In case you missed it, @Chrono finally got his hands on the Porta Pro to find out what he was missing all this time. Check out his thoughts on the Porta Pro and a potential spoiler for a video to come.
Very nice, @Chrono, glad you finally got to listen to the Porta Pro. Couple of things worth noting - they drive just fine off of a cellphone, and many people really like the Porta Pro for ZOOM conference calls.
These are great âstarterâ headphones - I hand them out to [usually deserving] kids.
Finally, the first time I didnât get irritated by the comment âpunches above itâs weightâ. Thatâs because we both know how much these cotton-candy light headphones weigh.
Is it worth upgrading the Koss Porta Pro?
What do you get with upgrades?
Background
The Koss Porta Pro retails for $50 as of 2022, and can often be found for around $35. It has been a mobile audio standard since 1984, and remains respected by many serious enthusiasts. To my ears, its mid range sounds quite good, but it has significant flaws and limitations. First, I describe it as âthick in the middle with no highs or lows.â The Porta Pro cannot generate real bass. It has a loud lower-mid hump, but this is not true bass. Male voices tend to be too loud and husky. Overall, its timbre is warm and comforting but not accurate.
A second and more troubling issue is that the Porta Pro tends to whine and whistle at a specific high frequencies. While the Porta Pro cannot generate true highs, it sometimes puts out unpleasant noises. This seems to happen when the drivers cannot generate an intended sound â they appear to convert notes to the driverâs natural resonant frequency. Imagine a dentistâs drill playing at random parts of a song. Fingers on the chalkboard. For more information, see the frequency charts for the in-line control model at Rtings.
The $35 Porta Pro brought to mind my experience with painful high frequencies from the $300+ Sennheiser HD-600. It too has loud and scratchy treble with a bad or incompatible DAC/amp setup. I learned to greatly improve its performance by upgrading my DACs, and using tube or balanced amps. With the right setup it becomes a smooth, easygoing, all-round performer. Without getting the treble under control Iâd rarely use either product.
Enter my Porta Pro upgrades
Hart Audio Cables compatible mini XLR 4 connector (DIY modification process)
Setups Tested
- iFi ZenDAC (V1) â Balanced versus single-ended output on the same device
- FiiO Q5 â Balanced versus single-ended output on the same device
- Bifrost 2 â Drop THX AAA 789 (balanced tested, but even that was bright, edgy, and awful)
- Bifrost 2 â Rebel Audio RebelAmp (single-ended, only option)
Test Tracks: A condensed 20 song edition of my standard fatigue-evaluation playlist. I could generally tell how well a setup performed upon reaching the awful recording Californication, but not always. The whining was consistently worse with my problem tracks (see the last third of the list).
Findings
Yaxi pads are worth it for all songs and sources. They smooth out the high frequencies and reduce the Porta Proâs scratchy, random hiss. They are also larger, softer, and more comfortable than the factory pads. They come in multiple colors, making it hard to confuse left versus right.
The amp matters and the DAC matters, but the Porta Pro doesnât scale much. The Porta Pro has firm limitations, but a warmer amp will sound warmer while a smoother and warmer DAC will not make its inherent flaws worse. Itâll always be thick in the middle with no highs or lows. The ZenDAC is warm and doesnât extend very far into the treble, so it was my clear favorite (balanced mode). The Q5 (AKM 4490 DAC) was good but not great in balanced mode. It was often whiny in single-ended mode. I used the Bifrost 2 to feed the THX AAA 789 and RebelAmp. Iâd avoid the 789 with the Porta Pro. Not good. The RebelAmp competed with the Q5âŚthe Porta Pro just doesnât scale much.
A balanced setup matters, and was required to minimize or eliminate the Porta Proâs treble artifacts. In comparing the ZenDAC and Q5 both in balanced versus single-ended modes, balanced was better and I was able to finish my playlist with little discomfort. The timbre remained identical, but the phantom whines were controlled by balanced.
Should I upgrade the Porta Pro or buy something better?
When I reviewed the Sennheiser HD-58X, I made a ludicrous comparison table ranging from the Porta Pro ($35) to the Focal Utopia ($4K+). My Porta Pro upgrades were an effort to see how much I could improve a $35 product. The answer isâŚnot very much⌠It remains a pleasant, light weight, and affordable product with serious treble dangers. Iâd happily use the Porta Pro in mobile situations, at least with a warmer balanced amp. However, if given the opportunity Iâd choose the HD-58X ($125 to $190) in a heartbeat. It has better bass and treble extension and sounds more natural overall. It performs better out of the box, with the factory pads and cable, and with a single-ended amp.
