Nice. What’s the speaker match?
I have one of those imputes transformer boxes: XLR to RCA version. Bought it used from a guy selling his Kenzie.
What is the purpose of a input transformer?
This is the Ampsandsound manufacturer explanation. I bought it mostly for a natural XLR to RCA conversion.
I wonder how they differ against the ones used in pro studios?
Take this one, for instance, with Jensen transformers.
Cheers.
Not sure how it works exactly. A&S Justin Weber makes good stuff. Most of his later model Encores incorporate the black box input transformers within the amp itself.
Probably both are the same
Damn I got the 1:1 from Jensen directly but this is price much higher… hopefully tho it’s got the better Lundahl transformers, the Jensen product works tho it’s a little soft
Also looook what I found!!!
Geek Out v2+ Infinity! I own the original non + which is the same circuit minus the middle gain option, but the Company as you guys know is dead so support is non existent I believe. I’ve also not heard a better portable Dac/Amp for $300 [Price I paid for this one and the original one got back in like 2017]
So I’ve been wanting a back up and holy smokes! This thing is SO much nicer in person!!! An it weighs a TON super heavy. A shame the company went under and what Larry did to his customers
hopefully tho iFi [or some one] will come out with something better than Micro iDSD that can finally overtake the sound quality of this little gem!
If they used lundahl transformers there would be nothing left over for profit. On speculation parts cost about 30-40% of retail which is not bad. Mine has cinemag transformers inside which would cost us $150 for 2 plus $50 for the chassis. Lundahl input transformers cost about $100-150 each and you need two of them. Using those a company would have to charge much more than $450 to keep a roof over their head.
What do you use your jensen box with?
once with Magnius, Its kinda there for IF I need it
but the transformer it self isn’t perfectly transparent so I dont find a need to use it honestly
I might buy the jensen just to do a comparison.
Also would be fun to build one myself with some lundahl’s!
Don’t buy one, I’ll send you mind for a week or so lol
I’m also curious to see how it compares and if u like it we can work out a deal haha, tho I don’t think you’ll need 2
But seriously, I’m curious to hear how the Jenson compares to other stuff
Hummmm, those two on the wall…oh, wait… there is an amp too.
comic lover too!?
I bet there are a bunch of us comic lovers in here!!
The Elise looks so clean. I am quite curious about how it pairs with the Vérité.
