).
What I’m looking to find is a definitive step up. I don’t know where that is. Planar-magnetic? I liked the original STAX SR-001, not that I’d actually buy a pair. I don’t think that jamming more BA speakers into a small space is going to do it. One reason I like the IE-40 Pro is that it’s a single dynamic driver. So it’s very coherent.
I don’t get to where I can hear the Zeus, Noble, or high end Campfires. And I’m not looking to pay those kinds of prices. If I’m going to blow a grand or more, it’s going to be on a new pair of STAX, probably Lambda SR-L300L or SR-L700s, or if I’m feeling rich an SR-007 Mark II used. Or something.
I’m not a fan of the heavy V signature. I do like extended and deep bass, but don’t want something that just bleats 150Khz in my ears… Some of the music I listen to has deep organ pipes, or electronic sounds, or well, cannons.
Aren’t we all. Hehe. An iem with the HD6XX sound would sell really well.
I’m not sure whether IEM technology is yet capable of HD-6xx versatility at any reasonable price point. All IEMs are much more strongly affected by tip and ear fit than headphones too.
I agree that BAs can be like chasing your tail. More drivers → fill more audio gaps → create more potential for imbalances → more drivers. Repeat. Low end BAs are quite literally a pain in the ear. They are very spiky–and while clear–they cause fatigue pretty fast.
Based on @antdroid’s and other reviews I purchased the Moondrop Kanas Pro. It has a large single dynamic driver and a solid metal case. I don’t have experience with the IE-40 pro, but it is perhaps similar. The Kanas Pro was pretty fuzzy during break in, and is the first and only in-ear product of mine that benefited from a balanced cable.
I keep nudging you toward balanced…heh…