The table below adapts and expands some of the information from my HD-58X comparison table. A higher price gets you âmoreâ of something but its doesnât scale with the dollars spent. The Porta Pro is in the lowest quality tier never rises above. It delivers just some of the facts, maâam.
| Quality Tier | Rough Cost (2022) | Sample Products | Character Summary |
| C: Obvious Flaws | $35 to $100 | Koss Porta Pro, Beats consumer products, many bundled âfreeâ headphones and IEMs | Exaggerated frequency bands, abruptly cuts off frequencies, creates artifacts such as whining, scratching, or buzzing |
| B: Solid Fundamentals | $125 to $200 | Sennheiser HD-58X, many airplane-oriented noise canceling products | Reasonably accurate in the midrange, but limited details and little or no ability to reproduce the air, room, or the recording environment |
| B+: Hints of Nuances (good enough for many people) | $200 to $500 | HD-6XX, HD-600 | Subtle aspects of audio start to be heard, but not all. Generally unable to produce sound all the way from deep bass to high treble. These products can require strong amp/DAC support to perform acceptably. |
| A: Audiophile âFineâ | $1,000 | Focal Clear (Original) | Reasonable dynamics, wide and accurate frequency reproduction, no glaring flaws. âClearâ ability to distinguish between primary notes and secondary sounds (e.g., room echoes, breath, etc.). |
| S: Superior or Specialized | $1,500+ to $6,000+ | HD-800S, Utopia, RAAL, ZMF, Audeze, Rosson, Abyss, etc. | Either technically superior or specialized in a way that appeals to dedicated users. These are not necessarily better or always hearable versus A tier products, but they are sometimes stunning. Low production numbers with little relationship between price and value. |
The thing that does it for me is the comfort of the PortaPro. I do prefer the KSC75 drivers on the PortaPro band.
The new KPH40 is even more comfortable but unfortunately it doesnât fold.
I always have a PortaPro in my backpack, and a set of KSC75âs (on headband) by each of the places I spend time, they are great for quick media consumption (such as YouTube etc.) and for long conference calls.
I really wish there was a headphone with the same setup but with better SQ.
The old Sennheiser PX-100 was, I think an upgrade against Porta Pro and it did fold. The PX-200 is reportedly similar, but not sure if itâs being made. These were in the $99-125 range. I donât know what Senn has there now, but if there is an evolutionary model, itâs probably worth a listen. The low end Grados also come to mind. Have not heard their sport band product, but clearly would be aimed at a similar audience to the Porta Pro.
I keep Porta Pros with YAXI pads at work and also near my regular listening station. They are my go to for quick listening and for telephone work - much better than using Speaker on my iPhone. I like them with the iPhone better than pretty much ANY wireless IEM until I get to the Audeze iSINE 20 or Audeze LCDi3 and wireless âcipherâ cable. Or wired Cipher cable, for that matter.
Theyâre not trying to be Focal Clears, or even Sennheiser HD-580s. As you point out comfort is supreme, and thatâs worth quite a bit in and of itself.
I have a pair of Porta Proâs on a stand to the right of my monitor as I type this. I equipped them with a set of Yaxi pads and am quite happy. They have the comfort I was looking for and the sound is acceptable. The Yaxi pads had an impressive impact on the sound quality, for me, they fleshed out the Bass and put an end to any irregularities in the Treble.
For my ears these are well worth the $45 that the phones & pads cost me.
Mark Gosdin
Throughout all my mods and chain swaps I found that the Porta Proâs timbre and mid range sound quality didnât change much. You can increase the (upper) bass, but thatâs about it. The treble canât truly be changed and mainly needs to be filtered. I take it for what it is.
Have you ever tried connecting a 75 ohm impedance adapter to the Porto Pro?
Nope. Do you have a source for how and why to do it?
Thanks.
You find a lot of discussion on this Head-Fi thread.
The impedance adapters address the treble extension of the Porto Pro, making it more trebly compared to stock. The higher impedance, paired with adequate power, also helps smooth out the low end.
I read the thread and the few posts regarding sound changes all said the impedance adapter makes no change at all. Maybe I missed something?
Itâs probably a lot like talk of cables making audible changes, it is something some people will hear and swear by and others may simply scoff at it.
It is something inexpensive to try to address any lack of treble. This technique worked well with Etymotic IEMs, so much so tht Etymotic sell there own adapter which makes any ER4-P sound like an ER4-S.
There may be a terminology issue going on.
It is possible to build various circuits into an adapter cable rather than just resistors in-line. These circuits can act as filters so they will certainly alter the sound.
Hmmm. You mean a hardware EQ like a Loki? I think itâs a functional duplicate.
Those seem designed to eliminate hiss on head gear which is more sensitive compared to the output of the amplifier. Like a CFA Andromeda.
Iâm always surprised at how sweet the Porta Pro can sound if not driven past its limits. At work, attached the Apple dongle - USB-3 version and plugged into my iPad , listening to Apple Classical. Some Bach Cello and guitar. Just lovely.
